NI RFmx GSM/EDGE+ 19.1 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件19.1
RFmx GSM/EDGE +
RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2019/10/17
包含的版本:19.1
Windows Server 2012 R2 64-bit
Windows 7 (SP1) 64-bit
Windows 8.1 64-bit
完整版校验和:
文件大小: 874780672 字节 (834.26 MB)
修改日期: 2022-03-25 22:15
MD5: 39cd5998b2fdef76d19efa5acd5522ac
SHA1: 72879b94b7c763be17ebdf4f21a9eaf7e07e1706
SHA256: 799119879ffa01c0ef3ebf3a00e364837c362589662519e8ca005850915bfbb4
CRC32: c909009b
NI官方下载和百度网盘下载地址:
注册登录视觉论坛账号,购买附件查看下载地址
RFmx GSM&EDGE 19.1.txt
(522 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 551956480 字节 (526.39 MB)
MD5: 6e0385d481291082f511495760e80b8b
SHA1: a4c42414c850cdb0cc1fbba9a0ca4a1b603225fd
SHA256: 50c22cc95f8ab56e625f6a656f3069f0fdb05f18c9f1b4980790bfd0ca58d02f
CRC32: 6f1f308c
NI官方下载和百度网盘下载地址:
RFmx GSM&EDGE 19.1RTE64.txt
(538 Bytes, 下载次数: 0, 售价: 5 圆)
32位运行版校验和:
文件大小: 558440448 字节 (532.57 MB)
MD5: 4401da7c2617356b6df5290e251db23d
SHA1: c71d3fd8753e038e60e5266ef7fcf1e12fbe6dd3
SHA256: 3cd4de92fcf0fc2d1ca85f5944d469ac34db4cb1ac06f9cafaab299229385355
CRC32: e7095704
NI官方下载和百度网盘下载地址:
RFmx GSM&EDGE 19.1RTE32.txt
(546 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx GSM 19.1 ReadmeOctober 2019 This file contains important information about the RFmx GSM, including system requirements and installation instructions. Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Help Finding Examples Product Security and Critical Updates Behavior Changes Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 Legal Information OverviewRFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. New FeaturesRFmx GSM 19.1 includes the following new features: - Addition of RFmx GSM Soft Front Panel with debug support
- Support for PXIe-5841
- Support for 95 th percentile phase error in GSM PFER measurement
- Support for 95 th percentile phase and magnitude error in EDGE ModAcc measurement
RFmx GSM 19.0 includes the following new features: - Support for LabVIEW 2019 (32-bit and 64-bit)
- Support for De-embedding S-Parameter External Attenuation Tables
- Addition of Reference Level Headroom property
RFmx GSM 3.0 includes the following new features: - Support for PXIe-5820
- Support for self-calibration in the RFmx Soft Front Panel
- Support for PvT measurement across slots of varying powers
Supported HardwareThe following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Vector Signal Analyzers- PXIe-5663
- PXIe-5663E
- PXIe-5665
- PXIe-5668
- PXIe-5668 with PXIe-5698
Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help . Vector Signal Transceivers- PXIe-5644
- PXIe-5645
- PXIe-5646
- PXIe-5820
- PXIe-5840
- PXIe-5841
Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help . System RequirementsRFmx GSM has the following requirements:
- Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Windows 10/8.1/7, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx GSM 19.1 supports the following 64-bit operating systems: - Windows 10/8.1 1 /7 SP1 2
- Windows Server 2012 R2 1
- Windows Server 2008 R2 SP1 2
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Note In 2019, RFmx GSM dropped support for all 32-bit Windows operating systems. RFmx GSM will not install or run on an unsupported OS. Refer to RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support. Application Software SupportRFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx GSM. To add support for application software installed after installing RFmx GSM modify your RFmx GSM installation or launch the RFmx GSM installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support . | Application Software | Versions Supported by RFmx GSM | | LabVIEW | 2016, 2017, 2018 SP1 f4 patch, or 2019 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0. Installation InstructionsNI installs RFmx GSM using NI Package Manager. If you do not already have NI software installed, RFmx GSM installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File Locations| Item | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » All Programs » National Instruments» RFmx GSM» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit). Accessing the APIRFmx GSM palette VIs are available from the Functions » Measurement I/O » NI-RFmx » GSM palette. Accessing the HelpDocumentation for RFmx GSM is located at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Documentation . The documentation set is composed of the following documents. | Document | Format | Description | | RFmx GSM Help | HTML/Windows Help | Contains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:- An introduction to RFmx GSM
- A complete reference for all RFmx GSM programming functions and VIs
| | RFmx GSM 19.1 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. | Finding ExamplesYou can access all the installed RFmx GSM examples at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals . Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Behavior ChangesThe following items are behavior changes in RFmx GSM 19.1 from RFmx GSM 19.0. - Obsoleted RFmxGSM Analyze (IQ) API. Use RFmxGSM Analyze (IQ, 1 Wfm) API instead
The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0. - Dropped support for LabVIEW 2015.
- Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
Known IssuesYou can access the software and documentation known issues list online. Refer to the RFmx GSM Known Issues for an up-to-date list of known issues. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in RFmx GSM . This is not an exhaustive list of issues fixed in the current version of the RFmx GSM . If you have a Bug ID, you can search this list to validate that the issue has been fixed. The following items are changes in RFmx GSM 19.1 from RFmx GSM 19.0. | ID | Fixed Issue | | 249283 | Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices. | | 234240 | Fixed an intermittent error occurring at Analyze IQ API when performing a composite measurement with different averaging count for each measurement |
The following items are changes in RFmx GSM 19.0 from RFmx GSM 3.0. | ID | Fixed Issue | | 237507 | Fixed an issue where querying ModAcc Results Detected TSC property for a slot index other than 0 resulted in an error. | | 237509 | Fixed an issue where querying the PVT Results properties by specifying result name in selector string resulted in an error. |
The following items are changes in RFmx GSM 3.0 from RFmx GSM 2.5 | ID | Fixed Issue | | 248862 | Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx. | | 244193 | Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840. | Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 . Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 . RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021RFmx GSM will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport . For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | LabVIEW | lifecycle | | LabWindows/CVI | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright © 2015–2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents . 375557K-01 |
