查看: 1581|回复: 0
[NI软件产品] NI RFmx EV-DO 2.5 Win32/64Eng 1xEV-DO蜂窝测试软件2.5
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-8 16:24:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2018/7/3
    包含的版本:2.5
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    完整版校验和:
    文件大小: 598671320 字节 (570.94 MB)
    修改日期: 2022-03-25 22:14
    MD5: 49bca3356c02ea6ac8cd659bc9bd54ae
    SHA1: b1e1cb4bedc650e04cf9f005f9fc7551186bd5fb
    SHA256: 4fa735718356c57922d99390c11944c3a20cef82d38a2793786d0c3bd1ec391e
    CRC32: dd8f44b5
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO2.5.txt (491 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 358096888 字节 (341.51 MB)
    MD5: ce8e536d2a89857519f6d5fbcccbd55d
    SHA1: f67c7880e6089c8346b5e8f1979778514ca47f85
    SHA256: b88508b96a32f4277f1c65f8feef0f34c6faff1aab9456d8ec9bee59ea656ba0
    CRC32: 084b781c
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.5RTE32.txt (503 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 351350800 字节 (335.07 MB)
    MD5: a94a54d9d0557d713020da3d6fb6f92c
    SHA1: 9c1646795ae8aff8e951169928ba15fc55faad66
    SHA256: 1dd21415abc48d2d9dd2b9466e07100621dcf45a00db11190db7521bcdbe996f
    CRC32: 89664126
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.5RTE64.txt (503 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx EV-DO 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx EV-DO and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx EV-DO 2.5 includes the following bug fixes and updates:
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxEVDO Commit API
    NI-RFmx EV-DO 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Phase measurement
    Caution  Before you install NI-RFmx EV-DO 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx EV-DO 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx EV-DO dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx EV-DO 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx EV-DO 2.5 to an unsupported OS. Additionally, after installing NI-RFmx EV-DO 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFmx EV-DO 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx EV-DO. To add support for ADEs installed after installing NI-RFmx EV-DO, modify your NI-RFmx EV-DO installation or launch the NI-RFmx EV-DO installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx EV-DO will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\EV-DO\Examples
    Examples\LabVIEW \examples\RFmx\EVDO
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Measurement Interactive Panel to launch the NI-RFmx EV-DO Measurement Interactive Panel.
    Documentation for NI-RFmx EV-DO is located at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx EV-DO HelpHTML/Windows HelpInformation about NI-RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx EV-DO
    • A complete reference for all NI-RFmx EV-DO programming functions and VIs
    NI-RFmx EV-DO 2.5 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    NI-RFmx EV-DO palette VIs are available from the Functions»Measurement I/O»NI-RFmx»EV-DO palette.
    You can access all the installed NI-RFmx EV-DO examples at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Examples.
    The following items are the behavior changes in NI-RFmx EV-DO 2.3.1 from NI-RFmx EV-DO 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@EVDO' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are not supported any longer.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx EV-DO 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx EV-DO 2.5.
    The following items are changes in NI-RFmx EV-DO 2.4 from NI-RFmx EV-DO 2.3.1.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx EV-DO 2.3.1 from NI-RFmx EV-DO 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead and waited for the measurement to finish before closing.
    650083Fixed the RFInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing a NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx EV-DO 2.3 from NI-RFmx EV-DO 2.2.
    623679Fixed an issue with measurement of small EVMs (close to 0%) when no input signal is present in the ModAcc measurement.
    © 2015–2018 National Instruments. All rights reserved.
    375526G-01
    GMT+8, 2025-11-19 09:06
