查看: 1433|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2.3 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件2.3
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 15:58:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2017/5/4
    包含的版本:2.3
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    Windows 8.1
    完整版校验和:
    文件大小: 684904400 字节 (653.18 MB)
    修改日期: 2022-03-25 22:15
    MD5: 5f98e137d6cd1d038fa685b0f82dfbe9
    SHA1: 3059827158faf8528329c5c203e7337e02f5cdf4
    SHA256: 5b3a7ef664d16dd719bc74f4656e3743378b213215c570f56a901e0954104b64
    CRC32: 4dfa513e
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 2.3.0.txt (492 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 360587272 字节 (343.88 MB)
    MD5: f3fc16e6fb2e421e6ddad4073c6c8586
    SHA1: 2ded5eb296c56a4f3f76f54a1dff158bcfec17c5
    SHA256: 024eb3fc2a742f3e325bd58de6bd25b43a1bafa475a1c87edda3b459a8719b3d
    CRC32: d41338f2
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.3.0RTE64.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 364752880 字节 (347.86 MB)
    修改日期: 2022-03-25 22:16
    MD5: 3b83c20567a348fca61a3a01ffad82a4
    SHA1: 9fee22d9108fb6749e1ef76262d28ccdb8330841
    SHA256: b7c5c9179d0b7d821d55e52317ca822a5285bb1edea8a91fdf5dac5ef6e7c967
    CRC32: e58b82b7
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.3.0RTE32.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 2.3 Readme
    May 2017
    This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx GSM
    NI-RFmx GSM 2.3 includes the following new features:
    NI-RFmx GSM 2.2 includes the following new features:
    • Support for I/Q gain imbalance for EDGE
    • Support for access burst in PVT
    • Support for constellation trace in ModAcc
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    NI-RFmx GSM 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution  Before you install NI-RFmx GSM 2.3, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx GSM 2.3 supports the following operating systems:
    Note  NI-RFmx GSM 2.3 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 2.3 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    NI-RFmx GSM 2.3 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx GSM drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 2.3 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 2.3 to an unsupported OS. Additionally, after installing NI-RFmx GSM 2.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx GSM 2.3 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx GSM 2.3 installation, the following software is installed. To completely remove the NI-RFmx GSM 2.3 installation from your system, you must also remove the following package:
    • NI-RFmx GSM Runtime 2.3
    • NI-RFmx GSM Runtime 2.3 (64-bit)
    You can access the software and documentation known issues list online. Refer to the NI-RFmx GSM 2.3 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx GSM 2.3.
    The following items are changes in NI-RFmx GSM 2.3 from NI-RFmx GSM 2.2.
    The following items are changes in NI-RFmx GSM 2.2 from NI-RFmx GSM 2.1.
    560076Fixed an issue where a high phase error was observed in the initial few samples of the phase error trace for GMSK, with certain generation sources.
    The following items are changes in NI-RFmx GSM 2.1 from NI-RFmx GSM 2.0.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2015–2017 National Instruments. All rights reserved.
    375557D-01
    GMT+8, 2025-11-19 09:03
