查看: 1585|回复: 0
[NI软件产品] NI RFmx 21.8.1 Full x64Win10 32/64bitEng NI Wireless Test Standard Software完整版ni-rfmx-suite_21.8.1
    发表于 2022-5-27 11:59:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/4/30
    包含的版本
    21.8.1完整版
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    English
    校验和
    文件大小: 4237877248 字节 (3.95 GB)
    修改日期: 2022-04-30 09:46
    MD5: 53e9dbbeb33e9677e49be49b08c43621
    SHA1: 6af462e60dfb309a22c82de0954457f998639d09
    SHA256: 693b69fb20e3bb8c3eb2294ba6de2f63eccb87939a0e0315c91fbcf44276776e
    CRC32: 0bc8c682
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFmx21.8.1.txt (558 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx 21.8.1 Readme
    April 2022
    This file contains important information about the RFmx, including system requirements, and installation instructions.
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx has the following requirements:
    RFmx 21.8.1 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.8.1 to an unsupported OS. Additionally, after installing RFmx 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx 21.8.1 supports the following application software versions, including service packs.
    Versions Supported by RFmx
    LabWindows™/CVI™2015 or later
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377996K-01
    GMT+8, 2026-1-13 13:22
