NI RFmx for Bluetooth Test 21.8.2 x64Win10 32/64bitEng RFmx蓝牙测试NIRFmxBluetooth21.8.2
RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
发布日期:2022/6/29
包含的版本:21.8.2完整版
校验和
文件大小: 1057388544 字节 (1008.40 MB)
修改日期: 2022-06-30 09:47
MD5: 70bc55b55ff4f885cf4547f5bd3514ee
SHA1: 6d826ddea26cf3f7ca4232b76d2f45f3167cef97
SHA256: 4c263cdd93672186232d9830c2cb38ec4d5cf80cfd0714b992d3f3b0f9e5ed98
CRC32: 0e7fc7aa
注册登录视觉论坛账号,购买附件查看下载地址
RFmxBT21.8.2.txt
(563 Bytes, 下载次数: 0, 售价: 10 圆)
RFmx for Bluetooth® Test 21.8.2 ReadmeMay 2022 This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Help Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information OverviewRFmx for Bluetooth® Test supports the following features: - Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.2, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
- Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.2.
- Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
- Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
- Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
New FeaturesRFmx for Bluetooth® Test 21.8 includes the following new features: - Support for Initial Frequency Error Maximum result for LE packets in ModAcc measurement
RFmx for Bluetooth® Test 21.3 includes the following new features: - Support for LabVIEW 2021 (32-bit and 64-bit)
- Support for DEVM magnitude and phase error results in ModAcc measurement
RFmx for Bluetooth® Test 20.0 includes the following new features: - Support for LabVIEW 2020 (32-bit and 64-bit)
- Support for Start trigger, Advance trigger, and Events in RFInstr
- Support to configure RFInstr properties in the context of signal configuration
- Support for PXIe-5841 with PXIe-5655
- Support for Demodulated Bit Trace in ModAcc measurement
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx for Bluetooth® Test has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Windows 10, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx for Bluetooth® Test 21.8.2 supports the following 64-bit operating systems: - Windows 10
- Windows Server 2019
- Windows Server 2016
Note RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 21.8.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 21.8.2 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 21.8.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx for Bluetooth® Test | | LabVIEW | 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021 SP1 f1 patch | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » RFmx for Bluetooth® Test » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit). Accessing the APIRFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Bluetooth palette. Accessing the HelpDocumentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx Bluetooth Documentation. The documentation set is composed of the following documents. Document | Format | Description | | RFmx for Bluetooth® Test Help | HTML/Windows Help | Contains primary help content for RFmx for Bluetooth® Test. This help file is an HTML version of a traditional user manual that includes the following information:- An introduction to RFmx for Bluetooth® Test
- A complete reference for all RFmx for Bluetooth® Test programming functions and VIs
| | RFmx for Bluetooth® Test 21.8.2 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. | Finding ExamplesYou can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx Bluetooth Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7. - Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
The following are the behavior changes in RFmx for Bluetooth® Test 20.7 from RFmx for Bluetooth® Test 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
The following items are behavior changes in RFmx for Bluetooth® Test 19.1 from RFmx for Bluetooth® Test 19.0. - Obsoleted RFmxBT Analyze (IQ) API. Use RFmxBT Analyze (IQ, 1 Wfm) API instead
- A warning is thrown if the measurement fails to detect start of the packet when you set the Burst Sync Type property to Preamble
The following items are behavior changes in RFmx for Bluetooth® Test 19.0 from RFmx for Bluetooth® Test 3.0. - Dropped support for LabVIEW 2015
- Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Legal InformationCopyright © 2019–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 377890L-01 |
