查看: 2074|回复: 0
[NI软件产品] NI Switch Executive 1.0 Eval and Patch Win32Eng 美国国家仪器开关管理软件1.0评估版及补丁下载
    发表于 2022-5-15 23:52:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Switch Executive是一款开关管理与路由应用软件,能够加速开发过程、简化对复杂开关系统的维护。
    Switch Executive提供交互式配置和自动路由功能,使开关系统的设计变得更加容易。您可以为开关模块、外部连接和信号路由分配别名,从而简化系统的文档,以便未来进行修改。使用Switch Executive开发的测试代码可以复用于LabVIEW、LabWindows/CVI、Measurement Studio和TestStand环境。
    文件大小: 528356945 字节 (503.88 MB)
    修改日期: 2021-09-14 23:31
    MD5: f29444dde041492ae0f35ea37d90588f
    SHA1: fcfb0d944a9de0766c28cc7d71aa455152ed3325
    SHA256: 7f0e1725cafa27ab6370f2dffef97ad8ba4dcc440cef60540f44b172c8467a17
    CRC32: 45e0d21e
    百度网盘下载地址和NI官方下载地址:
    请注册登录视觉论坛会员,购买附件查看
    Switch Executive1.0.txt (590 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Switch Executive Readme File
    Trademarks: CVI, LabVIEW, National Instruments, ni.com, PXI, and SCXI are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    Thank you for using National Instruments Switch Executive.
    This particular installation of Switch Executive installed the above components. NI components also install Microsoft Internet Explorer 5.0, unless the same or better version is not already present on the system.
    Uninstalling NI Switch Executive
    For Windows 2000/NT/Me/9x, complete the following:
    • Open the Control Panel from the Start\Settings\Control Panel Menu and select Add\Remove Programs.
    • Select NI Switch Executive from the list provided and click Add\Remove.
    • Repeat for other applications you want to remove.
    Examples
    \Examples\SwitchExecutive\
    TestStand
    C/C++
    \Examples\VisualBasic\
    Using NI Switch Executive
    To view the above listed documents, you will need Adobe Acrobat Reader. Go to Adobe's web site to download Acrobat Reader. http://www.adobe.com.
    Known IssuesniSE_OpenSession and niSE Open Session.vi Memory Leak
    The LabVIEW VI "niSE Get Ivi Device Session.vi" leaks a small amount of memory each time it is called. The memory will be freed when LabVIEW exits. Try to avoid calling this function multiple times if it can be avoided.
    Instrument Drivers
    If you install NI Switch Executive without having previously installed NI-SWITCH, it is possible that the NI-SWITCH VI's might not get installed for LabVIEW. To workaround this problem, install NI-Switch from the CD that came with your hardware before installing NI Switch Executive.
    "DLL Not Found" - Microsoft Visual Basic
    If you are using the SCXI-1127 in multiplexer mode, there are a few anomalies exposed by NI Switch Executive. First, the SCXI-1127 supports different wire modes (1, 2, or 4 wires) as configured through NI-DAQ. Through NI Switch Executive, however, you may only use it with 2 wire channels. Second, the list of channels retrieved from the instrument driver includes all of the channel names as though it was configured as a 1 wire switch. Because of this, half of the channels may appear valid in NI Switch Executive but actually are not. Consult the SCXI-1127 hardware reference manual and NI-SWITCH user manual for a list of which channels are valid 2 wire channels. In NI Switch Executive you will need to ignore those channels which are not valid. This behavior will be fixed with a future NI-SWITCH release.
    Installation failure on Windows 95 and NT
    The IVI configuration of an IVI switch is read at the time that the switch is added to the NI Switch Executive Virtual Device. If changes are made to the IVI configuration, such as creating virtual channels or changing default setup to make some channels come up as source or configuration channels, those changes will not automatically be reflected in NI Switch Executive. To get NI Switch Executive to recognize the change you must remove the IVI switch from the virtual device and then re-add it. The preferred manner for modifying source and configuration channel attributes is via the Channels panel in Measurement & Automation Explorer. Doing so will avoid such hassles.
    Documentation Errata
    The online help for NI Switch Executive is the most complete and up to date source for product information. There were some minor documentation issues found in some of the printed materials after they returned from the printer. That errata is documented below.
    • On pages 4 and 5 of the Quick Reference Guide, the Note section should read:
      • Note: The channel on either end of the bracketed list must not be:
        • Marked as a source channel (one or the other is valid)
        • A configuration channel
      • Note: Any channel within a route specification string that is not an endpoint must either be a configuration channel or must be hardwired to an endpoint.
    • On page 6 of the Quick Reference Guide, some error codes are not listed. See the online help for a complete list.
    GMT+8, 2026-1-13 13:22
