查看: 1675|回复: 0
[NI软件产品] NI RFmx EV-DO 19.1 Win32/64Eng 1xEV-DO蜂窝测试软件19.1
    6 小时前
  • 签到天数: 3863 天
    连续签到: 56 天
     楼主| 发表于 2022-7-8 16:38:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2019/10/17
    包含的版本:19.1
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 807114752 字节 (769.72 MB)
    修改日期: 2022-03-25 22:13
    MD5: b6a50e9b0caa7a67ff544666ffc08900
    SHA1: d5e77a0155a9061760fd2871badcab6a8f6ddad8
    SHA256: 5769d81ef8ae80179103cf0b6d14bfbe197864d5b5ab0561c0d034690a08ea2b
    CRC32: 6f02e8ae
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO19.1.txt (521 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 573274112 字节 (546.72 MB)
    MD5: f98a570f883c637f9ce07e473b7d9d8c
    SHA1: 79f66374ffe2b4e69d52d721485a0f412fb85393
    SHA256: 499ef97391f8ac8fc0bd86218ee28aae0676706fb47740e2765ddb67937aae0d
    CRC32: ee1fb54d
    NI官方下载和百度网盘下载地址:
    RFmx EVDO19.1RTE32.txt (545 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 566888448 字节 (540.63 MB)
    MD5: cb08fc16b1d8150eae45e1f36b17ac8c
    SHA1: 2a4d2f9ad6004fc1200ed0d5cb37bb0b69c892c1
    SHA256: 9ba22d709b5909c9c2ec2d21b641f44c59a0017a6d04f3d06f925869c87aed1b
    CRC32: 09aa18bd
    NI官方下载和百度网盘下载地址:
    RFmx EVDO19.1RTE64.txt (537 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 19.1 Readme
    October 2019
    This file contains important information about the RFmx EV-DO, including system requirements and installation instructions.
    Installed Software
    RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 19.1 includes the following new features:
    • Support for PXIe-5841
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx EV-DO has the following requirements:
    RFmx EV-DO 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx EV-DO dropped support for all 32-bit Windows operating systems. RFmx EV-DO will not install or run on an unsupported OS. Refer to RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx EV-DO. To add support for application software installed after installing RFmx EV-DO modify your RFmx EV-DO installation or launch the RFmx EV-DO installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx EV-DO
    Required Software
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx EV-DO using NI Package Manager. If you do not already have NI software installed, RFmx EV-DO installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    RFmx EV-DO palette VIs are available from the Functions » Measurement I/O » NI-RFmx » EVDO palette.
    Documentation for RFmx EV-DO is located at Start»All Programs»National Instruments»RFmx EV-DO»RFmx EV-DO Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx EV-DO examples at Start»All Programs»National Instruments»RFmx EV-DO»RFmx EV-DO Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are behavior changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0.
    • Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    You can access the software and documentation known issues list online. Refer to the RFmx EV-DO Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx EV-DO . This is not an exhaustive list of issues fixed in the current version of the RFmx EV-DO . If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx EV-DO 19.1 from RFmx EV-DO 19.0
    249283Fixed an issue to report an error when measurement bandwidth exceeds the device instantaneous bandwidth on PXIe-5668 and PXIe-5665 devices.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement.
    238895Fixed an issue with multicarrier measurements when the Automatic SG SA Shared LO property is set to Enabled .
    212491Fixed an issue with SEM mask for band class 6, 8, and 13.
    216452Fixed an issue with SEM mask display for band class 6 for multi-carrier configuration with 3 carriers.
    The following items are changes in RFmx EV-DO 3.0 from RFmx EV-DO 2.5
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx EV-DO will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    375526K-01
    GMT+8, 2026-4-21 13:50
