查看: 1455|回复: 0
[NI软件产品] NI RFmx EV-DO 19.0 Win32/64Eng 1xEV-DO蜂窝测试软件19.0
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-8 16:31:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2019/6/27
    包含的版本:19.0
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    完整版校验和:
    文件大小: 805013504 字节 (767.72 MB)
    修改日期: 2022-03-25 22:13
    MD5: 86e36015a4f5ab28477ddcc2d59ec8cb
    SHA1: 8b2cf37b17541fe94221bc8b1eb26dfd8b976495
    SHA256: 778782182d4bb827db70c73f214bbd513e475095a7b54f38d561dec6c2e5c207
    CRC32: 0fe8d694
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO19.0.txt (521 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 573374464 字节 (546.81 MB)
    MD5: 1cc731c62135882bb2f30c7cc3091a27
    SHA1: 3bfa3ff2204418ca14a4d75fb3b1ebf5e90ecafc
    SHA256: 7c4fcdef33d996112400675222117b5dd5ab59019c59ec4dc9dfb519dff46d82
    CRC32: 1645c47a
    NI官方下载和百度网盘下载地址:
    RFmx EVDO19.0RTE32.txt (545 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 566865920 字节 (540.61 MB)
    MD5: b9525ef4ae8f53e442f142ee3aa3c599
    SHA1: f7bd12f8bd28eb797c17511491e1c84755daae9a
    SHA256: 0f735e17d459f8cce999a548cf8fab0d4dca1e779df64ad4b73518d93c740143
    CRC32: 63dbd074
    NI官方下载和百度网盘下载地址:
    RFmx EVDO19.0RTE64.txt (537 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx EV-DO 19.0 Readme
    June 2019
    This file contains important information about RFmx EV-DO, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    Installed Software
    RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx EV-DO is an optimized API used for performing physical-layer measurements on EV-DO cellular standard signals. RFmx EV-DO is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx EV-DO 19.0 includes the following new features:
    RFmx EV-DO 3.0 includes the following new features:
    • Support for PXIe-5820
    RFmx EV-DO 2.5 includes the following new features:
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxEVDO Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    System RequirementsRFmx EV-DO has the following requirements:
    • RAM—4 GB*
    RFmx EV-DO 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx EV-DO dropped support for all 32-bit Windows operating systems. RFmx EV-DO will not install or run on an unsupported OS. Refer to RFmx EV-DO Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx EV-DO. To add support for application software installed after installing RFmx EV-DO modify your RFmx EV-DO installation or launch the RFmx EV-DO installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx EV-DO
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI automates RFmx EV-DO installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx EV-DO is available for download from NI Software Product Downloads.
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\EVDO\Examples
    Examples\LabVIEW \examples\RFmx\EV-DO
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.EV-DOMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx EV-DO»RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel.
    You can access all the installed RFmx EV-DO examples at Start»All Programs»National Instruments»RFmx EV-DO»RFmx EV-DO Examples.
    Documentation for RFmx EV-DO is located at Start»All Programs»National Instruments»RFmx EV-DO»RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx EV-DO HelpHTML/Windows HelpContains primary help content for RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx EV-DO
    • A complete reference for all RFmx EV-DO programming functions and VIs
    RFmx EV-DO 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx EV-DO palette VIs are available from the Functions»Measurement I/O»NI-RFmx»EVDO palette.
    The following items are behavior changes in RFmx EV-DO 19.0 from RFmx EV-DO 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    The following items are the behavior changes in RFmx EV-DO 2.3.1 from RFmx EV-DO 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@EVDO' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    Bug FixesThe following items are the IDs and titles of a subset of issues fixed in RFmx EV-DO. This is not an exhaustive list of issues fixed in the current version of the RFmx EV-DO. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx EV-DO 3.0 from RFmx EV-DO 2.5
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following items are changes in RFmx EV-DO 2.4 from RFmx EV-DO 2.3.1.
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in RFmx EV-DO 2.3.1 from RFmx EV-DO 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead and waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in RFmx EV-DO 2.3 from RFmx EV-DO 2.2.
    623679Fixed an issue with measurement of small EVMs (close to 0%) when no input signal is present in the ModAcc measurement.
    RFmx EV-DO will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    375526J-01
    GMT+8, 2025-11-19 09:04
