查看: 1571|回复: 0
[NI驱动程序] NI-RFSG Playback Library 21.8 x64Win10 32/64bitEng NI-RFSG回放库21.8完整版下载
    12 小时前
  • 签到天数: 3559 天
    连续签到: 4 天
    发表于 2022-6-9 17:37:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期
    2022/4/19
    包含的版本
    21.8.0完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 463955968 字节 (442.46 MB)
    修改日期: 2022-06-09 15:43
    MD5: 56c54233c8ebf42107d3c45453ba5f22
    SHA1: 296c4a287f94fe2b2ee8d8ce088568580bae61f1
    SHA256: 30becfe5b577678c05b9c862a032f6f5a078e3c764a9355024dfb2c2ac28996e
    CRC32: 5b31d01f
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFSG PlayBack21.8.txt (563 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSG Playback Library 21.8 Readme
    April 2022
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    Installed Software
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 21.3 includes the following new features:
    NI-RFSG Playback Library 20.6 includes the following new features:
    • Support for PXIe-5832
    NI-RFSG Playback Library 20.0 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 21.8 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 21.8 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library
    LabVIEW2018, 2019 SP1, 2020 SP1, 2021
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG Playback Library HelpHTML/Windows HelpContains primary help content for NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions and VIs
    NI-RFSG Playback Library 21.8 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Examples.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    375556V-01
    GMT+8, 2025-6-6 20:20
