查看: 1009|回复: 0
[RTE运行引擎] NI RFmx for Bluetooth Test 21.8.1 Runtime x64Win10 32bitEng RFmx蓝牙测试NIRFmxBluetooth21.8.1运行版32位
    昨天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
     楼主| 发表于 2022-7-6 16:25:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
    RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
    发布日期:2022/4/30
    包含的版本:21.8.1运行版
    应用程序位数:32位
    校验和
    文件大小: 632698880 字节 (603.39 MB)
    修改日期: 2022-04-30 01:45
    MD5: fb709b7ec48ed234960cf4e4c2f87da7(官方正确)
    SHA1: 18e30b07355576d0aa010501829764325b87a232
    SHA256: 645a111f466f19210303c0a40a947bb4d198fb38dfd2efa1c9e44c1e811ac820
    CRC32: fc87b37a
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmxBT21.8.1RTE32.txt (631 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx for Bluetooth® Test 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx for Bluetooth® Test supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.2, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.2.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    RFmx for Bluetooth® Test 21.8 includes the following new features:
    • Support for Initial Frequency Error Maximum result for LE packets in ModAcc measurement
    RFmx for Bluetooth® Test 21.3 includes the following new features:
    • Support for DEVM magnitude and phase error results in ModAcc measurement
    RFmx for Bluetooth® Test 20.0 includes the following new features:
    • Support to configure RFInstr properties in the context of signal configuration
    • Support for Demodulated Bit Trace in ModAcc measurement
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 21.8.1 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test
    Required Software
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
    Select Start » National Instruments » RFmx for Bluetooth® Test » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Bluetooth palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx Bluetooth Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx for Bluetooth® Test HelpHTML/Windows HelpContains primary help content for RFmx for Bluetooth® Test. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx for Bluetooth® Test
    • A complete reference for all RFmx for Bluetooth® Test programming functions and VIs
    RFmx for Bluetooth® Test 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx Bluetooth Examples.
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    The following are the behavior changes in RFmx for Bluetooth® Test 20.7 from RFmx for Bluetooth® Test 20.6.
    The following items are behavior changes in RFmx for Bluetooth® Test 19.1 from RFmx for Bluetooth® Test 19.0.
    • Obsoleted RFmxBT Analyze (IQ) API. Use RFmxBT Analyze (IQ, 1 Wfm) API instead
    • A warning is thrown if the measurement fails to detect start of the packet when you set the Burst Sync Type property to Preamble
    The following items are behavior changes in RFmx for Bluetooth® Test 19.0 from RFmx for Bluetooth® Test 3.0.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377890L-01
    GMT+8, 2025-6-1 06:32
