查看: 1855|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 21.8.1 Runtime x64Win10 64bitENG运行版下载
    昨天 16:26
  • 签到天数: 3674 天
     楼主| 发表于 2022-6-17 10:29:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2022/4/30
    包含的版本:
    21.8.1运行版
    应用程序位数:
    64位
    语言:
    英文
    文件大小: 606607360 字节 (578.51 MB)
    修改日期: 2022-04-30 01:45
    MD5: af32a1b82c65c00d4c062ee8e76e2a37(官方正确)
    SHA1: 016e29e702cec7897acff5bb52a3706e5fa4ce38
    SHA256: 114a3b947fadbdfaf0a7206ea094858fb9c25acce48689d2e40a18758b069463
    CRC32: 8801a83f
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K21.8.1RTE64.txt (584 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 21.8.1 Readme
    April 2022
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    RFmx CDMA2k 21.3 includes the following new feature:
    RFmx CDMA2k 20.0 includes the following new features:
    RFmx CDMA2k 19.1 includes the following new feature:
    RFmx CDMA2k 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 21.8.1 to an unsupported OS. Additionally, after installing RFmx CDMA2k 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files
    Select Start » National Instruments » RFmx CDMA2k » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » NI-RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k » RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx CDMA2k
    • A complete reference for all RFmx CDMA2k programming functions and VIs
    RFmx CDMA2k 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k » RFmx CDMA2k Examples.
    The following are the behavior changes in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    375524V-01
    GMT+8, 2025-10-8 00:13
