查看: 2061|回复: 0
[NI驱动程序] NI RF Signal Generators 21.8.0 x64Win10 32/64bitEng NI RF信号发生器NI-RFSG21.8.0
    发表于 2022-5-27 16:40:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    发行日期
    2022/04/17
    包含的版本
    21.8.0完整版
    受支持的操作系统
    程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 5532975104 字节 (5.15 GB)
    修改日期: 2022-04-18 10:17
    MD5: 0959dfe6a9f5136fc40ffcae00af4643(官方正确)
    SHA1: 99c3c311b8aa1afa69d478afc354c07f2a6eb837
    SHA256: 690222f3bd3ef9873a41d0cc7d86c3b5e2916511ece05f39ba4b0de87ca9dd58
    CRC32: c42d0da4
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSG21.8.0.txt (525 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 21.8 Readme
    April 2022
    This file contains installation instructions and compatibility information for NI-RFSG.
    • NI-RFSG Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 21.8 includes the following new feature:
    • Support for NI Linux® Real-Time
    NI-RFSG 21.5 includes the following new feature:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Upconverter Frequency Offset Mode, and Signal Bandwidth attributes
    NI-RFSG 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    NI-RFSG 20.7 includes the following new features:
    • Added new InstrumentStudio-based NI-RFSG Soft Front Panel with the ability to debug and monitor applications for the PXIe-5840/5841 and PXIe-5830/5831/5832
    • Added the ability to load waveforms from TDMS files into the device memory for the PXIe-5840/5841 and PXIe-5830/5831/5832
    • Added the ability to configure certain properties for a specific waveform on the PXIe-5840/5841 and PXIe-5830/5831/5832
    • 4 GB RAM*
    Note  NI-RFSG 21.8 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 21.8.
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2018 to current
    LabVIEW Real-Time Module2021
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    374769AH-01
    GMT+8, 2026-1-13 13:22
