查看: 1230|回复: 0
[RTE运行引擎] NI RFmx for Bluetooth Test 3.0 Runtime Win32Eng RFmx蓝牙测试NIRFmxBluetooth3.0运行版32位
    昨天 10:31
  • 签到天数: 3600 天
    连续签到: 8 天
     楼主| 发表于 2022-7-6 15:26:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx for Bluetooth Test为不同的蓝牙技术应用提供信号生成和分析功能。
    RFmx for Bluetooth Test是一款测量专用软件,旨在扩展NI RF仪器生成和分析常规蓝牙和低功率(LE)蓝牙信号的能力。该软件可以帮助您调制精度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助RFmx,您可通过交互式软件前面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的、未锁定的波形,并并通过性能优化的API加快自动测试。此外,您可以使用RFmx for Bluetooth Test,通过内置的直接测试模式(DTM)命令来控制被测设备(DUT)。Bluetooth 为Bluetooth SIG公司的注册商标。
    发布日期:2019/1/17
    包含的版本:3.0运行版
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    应用程序位数:32位
    校验和
    文件大小: 342036488 字节 (326.19 MB)
    修改日期: 2022-03-25 22:09
    MD5: def39626e5e580610c807a641e2de77b
    SHA1: cc7795893b3d4be5aaa8b8e0cfa0dcdca3a1352a
    SHA256: a773edf0c80ddd1c58f5e753297ffaee92457e502e1c4590308bbb27b4b7a273
    CRC32: 52c2e182
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmxBT3.0RTE32.txt (521 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFmx Bluetooth 3.0 Readme
    January 2019
    Thank you for using NI-RFmx Bluetooth. This file contains important information about NI-RFmx Bluetooth and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx Bluetooth supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.0, and the Bluetooth RF PHY test specifications RF.TS.5.0.2 and RF-PHY.TS.5.0.3.
    • Support for Low Energy Direction Finding physical layer confirming to Bluetooth Core Specification v5.1.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    Installation InstructionsCaution  Before you install this version of NI-RFmx Bluetooth, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx Bluetooth 3.0 supports the following operating systems:
    Note  NI-RFmx Bluetooth 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx Bluetooth. To add support for ADEs installed after installing NI-RFmx Bluetooth, modify your NI-RFmx Bluetooth installation or launch the NI-RFmx Bluetooth installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx Bluetooth does not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    Item
    Installed Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\BT\Examples
    Examples\LabVIEW \examples\RFmx\BT
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.BtMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx BT»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Documentation for NI-RFmx Bluetooth is located at Start»All Programs»National Instruments»NI-RFmx BT»NI-RFmx BT Documentation. The documentation set is composed of the following documents.
    s
    Document
    Format
    Description
    NI-RFmx Bluetooth HelpHTML/Windows HelpContains primary help content for NI-RFmx Bluetooth. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Bluetooth
    • A complete reference for all NI-RFmx Bluetooth programming functions and VIs
    NI-RFmx Bluetooth 3.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx Bluetooth palette VIs are available from the Functions»Measurement I/O»NI-RFmx»Bluetooth palette.
    You can access all the installed NI-RFmx Bluetooth examples at Start»All Programs»National Instruments»NI-RFmx BT»NI-RFmx BT Examples.
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2019 National Instruments. All rights reserved.
    377890A-01
    GMT+8, 2025-7-22 09:34
