查看: 1603|回复: 0
[RTE运行引擎] NI RFmx 21.8.0 Runtime x64Win10 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.8.0
    发表于 2022-5-27 11:56:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/4/19
    包含的版本
    21.8.0运行版
    受支持的操作系统
    应用程序位数
    32位
    语言
    English
    校验和
    文件大小: 749901824 字节 (715.16 MB)
    修改日期: 2022-04-20 08:28
    MD5: 334265f6c3a2cb9e06e529c7244cf196
    SHA1: bded29b0757790ea45bd53641e3b63464588f876
    SHA256: b29cebbccf472000315bba2befd7c202afc01b69afad1c75c9ff01b7309ffe67
    CRC32: 3881c580
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFmx21.8.0RTE32.txt (600 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (32-Bit) 21.8 Readme
    April 2022
    This file contains important information about the RFmx Runtime (32-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (32-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (32-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (32-Bit)
    • RFmx Demod Runtime (32-Bit)
    • RFmx WLAN Runtime (32-Bit)
    • RFmx for Bluetooth® Test Runtime (32-Bit)
    • RFmx NR Runtime (32-Bit)
    • RFmx LTE Runtime (32-Bit)
    • RFmx WCDMA Runtime (32-Bit)
    • RFmx TD-SCDMA Runtime (32-Bit)
    • RFmx EV-DO Runtime (32-Bit)
    • RFmx CDMA2k Runtime (32-Bit)
    • RFmx GSM Runtime (32-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (32-Bit) has the following requirements:
    RFmx Runtime (32-Bit) 21.8 supports the following 64-bit operating systems:
    Note RFmx Runtime (32-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (32-Bit) 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (32-Bit) 21.8 to an unsupported OS. Additionally, after installing RFmx Runtime (32-Bit) 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Download the RFmx Runtime (32-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2019–2022 National Instruments Corporation. All rights reserved.
    377997J-01
    GMT+8, 2026-1-13 13:21
