NI RFmx GSM/EDGE+ 20.7.1 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件20.7.1
RFmx GSM/EDGE +
RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2021/7/20
包含的版本:20.7.1
完整版校验和:
文件大小: 932024320 字节 (888.85 MB)
修改日期: 2022-03-25 10:13
MD5: 99e636b51f9c5e854ddb4f5b517c9ab5
SHA1: 88d983ca8c1e6059f664a65d6153ea5b87781fcf
SHA256: 85ed34f15e5d580559b0d0cad45759f5183c549e71e653d35193e16a8cf0a34b
CRC32: 43007af9
NI官方下载和百度网盘下载地址:
注册登录视觉论坛账号,购买附件查看下载地址
RFmx GSM&EDGE 20.7.1.txt
(541 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 596176896 字节 (568.56 MB)
修改日期: 2022-03-25 10:42
MD5: 4ec11247121523f08bcfba0c84c2aa8c
SHA1: 97d2ba345105ea1329fc72f6863d01d42463c657
SHA256: 942f6d005005a88e14f5ed47e25438d2eb0e7f66843d566659ce9080cd32373d
CRC32: 9e7ca444
NI官方下载和百度网盘下载地址:
RFmx GSM&EDGE 20.7.1RTE64.txt
(565 Bytes, 下载次数: 0, 售价: 5 圆)
32位运行版校验和:
文件大小: 592574464 字节 (565.12 MB)
修改日期: 2022-03-25 10:59
MD5: 868d875d233b8564eb2bb2a8dece2145
SHA1: 4a61adb207ba226e91fa481bbe5adc0ba3f6b4bc
SHA256: d1cc7560c2aa250e89597aafb256934122c842bb1869b9dc8b6e04f78ec28d86
CRC32: bee00d97
NI官方下载和百度网盘下载地址:
RFmx GSM&EDGE 20.7.1RTE32.txt
(577 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx GSM 20.7.1 ReadmeJuly 2021 This file contains important information about the RFmx GSM, including system requirements, and installation instructions. Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Help Finding Examples Product Security and Critical Updates Behavior Changes Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewRFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. New FeaturesRFmx GSM 20.7 includes the following new features: - Support for Custom RBW in case of Modulation and Switching carrier powers.
RFmx GSM 20.0 includes the following new features: - Support for LabVIEW 2020 (32-bit and 64-bit)
- Support for Start trigger, Advance trigger, and Events in RFInstr
- Support to configure RFInstr properties in the context of a signal configuration
- Support for PXIe-5841 with PXIe-5655
RFmx GSM 19.1 includes the following new features: - Addition of RFmx GSM Soft Front Panel with debug support
- Support for 95 th percentile phase error in GSM PFER measurement
- Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
RFmx GSM 19.0 includes the following new features: - Support for LabVIEW 2019 (32-bit and 64-bit)
- Support for De-embedding S-Parameter External Attenuation Tables
- Addition of Reference Level Headroom property
RFmx GSM 3.0 includes the following new features: - Support for PXIe-5820
- Support for self-calibration in the RFmx Soft Front Panel
- Support for PvT measurement across slots of varying powers
Supported HardwareThe following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Vector Signal Analyzers- PXIe-5663
- PXIe-5663E
- PXIe-5665
- PXIe-5668
- PXIe-5668 with PXIe-5698
Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help. Vector Signal Transceivers- PXIe-5820
- PXIe-5840
- PXIe-5841
- PXIe-5644
- PXIe-5645
- PXIe-5646
- PXIe-5841 with PXIe-5655
Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help. System RequirementsRFmx GSM has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Windows 10, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx GSM 20.7.1 supports the following 64-bit operating systems: - Windows 10
- Windows Server 2019
- Windows Server 2016
Note RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 20.7.1 to an unsupported OS. Additionally, after installing RFmx GSM 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by RFmx GSM | | LabVIEW | 2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation .
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File Locations| Item | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » All Programs » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit). Accessing the APIRFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette. Accessing the HelpDocumentation for RFmx GSM is located at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents. | Document | Format | Description | | RFmx GSM Help | HTML/Windows Help | Contains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:- An introduction to RFmx GSM
- A complete reference for all RFmx GSM programming functions and VIs
| | RFmx GSM 20.7.1 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. | Finding ExamplesYou can access all the installed RFmx GSM examples at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Behavior ChangesThe following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6. - Obsoleted RFmxInstr Configure Automatic SG SA Shared LO API and RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0. - Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0. - Dropped support for LabVIEW 2015.
- Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
Known IssuesYou can access the RFmx GSM known issues list online at RFmx GSM 20.7 Known Issues. Bug FixesYou can access the RFmx GSM bug fix list online at RFmx GSM 20.7 Bug Fixes. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Legal InformationCopyright © 2015–2021 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375557P-01
