查看: 1765|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 21.5 Driver x64Win10 32bitEng NI-DNet工业通信软件驱动程序21.5下载
    发表于 2022-5-23 12:39:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    Win32Eng
    21.5
    发布日期
    2022/1/27
    包含的版本
    21.5.0完整版
    受支持的操作系统
    语言
    English
    应用程序位数
    32/64位
    校验和
    文件大小: 1107568640 字节 (1.03 GB)
    修改日期: 2022-01-28 07:01
    MD5: 8ae8d86de90cbff22b24eec6fe77f17c
    SHA1: c691b53b6d3ba4ad8107e9dbdddc41237044eaf4
    SHA256: 5e8234fa38547db599bc37f70872508efc32bcbbf5b05d1418bfc8ca84e61fec
    CRC32: a2902487
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-DNET21.5.txt (531 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet 21.5 Readme
    January 2022
    This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time environment, including supported application software and hardware, installation instructions, and new features.
    • NI-Industrial Communications for DeviceNet Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Industrial Communications for DeviceNet Manuals: New features, behavior changes, and other documentation
    Caution   The NI-Industrial Communications for DeviceNet 18.0 software or later requires the NI-9882 module with the updated firmware. When you upgrade your software to the 18.0 version or later, check the software version of the media shipped with your NI-9882 module. If the version is not 18.0 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for DeviceNet 18.0 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete the following task to update the firmware.
    • Double-click Firmware_Update_Instructions.html in the \NI-IndCom for DeviceNet directory and follow the instructions to use a LabVIEW example project to update the firmware.
    Compatibility with NI-DNET 1.x
    The NI-Industrial Communications for DeviceNet software provides the DeviceNet driver and VIs for you to configure and control DeviceNet devices on a DeviceNet network and to communicate with FPGA targets.
    NI-Industrial Communications for DeviceNet supports the following operating systems:
    Note    NI-Industrial Communications for DeviceNet no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-Industrial Communications for DeviceNet 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for DeviceNet 21.5 to an unsupported OS. Additionally, after installing NI-Industrial Communications for DeviceNet 21.5 on a supported OS computer, you cannot create any installers containing any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio for an unsupported OS computer.
    Refer to KB 6CCA8MEG, Supported Hardware and Software for NI-Industrial Communications for DeviceNet, for a complete list of NI hardware and software supported by each version of the NI-Industrial Communications for DeviceNet.
    The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, you may connect 64 devices to the network.
    Caution  The NI-Industrial Communications for DeviceNet software does not support the previous generation of the DeviceNet hardware products such as NI PCI-DNET, NI PCMCIA-DNET, and NI PXI-8461/D. Those products require an NI-DNET 1.x driver.
    Download the NI-Industrial Communications for DeviceNet installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installing the Software on the RT Target
    Complete the following steps to install the NI-Industrial Communications for DeviceNet software on the RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand the RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select the Custom software installation option.
    • Select the NI-IndCom for DeviceNet item in the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    New FeaturesDeviceNet 21.5
    • Added support for LabVIEW 2021 (32-bit) and LabVIEW 2021 Real-Time Module.
    • Added support for PXI and PXIe controllers with NI Linux RealTime through .ipk installation
    DeviceNet 20.0
    • Added support for LabVIEW 2020 (32-bit) and LabVIEW 2020 Real-Time Module.
    DeviceNet 19.0
    • Added support for LabVIEW 2019 (32-bit) and LabVIEW 2019 Real-Time Module.
    DeviceNet 18.0
    • Added support for LabVIEW 2018 (32-bit) and LabVIEW 2018 Real-Time Module.
    • Removed support for FPGA VIs.
    • Added support for cRIO-904x/905x.
    • Updated the firmware upgrade tool for NI 9882.
    Refer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet in LabVIEW, for information about using the NI-Industrial Communications for DeviceNet software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two products can be installed on the same system side by side. DeviceNet 2.1 or later provides NI-DNET 1.x compatible VIs, so the application using NI-DNET 1.x VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    375166J-01
    GMT+8, 2026-1-13 13:22
