查看: 1536|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2.2 Win32/64Eng GSM/EDGE/EDGE Evolved蜂窝测试软件2.2
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-12 15:53:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE +
    RFmx GSM/EDGE+为GSM、EDGE和EDGE Evolved蜂窝测试应用提供了信号生成和分析功能。
    RFmx GSM/EDGE+是一款测量专用软件,旨在扩展NI RF仪器生成和分析GSM、EDGE和EDGE Evolved蜂窝信号的能力。该软件可以通过相位和频率误差、误差矢量幅度(EVM)、输出RF频谱(ORFS)、功率时间变化曲线(PVT) 等符合标准的物理层测量,对GSM、EDGE和EDGE Evolved信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2016/12/8
    包含的版本:2.2
    Windows Server 2008 R2 64-bit
    Windows 8.1
    Windows 7
    Windows 10
    完整版校验和:
    文件大小: 569302992 字节 (542.93 MB)
    修改日期: 2022-03-25 22:15
    MD5: 646bd579c1ab5a5898d3b476e18f3948
    SHA1: 2a3b540910aad681ebfcef74ba6b320694414e51
    SHA256: 0132af96905917487bca1641403559f821e6e24c60cd4ecf61528b8bb415115c
    CRC32: f5ca78c1
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM&EDGE 2.2.txt (486 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 276361224 字节 (263.56 MB)
    MD5: a239a633d83eda4455535c541b64123e
    SHA1: 48c6bbdd1cda110708e2c963e758681edcc92a4d
    SHA256: 8abb6833cca9881bf23837ec29e62acc104b0af3a295c8453e73644e4b7b4066
    CRC32: c3c703b3
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.2RTE64.txt (504 Bytes, 下载次数: 0, 售价: 5 圆)
    32位运行版校验和:
    文件大小: 281350128 字节 (268.32 MB)
    MD5: 6e441e1535a6826a39babaafc8267590
    SHA1: 1b987de6ec824bf64e26b1379d034bb83d4b0b07
    SHA256: 3292cf03faf5f7e3a924728164f3f5eda130cc9632ef840f59cbe81ce5e63194
    CRC32: 6d6b30eb
    NI官方下载和百度网盘下载地址:
    RFmx GSM&EDGE 2.2RTE32.txt (487 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx GSM 2.2 Readme
    December 2016
    Thank you for using NI-RFmx GSM. This file contains important information about NI-RFmx GSM and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx GSM
    NI-RFmx GSM 2.2 includes the following new features:
    • Support for I/Q gain imbalance for EDGE
    • Support for access burst in PVT
    • Support for constellation trace in ModAcc
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    NI-RFmx GSM 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    NI-RFmx GSM 2.1 includes the following new features:
    • Support for C and .NET
    • Support for the Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q waveform
    Caution  Before you install NI-RFmx GSM 2.2, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx GSM 2.2 supports the following operating systems:
    Note  NI-RFmx GSM 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx GSM. To add support for ADEs installed after installing NI-RFmx GSM, modify your NI-RFmx GSM installation or launch the NI-RFmx GSM installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    Note  NI-RFmx GSM will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\GSM\Examples
    Examples\LabVIEW \examples\RFmx\GSM
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Measurement Interactive Panel to launch the NI-RFmx GSM Measurement Interactive Panel.
    Documentation for NI-RFmx GSM is located at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx GSM HelpHTML/Windows HelpInformation about NI-RFmx GSM. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx GSM
    • A complete reference for all NI-RFmx GSM programming functions and VIs
    NI-RFmx GSM 2.2 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx GSM palette VIs are available from the Functions»Measurement I/O»NI-RFmx»GSM palette.
    You can access all the installed NI-RFmx GSM examples at Start»All Programs»National Instruments»NI-RFmx GSM»NI-RFmx GSM Examples.
    NI-RFmx GSM 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx GSM drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx GSM 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx GSM 2.2 to an unsupported OS. Additionally, after installing NI-RFmx GSM 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx GSM 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx GSM 2.2 installation, the following software is installed. To completely remove the NI-RFmx GSM 2.2 installation from your system, you must also remove the following package:
    • NI-RFmx GSM Runtime 2.2
    • NI-RFmx GSM Runtime 2.2 (64-bit)
    You can access the software and documentation known issues list online. Refer to the NI-RFmx GSM 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx GSM 2.2.
    The following items are changes in NI-RFmx GSM 2.2 from NI-RFmx GSM 2.1.
    560076Fixed an issue where a high phase error was observed in the initial few samples of the phase error trace for GMSK, with certain generation sources.
    The following items are changes in NI-RFmx GSM 2.1 from NI-RFmx GSM 2.0.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2015–2016 National Instruments. All rights reserved.
    375557C-01
    GMT+8, 2025-11-19 09:06
