查看: 1483|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 19.0 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件19.0
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 16:17:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2019/6/27
    包含的版本:19.0
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 766838784 字节 (731.31 MB)
    修改日期: 2022-03-25 22:15
    MD5: 79cd0a6a72a61b1d391b39fd8a3ba23d
    SHA1: 1de3219913d2d7a5b6b5d523ce492d91edfac1fb
    SHA256: 2f40750ac99b71ebae5a674778eaf3bab841b5271f28c17016fb94a7d3cbc523
    CRC32: db3f7271
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 19.0.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 552007680 字节 (526.44 MB)
    MD5: 7db2b2352a7e53cd713fd113650562e9
    SHA1: 94bc7a0381166df0efd0aa2e64615283b779a2c5
    SHA256: 90dd30808bd3bd2fa797b787ca86225d4e7d464e5f61818c87b86824832eab11
    CRC32: d6917e95
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 19.0RTE64.txt (538 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 558612480 字节 (532.73 MB)
    MD5: fcfdd4983be64dbc3abe9df39bfcbd66
    SHA1: a9c6ef34a55eadabfb27097bd85f9c36927143be
    SHA256: f0c002254e996c8b125f5f4ed869baac135a1679b2ba22a1e8a256122f5ba1eb
    CRC32: 2d512d7f
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 19.0RTE32.txt (546 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 19.0 Readme
    June 2019
    This file contains important information about RFmx GSM, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    Installed Software
    RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx GSM is an optimized API for performing physical layer measurements on GSM cellular standard signals. RFmx GSM is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx GSM 19.0 includes the following new features:
    RFmx GSM 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for PvT measurement across slots of varying powers
    RFmx GSM 2.5 includes the following new features:
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxGSM Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    System RequirementsRFmx GSM has the following requirements:
    • RAM—4 GB*
    RFmx GSM 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx GSM dropped support for all 32-bit Windows operating systems. RFmx GSM will not install or run on an unsupported OS. Refer to RFmx GSM Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx GSM. To add support for application software installed after installing RFmx GSM modify your RFmx GSM installation or launch the RFmx GSM installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx GSM
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI automates RFmx GSM installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx GSM is available for download from NI Software Product Downloads.
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Measurement Interactive Panel to launch the RFmx GSM Measurement Interactive Panel.
    You can access all the installed RFmx GSM examples at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Examples.
    Documentation for RFmx GSM is located at Start»All Programs»National Instruments»RFmx GSM»RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx GSM HelpHTML/Windows HelpContains primary help content for RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx GSM
    • A complete reference for all RFmx GSM programming functions and VIs
    RFmx GSM 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    The following items are behavior changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    The following items are the behavior changes in RFmx GSM 2.3.1 from RFmx GSM 2.3.
    • The alias 'default@GSM' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    The following items are the IDs and titles of a subset of issues fixed in RFmx GSM. This is not an exhaustive list of issues fixed in the current version of the RFmx GSM. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx GSM 19.0 from RFmx GSM 3.0.
    731132Fixed an issue where querying ModAcc Results Detected TSC property for a slot index other than 0 resulted in an error.
    734443Fixed an issue where querying the PVT Results properties by specifying result name in selector string resulted in an error.
    The following items are changes in RFmx GSM 3.0 from RFmx GSM 2.5
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following items are changes in RFmx GSM 2.4 from RFmx GSM 2.3.1.
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in RFmx GSM 2.3.1 from RFmx GSM 2.3.
    654867Fixed an issue where the C functions and .NET methods used to configure the ORFS Custom Offset Frequency Array threw an error.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead and waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in RFmx GSM 2.3 from RFmx GSM 2.2.
    RFmx GSM will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    375557J-01
    GMT+8, 2025-11-19 09:04
