查看: 1431|回复: 0
[NI软件产品] NI RFmx EV-DO 2.2 Win32/64Eng 1xEV-DO蜂窝测试软件2.2
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-8 16:00:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx EV-DO
    RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
    RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2016/12/8
    包含的版本:2.2
    Windows 7
    Windows 10
    Windows Server 2008 R2 64-bit
    Windows 8.1
    完整版校验和:
    文件大小: 589971416 字节 (562.64 MB)
    修改日期: 2022-03-25 22:14
    MD5: a1acffec5e7ed4962c7c80d997490b17
    SHA1: 60c4bcdf4523d70e0121e9cfb0df612663ec835f
    SHA256: 999ded9353ced317020b7cda89084fdf5512ff465847d6bd2adfa1969e8120ef
    CRC32: 3b8515d6
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx EVDO2.2.txt (491 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 289103864 字节 (275.71 MB)
    MD5: e0c317b6fec8d0f973072cace9cb70e0
    SHA1: 1d2b1be716bffeefa6e55035df3658d5ee49ded1
    SHA256: 2b82520a5d703e58a92a16a6724ef884ab5ab071109c7c9bb8ad37254d128141
    CRC32: 659eb3b7
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.2RTE32.txt (503 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 284205072 字节 (271.04 MB)
    MD5: 0e9520a264545a1c475b81d1abc777d7
    SHA1: 2565cc28378a0a84d8ed03fca2182b53238aeb6e
    SHA256: be44f800a1c699251fc34ad6bf1439fbd56dc127945841ed5c2649451b2fe4c3
    CRC32: 698bdec6
    NI官方下载和百度网盘下载地址:
    RFmx EVDO2.2RTE64.txt (503 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx EV-DO 2.2 Readme
    December 2016
    Thank you for using NI-RFmx EV-DO. This file contains important information about NI-RFmx EV-DO and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx EV-DO
    NI-RFmx EV-DO 2.2 includes the following new features:
    • Addition of I/Q gain imbalance and I/Q quadrature error measurement results in ModAcc measurement
    • Improved robustness of channel and data modulation auto detection in ModAcc measurements
    • Support for reading measurement configuration internally used by RFmx for spectral measurements
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer
    NI-RFmx EV-DO 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    NI-RFmx EV-DO 2.1 includes the following new features:
    • Support for C and .NET
    • Support for the Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q or spectrum waveform
    Caution  Before you install NI-RFmx EV-DO 2.2, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx EV-DO 2.2 supports the following operating systems:
    Note  NI-RFmx EV-DO 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx EV-DO. To add support for ADEs installed after installing NI-RFmx EV-DO, modify your NI-RFmx EV-DO installation or launch the NI-RFmx EV-DO installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    Note  NI-RFmx EV-DO will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    Item
    Installed Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\EV-DO\Examples
    Examples\LabVIEW \examples\RFmx\EVDO
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Measurement Interactive Panel to launch the NI-RFmx EV-DO Measurement Interactive Panel.
    Documentation for NI-RFmx EV-DO is located at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFmx EV-DO HelpHTML/Windows HelpInformation about NI-RFmx EV-DO. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx EV-DO
    • A complete reference for all NI-RFmx EV-DO programming functions and VIs
    NI-RFmx EV-DO 2.2 Beta 1 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx EV-DO palette VIs are available from the Functions»Measurement I/O»NI-RFmx»EV-DO palette.
    You can access all the installed NI-RFmx EV-DO examples at Start»All Programs»National Instruments»NI-RFmx EV-DO»NI-RFmx EV-DO Examples.
    NI-RFmx EV-DO 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx EV-DO drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx EV-DO 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx EV-DO 2.2 to an unsupported OS. Additionally, after installing NI-RFmx EV-DO 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx EV-DO 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx EV-DO 2.2 installation, the following software is installed. To completely remove the NI-RFmx EV-DO 2.2 installation from your system, you must also remove the following package:
    • NI-RFmx EV-DO Runtime 2.2
    • NI-RFmx EV-DO Runtime 2.2 (64-bit)
    You can access the software and documentation known issues list online. Refer to the NI-RFmx EV-DO 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx EV-DO 2.2.
    The following items are changes in NI-RFmx EV-DO 2.1 from NI-RFmx EV-DO 2.0.
    ID
    Fixed Issue
    563070Fixed an issue with fetching scalar results from the property node when traces are disabled in the NI-RFmx EV-DO ModAcc measurement.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2015–2016 National Instruments. All rights reserved.
    375526C-01
    GMT+8, 2025-11-19 09:06
