查看: 1462|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2.4 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件2.4
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 16:07:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2017/12/6
    包含的版本:2.4
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    完整版校验和:
    文件大小: 620863440 字节 (592.10 MB)
    修改日期: 2022-03-25 22:16
    MD5: 1e44cd736ae9933f25fa9e19d996bb0c
    SHA1: cde3ca7ff76a28386eb55ccb7626bd5c77c95b5a
    SHA256: 15d6071b6f81643b9db2698d21e33fb03b5decc357ee989441c2ac595a5e4a42
    CRC32: c4ae85d4
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 2.4.txt (486 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 345886728 字节 (329.86 MB)
    MD5: 4805ebfeead8709f87750d6ba4d99f16
    SHA1: b7c0a9c2de524469763f5e711737a1bc5d962b03
    SHA256: 67b6dc962969b839ac9b7ddbd25f5f079699f740730bab91f7551b666cb64a16
    CRC32: b65f0341
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.4RTE64.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 352718832 字节 (336.38 MB)
    MD5: 2d13101d2a0b86bfb2a3d8bd6bee3bbc
    SHA1: c0a28b041cba2d97cf535b8379ee83cdbae039a3
    SHA256: 8efd523b25d8cc98ac30073a09d00f02480a60113c6f38e946ffa11f1704280e
    CRC32: 704a08df
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.4RTE32.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 2.4 Readme
    November 2017
    This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx GSM
    NI-RFmx GSM 2.3 includes the following new features:
    NI-RFmx GSM 2.2 includes the following new features:
    • Support for I/Q gain imbalance for EDGE
    • Support for access burst in PVT
    • Support for constellation trace in ModAcc
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    NI-RFmx GSM 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution  Before you install NI-RFmx GSM 2.4, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx GSM 2.4 supports the following operating systems:
    Note  NI-RFmx GSM 2.4 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 2.4 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    NI-RFmx GSM 2.4 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx GSM drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 2.4 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 2.4 to an unsupported OS. Additionally, after installing NI-RFmx GSM 2.4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx GSM 2.4 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx GSM 2.4 installation, the following software is installed. To completely remove the NI-RFmx GSM 2.4 installation from your system, you must also remove the following package:
    • NI-RFmx GSM Runtime 2.4
    • NI-RFmx GSM Runtime 2.4 (64-bit)
    The following items are the behavior changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    • The alias 'default@GSM' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx GSM 2.4 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx GSM 2.4
    The following items are changes in NI-RFmx GSM 2.4 from NI-RFmx GSM 2.3.1.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx GSM 2.3.1 from NI-RFmx GSM 2.3.
    654867Fixed an issue where the C functions and .NET methods used to configure the ORFS Custom Offset Frequency Array threw an error.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx GSM 2.3 from NI-RFmx GSM 2.2.
    © 2015–2017 National Instruments. All rights reserved.
    375557F-01
    GMT+8, 2025-11-19 09:04
