查看: 1459|回复: 0
[NI软件产品] NI RFmx EV-DO 20.0 Win32/64Eng 1xEV-DO蜂窝测试软件20.0
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-8 16:40:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2020/6/9
    包含的版本:20.0
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    完整版校验和:
    文件大小: 780130304 字节 (743.99 MB)
    修改日期: 2022-03-25 09:44
    MD5: ba8680169f559998686b4c3f7e1ab056
    SHA1: d53210171398a597b3bace056bb83079111f839c
    SHA256: c574da76b047cf307c00bb509e4ad60902bcd2a893fa700fb38c540287ee0821
    CRC32: 81da7bfd
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO20.0.txt (537 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 579504128 字节 (552.66 MB)
    修改日期: 2022-03-25 10:00
    MD5: 1d482ea083e17697408d790f537bc4ad
    SHA1: 3771cfc63a9cab26ecab1f23ee75be647d4d7b3b
    SHA256: a8298bd8baa7db9ed39d45edf8482973d47bb5cea3ff38652c7c7b8275153c31
    CRC32: f42bc625
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.0RTE32.txt (573 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 582262784 字节 (555.29 MB)
    修改日期: 2022-03-25 09:53
    MD5: 2c093d354189839aa381a8ae758857e5
    SHA1: a823984f1ff03742c0b85604bd2d9743e8e1c29d
    SHA256: ef80abbe8237895b6e46b7c633e6c75b84f5b5a9dd40f2b5768b2e50be63fc0e
    CRC32: 39a966e0
    NI官方下载和百度网盘下载地址:
    RFmx EVDO20.0RTE64.txt (561 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 20.0 Readme
    June 2020
    This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions.
    Installed Software
    RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 20.0 includes the following new features:
    RFmx EV-DO 19.1 includes the following new features:
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx EV-DO has the following requirements:
    RFmx EV-DO 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx EV-DO dropped support for all 32-bit Windows operating systems. RFmx EV-DO will not install or run on an unsupported OS. Refer to RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx EV-DO dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx EV-DO 20.0 to an unsupported OS. Additionally, after installing RFmx EV-DO 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. To add support for application software installed after installing RFmx EV-DO modify your RFmx EV-DO installation or launch the RFmx EV-DO installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx EV-DO
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    Required Software
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx EV-DO using NI Package Manager. If you do not already have NI software installed, RFmx EV-DO installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation .
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start » All Programs » National Instruments » RFmx EV-DO » RFmx EV-DO Examples.
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the RFmx EV-DO known issues list online at RFmx EV-DO 20.0 Known Issues.
    You can access the RFmx EV-DO bug fix list online at RFmx EV-DO 20.0 Bug Fixes.
    RFmx EV-DO will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2020 National Instruments. All rights reserved.
    375526L-01
    GMT+8, 2025-11-19 09:07
