查看: 1606|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 21.3 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件21.3
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 16:39:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2021/10/22
    包含的版本:21.3
    完整版校验和:
    文件大小: 1068597248 字节 (1019.09 MB)
    修改日期: 2022-03-25 10:15
    MD5: 34278ac81fae1dbad09ad72e93cdff5a
    SHA1: 4840ecec7c3330d075f4820daf3e8590d3a3af43
    SHA256: c62b9663fd0f1aa846f935e84706b2c0e66525e6ab72f07aab130a37e0dd6a70
    CRC32: ddc2062f
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 21.3.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 583467008 字节 (556.44 MB)
    修改日期: 2022-03-25 10:44
    MD5: cb1b0fa42b638d375af9ee0e052895ef
    SHA1: 52e1530441e9f32f7280105cbac9ce7804ca2c60
    SHA256: 00a21113975a3ab5e98696dc7aa814f16b17744f10c56cc35ea3d4bc6b7acf04
    CRC32: af2c726f
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.3RTE64.txt (563 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 580050944 字节 (553.18 MB)
    修改日期: 2022-03-25 11:00
    MD5: f4c9e6e4847f75967bc6456f54860216
    SHA1: 3008a02644fdaf1b61db4036c7a667c2cde68df4
    SHA256: 8631536465738479319eea4a1d6a344d38bd1ee85808afe7d2fa2350ff215d0a
    CRC32: 98de7823
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 21.3RTE32.txt (575 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 21.3 Readme
    October 2021
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 21.3 includes the following new features:
    RFmx GSM 20.7 includes the following new features:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx GSM has the following requirements:
    RFmx GSM 21.3 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 21.3 to an unsupported OS. Additionally, after installing RFmx GSM 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    Required Software
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 21.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375557R-01
    GMT+8, 2025-11-19 09:04
