查看: 1373|回复: 0
[NI驱动程序] NI-SCOPE 21.0.1 x64Win10 32/64bitEng/Jpn NI示波器驱动程序SCOPE21.0.1
    12 小时前
  • 签到天数: 3559 天
    连续签到: 4 天
    发表于 2022-6-6 15:21:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    NI-SCOPE 21.0.1
    发布日期
    2022/5/10
    包含的版本
    21.0.1
    受支持的操作系统
    语言
    英文,日语
    程序位数
    32/64位
    校验和
    修改日期: 2022-05-10 04:53
    MD5: 19ae4237ce132d9f4f5de0707f154343(官方正确)
    SHA1: 6a9c3026129cef56bc25d163a52cbda7d3d97da4
    SHA256: a9f8fcba10f26b76fd7faa2c4b9f7eac086291ff405429227bfa23be4b7403d7
    CRC32: b0d7cd5b
    注册登录视觉论坛,购买附件查看下载地址
    NI-Scope21.0.1.txt (530 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SCOPE 21.0.1 Readme
    May 2022
    This file contains installation instructions and compatibility information for NI-SCOPE.
    • NI-SCOPE Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SCOPE Manuals: New features, behavior changes, and other documentation
    NI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples.
    NI-SCOPE 21.0.1 has the following requirements:
    • 1 GHz or faster 64-bit (x64) processor
    • 2 GB RAM (64-bit)
    • If you are running your application on an RT target, at least 128 MB of memory
    NI-SCOPE 21.0.1 supports the following operating systems:
    • NI Linux® Real-Time1
    1 This operating system is not supported for the following features:
    • Autopopulation of resource names in LabVIEW 2020 and earlier
    • Test panels as accessible from Measurement & Automation Explorer (MAX)
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022 may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    Note  In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 21.0.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-SCOPE
    LabVIEW2018, 2019, 2020, and 2021
    LabVIEW Real-Time Module12018, 2019, 2020, and 2021
    LabVIEW NXG5.1
    LabWindows™/CVI™2013 SP1 or later
    LabWindows/CVI Real-Time Module32013 SP1 or later
    1No support for the PXIe-5110/5111/5113, the PXIe-5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes.
    If you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to NI-SCOPE. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software.
    NI installs NI-SCOPE using NI Package Manager. If you do not already have NI software installed, NI-SCOPE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-SCOPE is available for download from ni.com/downloads/drivers. NI-SCOPE installs NI-DAQmx if it is not already installed or if an earlier version of NI-DAQmx is installed. NI-DAQmx support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQmx is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    • From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    • From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx
    • NI Hierarchical Waveform Storage
    • NI I/O Trace
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    The following table details the hardware models supported in NI-SCOPE 21.0.1.
    Hardware Device
    Supported Under Windows 10 (64-bit)1
    NI-DAQmx-Based Oscilloscopes
    PXI/PXIe/PCI-5105
    Yes
    PXI/PXIe/PCI-5114
    Yes
    PXI/PXIe/PCI-5122
    Yes
    PXI/PCI-5124
    Yes
    USB-5132/5133
    Yes
    PXI/PCI-5142
    Yes
    PXI/PCI-5152
    Yes
    PXI/PCI-5153
    Yes
    PXI/PCI-5154
    Yes
    PXIe-5160/5162
    Yes
    PXIe-5185/5186
    Yes
    PXIe-5622
    Yes
    PXI-5900
    Yes
    PXI/PCI-5922
    Yes
    SDI-Based Oscilloscopes
    PXIe-5110
    Yes
    PXIe-5111
    Yes
    PXIe-5113
    Yes
    516x Oscilloscopes
    PXIe-5163
    Yes
    PXIe-5164
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    PXIe-5171
    Yes
    PXIe-5172
    Yes
    1When you install NI-SCOPE 21.0 and later, InstrumentStudio is installed instead of the SCOPE soft front panel. Use InstrumentStudio to monitor and control your oscilloscope.
    Device-specific information about these modules is included in the NI High-Speed Digitizers Help.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
    • For help with InstrumentStudio, used to configure and monitor NI-SCOPE devices, refer to the InstrumentStudio help at ni.com.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start»Programs»National Instruments»NI-SCOPE»Examples.
    For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-SCOPE.
    LabVIEW NXG Hardware Support
    The following table details the hardware models supported in NI-SCOPE with LabVIEW NXG.
    Hardware Module
    PXI/PXIe/PCI-5105
    Yes
    PXI/PXIe/PCI-5114
    Yes
    PXI/PXIe/PCI-5122
    Yes
    PXI/PCI-5124
    Yes
    USB-5132/5133
    Yes
    PXI/PCI-5142
    Yes
    PXI/PCI-5152
    Yes
    PXI/PCI-5153
    Yes
    PXI/PCI-5154
    Yes
    PXIe-5160/5162
    Yes
    PXIe-5185/5186
    Yes
    PXIe-5622
    Yes
    PXI-5900
    Yes
    PXI/PCI-5922
    Yes
    PXIe-51101
    Yes
    PXIe-51111
    Yes
    PXIe-51131
    Yes
    516x Oscilloscopes
    PXIe-51631
    Yes
    PXIe-51641
    Yes
    517x Oscilloscopes
    PXIe-51701
    Yes
    PXIe-51711
    Yes
    PXIe-51721
    Yes
    1External calibration of this module is not supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-SCOPE no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 1999–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-6-6 20:28
