查看: 2010|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 21.8 x64Win10 32/64bitEng NI数字向量仪器驱动程序21.8下载
    发表于 2022-5-23 15:41:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Digital Pattern Driver为用户使用NI PXI数字pattern仪器提供支持。
    NI-Digital Pattern Driver是用于配置和控制数字向量仪器的NI仪器驱动程序。该驱动程序可让您在NI-Digital Pattern Driver LabVIEW或.NET API中,调用使用数字向量编辑器创建的引脚和通道图、规格、电平、时序、向量、波形文件。NI-Digital Pattern Driver还包含高级和底层实用工具和示例,可帮助您轻松创建应用程序。
    从NI-Digital Pattern Driver 21.0版本开始,仅支持64位的Win10/WinServer 2016/WinServer 2019系统,但是仍然支持64位系统下的32位LabVIEW。
    发布日期
    2024/4/17
    包含的版本
    21.8.0
    受支持的操作系统
    应用程序位数
    32/64位
    语言
    英文
    校验和
    文件大小: 1762158592 字节 (1.64 GB)
    修改日期: 2022-04-18 10:30
    MD5: 4da6b1dd159fac3fb75b6ecd81280957(官方正确)
    SHA1: 0937b0111b0c54d61ca25e6c85ea4cbdf6c2ee79
    SHA256: 84437b0b23c834905ca1a6469bea877841457c4b34471616a64e63e274d6545d
    CRC32: 0ce7180e
    注册登录视觉论坛,购买附件查看下载地址
    NI-DigitalPD21.8.txt (554 Bytes, 下载次数: 0, 售价: 10 圆)
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor 21.8 Readme
    April 2022
    This file contains installation instructions and compatibility information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor.
    • NI-Digital Pattern Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Digital Pattern Driver Manuals: New features, behavior changes, and other documentation
    Accessing Documentation
    Use the Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    System RequirementsMinimum System Requirements
    • RAM—4 GB
    • A screen resolution of 1024 x 768
    Recommended System
    • RAM—8 GB
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
    • Windows 10 (64-bit)
    Note:  Refer to your ADE documentation for more information about creating a runtime deployment:
    • LabVIEW - "Building and Distributing Applications"
    • NI TestStand - "Deploying TestStand Systems"
    • Microsoft Visual Studio - "Deploying the .NET Framework and Applications"
    Note:  The Digital Pattern Editor does not support Guest user accounts on Windows.
    Note:  NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/info and enter the Info Code mshotfix for more information about Microsoft Hotfix 2588507.
    Install Application Development Environments (ADEs), such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
    NI-Digital Pattern Driver and Digital Pattern Editor 21.8 support the following ADE versions:
    Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 21.8
    LabVIEW2018, 2019, 2020, and 2021
    NI TestStand2016 and later (64-bit)
    NI TestStand Semiconductor Module™2016 and later (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)
    Note:  You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note:  You must install the NI-Sync driver to access NI-Sync-related functionality.
    If you are using the NI-Digital .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    Download the NI-Digital Pattern Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI-Digital Pattern Driver and Digital Pattern Editor. For more information on NI-Digital Pattern Driver and Digital Pattern Editor activation, refer to NI Software Activation.
    Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following location:
    • LabVIEW 2017 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    .NET Class Library
    You can use the NI-Digital Pattern .NET class library by adding a reference to NationalInstruments.ModularInstruments.NIDigital.Fx40 or NationalInstruments.ModularInstruments.NIDigital.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    Refer to the What's New topics in the Digital Pattern Help for detailed information about new features and other changes in the NI-Digital Pattern Driver and Digital Pattern Editor. Refer to the What's New topics for previous versions of the NI-Digital Pattern Driver and Digital Pattern Editor in the Digital Pattern Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Documentation for the Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor is available from the Start menu by navigating to NI Digital Pattern Documentation in the National Instruments folder. The installed documentation set is composed of the following documents:
    • Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor Readme (this file)—Contains information about the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor, including where to go for support, supported hardware, system requirements, operating systems, known issues, and legal notices.
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    Digital Pattern Instrument manuals are available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Digital Pattern Instrument manuals include the following documents:
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6570 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    • PXIe-6571 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6571.
    Use the getting started examples, located by default in the \National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    In the Welcome window of the Digital Pattern Editor, click Examples or click the Learning tab to launch the Learning window, which includes examples of common usages of digital patterns.
    NI-Digital Pattern Driver Examples
    Use the NI-Digital Pattern Driver example programs to learn more about how to use the NI-Digital Pattern Driver software to configure and control digital pattern instruments.
    LabVIEW Examples
    Use the NI Example Finder to locate LabVIEW examples. In LabVIEW, select Help»Find Examples to launch the NI Example Finder.
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the \National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the \National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    NI software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2015–2022 National Instruments Corporation. All rights reserved.
    376615M-01
    GMT+8, 2026-1-13 13:21
