查看: 1464|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 20.7 x64Win10 32/64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件20.7
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 16:30:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2021/4/20
    包含的版本:20.7
    完整版校验和:
    文件大小: 932048896 字节 (888.87 MB)
    修改日期: 2022-03-25 10:12
    MD5: 09e2aa542447a58ae5368f868a2adc3f
    SHA1: 9dde51d988661b343226b3f24bae5e29d723e98b
    SHA256: bc04f30c74981dc8e17c2f1aee624261ec14b08c202fa2ee3755c2ca652172ee
    CRC32: 28d0c662
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 20.7.0.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 596189184 字节 (568.57 MB)
    修改日期: 2022-03-25 10:41
    MD5: a37fba3ef756fee5dc3df78cb2f2ea43
    SHA1: 9e4bf26fa4ee517ec077a3168bde5e312a3eee02
    SHA256: c956c6462904de6fbbf6c9ef4a9c368716c8b629acac7bca8a7eed65e82c33d7
    CRC32: 67ac4599
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.7.0RTE64.txt (565 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 592596992 字节 (565.14 MB)
    修改日期: 2022-03-25 10:57
    MD5: d829529943db6942da7b38f3b6031a6e
    SHA1: 2712d876d9f6a0d55509c4d318328d8ad01eedca
    SHA256: 43d44233910f0ed35ac18a69d6af691ab1a822ff4da4867b2372d8390ff00c96
    CRC32: 4a95efc6
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 20.7.0RTE32.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 20.7 Readme
    April 2021
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    Installed Software
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 20.7 includes the following new features:
    • Support for Custom RBW in case of Modulation and Switching carrier powers.
    RFmx GSM 20.0 includes the following new features:
    RFmx GSM 19.1 includes the following new features:
    • Addition of RFmx GSM Soft Front Panel with debug support
    • Support for 95 th percentile phase error in GSM PFER measurement
    • Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
    RFmx GSM 19.0 includes the following new features:
    RFmx GSM 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for PvT measurement across slots of varying powers
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx GSM has the following requirements:
    RFmx GSM 20.7 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 20.7 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 20.7 to an unsupported OS. Additionally, after installing RFmx GSM 20.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    Required Software
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation .
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start » All Programs » National Instruments » RFmx GSM » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 20.7 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx GSM examples at Start » All Programs » National Instruments » RFmx GSM » RFmx GSM Examples.
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    The following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0.
    • Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx GSM known issues list online at RFmx GSM 20.7 Known Issues.
    You can access the RFmx GSM bug fix list online at RFmx GSM 20.7 Bug Fixes.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375557N-01
    GMT+8, 2025-11-19 09:04
