NI RFmx 21.8.0 Full x64Win10 32/64bitEng NI Wireless Test Standard Software完整版ni-rfmx-suite_21.8.0
RFmx
发布日期
2022/4/19
包含的版本
21.8.0完整版
受支持的操作系统
应用程序位数
32/64位
语言
English
校验和
文件大小: 2473338880 字节 (2.30 GB)
修改日期: 2022-04-20 08:28
MD5: 72750196b6add7bc6ef1747543f3a40c
SHA1: 4090199ac845c03540fc991700218305843403fe
SHA256: a0aecc491582db6af71c65471c4f48b57a934359ace80121c6c2d2cde3a3d6bc
CRC32: 8c7aad27
注册登录视觉论坛账号,购买附件查看下载地址
NI-RFmx21.8.0.txt
(558 Bytes, 下载次数: 0, 售价: 10 圆)
RFmx 21.8 ReadmeApril 2022 This file contains important information about the RFmx, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Legal Information
The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes. Application Software - RFmx Waveform Creator
- RFmx SpecAn
- RFmx Demod
- RFmx WLAN
- RFmx for Bluetooth® Test
- RFmx NR
- RFmx LTE
- RFmx WCDMA
- RFmx TD-SCDMA
- RFmx EV-DO
- RFmx CDMA2k
- RFmx GSM
Drivers System RequirementsRFmx has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Windows 10, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx 21.8 supports the following 64-bit operating systems: - Windows 10
- Windows Server 2019
- Windows Server 2016
Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.8 to an unsupported OS. Additionally, after installing RFmx 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx 21.8 supports the following application software versions, including service packs. Application Software | Versions Supported by RFmx | | LabVIEW | 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021 SP1 f1 patch | | LabWindows™/CVI™ | 2015 or later | Installation InstructionsDownload the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Legal InformationCopyright © 2019–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 377996J-01 |
