查看: 1858|回复: 0
[RTE运行引擎] NI RFmx 21.8.1 Runtime x64Win10 64bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.8.1
    发表于 2022-5-27 12:01:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/4/30
    包含的版本
    21.8.1运行版
    受支持的操作系统
    应用程序位数
    64位
    语言
    English
    校验和
    文件大小: 1071869952 字节 (1022.21 MB)
    修改日期: 2022-04-30 09:46
    MD5: 19a0b743616142a76c9155704d36cfe4
    SHA1: 70912cbe29bbe5bf2cb72e25b9d1824f9e948e9d
    SHA256: eb489dba6334848a960252dc75a8c0716230c52e244962abc816dabd8695f6b0
    CRC32: e778b264
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFmx21.8.1RTE64.txt (590 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 21.8.1 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.8.1 to an unsupported OS. Additionally, after installing RFmx 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx 21.8.1 supports the following application software versions, including service packs.
    Versions Supported by RFmx
    LabWindows™/CVI™2015 or later
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377996K-01
    GMT+8, 2026-1-13 13:21
