查看: 1290|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 21.3 x64Win10 32/64bitEng RFmx蓝牙测试NIRFmxBluetooth21.3
  • 签到天数: 3717 天
    连续签到: 44 天
     楼主| 发表于 2022-7-6 16:07:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
    RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
    发布日期:2021/10/22
    包含的版本:21.3完整版
    校验和
    文件大小: 1090283520 字节 (1.02 GB)
    修改日期: 2022-03-25 08:34
    MD5: 5ec738b2639dc16adecff96e75c20729
    SHA1: 16f5118e3108239d60b56c36df780a56e6bf5540
    SHA256: e87679af2bd819a3445633118384a438ce345ea3d08ad5be24346a4f9745eec4
    CRC32: 2a7b045d
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmxBT21.3.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Bluetooth 21.3 Readme
    October 2021
    This file contains important information about the RFmx Bluetooth, including system requirements, and installation instructions.
    • RFmx Bluetooth Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Bluetooth Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx Bluetooth supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.2, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.2.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    RFmx Bluetooth 21.3 includes the following new features:
    • Support for DEVM magnitude and phase error results in ModAcc measurement
    RFmx Bluetooth 20.0 includes the following new features:
    • Support to configure RFInstr properties in the context of signal configuration
    • Support for Demodulated Bit Trace in ModAcc measurement
    RFmx Bluetooth 19.1 includes the following new features:
    • Support for angle of departure transmitter tests on low energy physical layer signals
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx Bluetooth has the following requirements:
    RFmx Bluetooth 21.3 supports the following 64-bit operating systems:
    Note    RFmx Bluetooth no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Bluetooth 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Bluetooth 21.3 to an unsupported OS. Additionally, after installing RFmx Bluetooth 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Bluetooth supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Bluetooth. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Bluetooth
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    Required Software
    If you are using the RFmx Bluetooth .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Bluetooth .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Bluetooth installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Bluetooth. For more information on RFmx Bluetooth activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BTMX.Fx40.dll
    Select Start » National Instruments » RFmx Bluetooth » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx Bluetooth palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Bluetooth palette.
    Documentation for RFmx Bluetooth is located at Start » National Instruments » RFmx Bluetooth » RFmx Bluetooth Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx Bluetooth HelpHTML/Windows HelpContains primary help content for RFmx Bluetooth. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Bluetooth
    • A complete reference for all RFmx Bluetooth programming functions and VIs
    RFmx Bluetooth 21.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Bluetooth examples at Start » National Instruments » RFmx Bluetooth » RFmx Bluetooth Examples.
    The following are the behavior changes in RFmx Bluetooth 21.3 from RFmx Bluetooth 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    The following are the behavior changes in RFmx Bluetooth 20.7 from RFmx Bluetooth 20.6.
    The following items are behavior changes in RFmx Bluetooth 19.1 from RFmx Bluetooth 19.0.
    • Obsoleted RFmxBT Analyze (IQ) API. Use RFmxBT Analyze (IQ, 1 Wfm) API instead
    • A warning is thrown if the measurement fails to detect start of the packet when you set the Burst Sync Type property to Preamble
    The following items are behavior changes in RFmx Bluetooth 19.0 from RFmx Bluetooth 3.0.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377890H-01
    GMT+8, 2025-11-19 09:07
