查看: 1183|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 21.8.2 Runtime x64Win10 64bitEng NI RFmx解调/模拟调制/数字调制21.8.2运行版
  • 签到天数: 3535 天
     楼主| 发表于 2022-7-8 10:40:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    RFmx数字调制
    RFmx数字変調提供测试应用数字変調信号生成和分析。
    RFmx Digital Modulation是RFmx Demod内运行的应用软件,该软件与RFmx Digital Modulation一起安装。该软件可扩展NI RF仪器对于数字调制信号的生成和分析能力。您可以使用这个软件,通过对误差矢量幅度(EVM)、调制误差率(MER)、rho、振幅下降等的测量,分析ASK、FSK、PSK和QAM信号。此外,您可以分析同步化和应用化的灵活均衡、脉冲形状过滤、测量过滤和损伤补偿的解调比特。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:2022/6/30
    包含的版本:21.8.2运行版
    文件大小: 601456640 字节 (573.59 MB)
    修改日期: 2022-06-29 21:48
    MD5: 1f5fa9cacd7e23c43de3ef8f510909c1
    SHA1: 981937da034b45c5795c3b8053dae78b851ce9c5
    SHA256: 69b0160cc04b1d772815e1f9e36197ace001888f42326b211fb974e852e1af90
    CRC32: eca6794a
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx Demod Analog Digital Modulation21.8.2 RTE64.txt (626 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx Demod 21.8.2 Readme
    May 2022
    This file contains important information about the RFmx Demod, including system requirements, and installation instructions.
    • RFmx Analog Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Digital Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Analog Modulation Manuals: New features, behavior changes, and other documentation
    • RFmx Digital Modulation Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 21.3 includes the following new features:
    RFmx Demod 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx Demod 20.0 includes the following new features:
    RFmx Demod 21.8.2 supports the following 64-bit operating systems:
    Note    RFmx Demod no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Demod 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Demod 21.8.2 to an unsupported OS. Additionally, after installing RFmx Demod 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Application SoftwareVersions Supported by RFmx Demod
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    LabWindows™/CVI™2017 or later
    Required Software
    • NI-RFSG 14.0.1 or later
    • RFmx Demod installs the following licensed products
      • Analog Modulation: This will enable demodulation support of Analog Modulation (AM), Frequency Modulation (FM), and Phase Modulation (PM).
      • Digital Modulation: This will enable demodulation support of Amplitude-Shift Keying (ASK), Frequency-Shift Keying (FSK), Minimum-Shift Keying (MSK), Phase-Shift Keying (PSK), and Quadrature Amplitude Modulation (QAM).
    • Use the serial number that is included with your software to activate RFmx Demod. For more information on RFmx Demod activation, refer to National Instruments Software Activation.
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » National Instruments» RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start » National Instruments » RFmx Demod » RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 21.8.2 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Demod examples at Start » National Instruments » RFmx Demod » RFmx Demod Examples.
    The following items are behavior changes in RFmx Demod 20.7 from RFmx Demod 20.6.
    © 2014–2022 National Instruments Corporation. All rights reserved.
    374855Y-01
    GMT+8, 2025-5-10 20:28
