查看: 2400|回复: 0
[NI软件产品] NI Lookout 6.6 Server Win32Eng NI Lookout服务器6.6版
    发表于 2022-5-13 22:20:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Lookout服务器
    Lookout Server支持基于Web的工业测量和自动化功能,大幅减少了开发工作量。
    Lookout Server是一款应用软件,提供基于Web的功能,如多客户多服务器网络、Web监控和控制、OPC服务器和客户端、事件驱动处理、分布式日志记录和分布式报警。
    Lookout客户端
    Lookout Client可为要求苛刻的制造和过程控制应用提供直观的控制。
    Lookout Client是基于Web的人机界面/监控和数据采集(HMI/SCADA)系统软件。它具有网络监测和控制以及分布式警报、事件和数据记录等功能。Lookout Client采用基于对象的架构,并支持事件驱动的处理。
    Lookout6.6CD1(Server)
    文件大小: 472986720 字节 (451.08 MB)
    修改日期: 2011-11-17 12:00
    MD5: de1714fc2f143577b7e7d5d64abcfcbe(重复一致)
    SHA1: 4a97493b23a02ab7d89e1d4da15fce741365f967
    SHA256: cc83f6fdaa90c2a3db1af1a6a3c6da21022449537b502af03e86404a0ef59d73
    CRC32: 82b67d2e
    注册登录视觉论坛账号,购买附件查看下载地址
    Lookout6.6Server.txt (542 Bytes, 下载次数: 0, 售价: 10 圆)
    Lookout6.6Patch
    文件大小: 29078304 字节 (27.73 MB)
    修改日期: 2013-05-20 22:36
    MD5: 3edcd2f6a54094c9c2abc23174df3ddd(官方正确)
    SHA1: 58ac430a327051ce16870b0aa2b44c136e2091a0
    SHA256: d5ffbdb55d63e706173f68d906ca490b6fe00cfa395d970bf74856c6796a6e84
    CRC32: ffee8d0b
    Lookout6.6Server Patch.txt (582 Bytes, 下载次数: 0, 售价: 1 圆)
    Lookout 6.6 Readme
    June 2011
    This file contains information about Lookout 6.6, including supported platforms, installation instructions, and a list of new features and changes.
    Supported Platforms
    Licensing
    Features and Changes
    Upgrade Notes
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    National Instruments Lookout is a human machine interface (HMI) and supervisory control and data acquisition (SCADA) software system for industrial automation. Lookout runs under Windows and communicates with field I/O through control hardware. Lookout can support the following applications:
    • Continuous process monitoring and supervisory control
    • Discrete manufacturing
    • Batch applications
    • Remote telemetry systems
    Supported Platforms
    Lookout supports the following operating systems:
    • Windows 7
    • Windows Vista
    • Windows XP Service Pack 2 or later
    Lookout does not support Windows Me/2000/9x/NT or the Windows Server non-R2 editions. Refer to the Lookout Release Notes for a complete list of system requirements.
    Note: National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the Info Code windows7.
    Refer to the Lookout Release Notes for more information about installing Lookout. This section describes additional installation considerations.
    The Lookout software requires Microsoft SQL Server 2005 Express Edition (SQL Express). This component is installed by default when you install Lookout. During the installation process, the Lookout installer creates an instance of SQL Express named CITADEL. To prevent unauthorized access to SQL Express, the installer also generates a password for the SQL Express administrator sa. The default password is the computer ID. Complete the following steps to find the computer ID using NI License Manager.
    • Launch NI License Manager by selecting Start»All Programs»National Instruments»NI License Manager.
    • Click the Display Computer Information button in the toolbar.
    The Lookout installer enables a mixed security mode on existing SQL Servers. If the target computer does not have an SQL Server installed, the Lookout installer installs SQL Express in the mixed security mode.
    Use the following command line prompt to change the default password for the sa user:
    Sqlcmd -S"localhost\CITADEL" -U"sa" -P"COMPUTER_ID" -Q"sp_password 'COMPUTER_ID', 'NEW_PASSWORD', 'sa'"
    If the mixed security mode is not acceptable, change both the SQL Express and Citadel login modes. You must set the registry DWORD values HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer\MSSQLServer\LoginMode and HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Citadel\5.0\IntegratedSecurity to 1.
    National Instruments recommends you to change the login mode immediately after you install Lookout. Otherwise, you must relink all existing Citadel databases. Restart the SQL Express and Citadel services in order for changes to take effect. If you use integrated NT security, you might need to configure the server machine and all clients explicitly.
    Note: Lookout 6.0.2 and earlier use Microsoft SQL Server 2000 Desktop Engine (MSDE 2000), not SQL Express. If you upgrade Lookout 6.0.2 or earlier to Lookout 6.6, any existing databases continue to use MSDE 2000 for alarm logging, but new databases you create use SQL Express. If you detach an existing database from Lookout and then reattach the database, Lookout migrates the database to SQL Express.
    You might want to uninstall MSDE 2000 after installing Lookout 6.6. Complete the following steps to uninstall MSDE 2000.
    • Exit Lookout if Lookout is running.
    • Open NI Measurement & Automation Explorer (MAX) and select My System»Historical Data»Citadel 5 Universe from the Configuration tree.
    • On the Databases page, detach all databases from the local computer.
    • Open the Windows Control Panel and uninstall MSDE 2000.
    • Restart the computer.
    • Open MAX and reattach all databases.
    Licensing
    Lookout relies on licensing activation. You must activate a valid Lookout license before you can run Lookout. To activate Lookout, use the serial number you received as part of your installation package.
    Refer to the Lookout Release Notes for more information about licensing in Lookout.
    Lookout 6.6 incorporates the following new features and changes:
    Supporting Multiple Windows
    Lookout supports running multiple processes in different Lookout windows. Each Lookout window has the same alarm window and menu options. You can open multiple Lookout windows by creating multiple processes.
    Supporting Full Screen
    Lookout supports developing and running applications in full screen.
    Supporting Enabling or Disabling Control Panel Buttons Programmatically
    Lookout provides a new panel data member enablerestoreoptions to help you enable or disable the Minimize, Maximize, Restore Down, Restore Up, and Close buttons programmatically on the control panels.
    Supporting Auto-Saving Changes
    Lookout can help you recover files from crashes or power outage, which gives you extra protection on file safety. Lookout automatically saves your changes in the following situations:
    • Auto-save your changes when you switch Lookout from edit mode to run mode.
    • Auto-save your changes at regular intervals in edit mode. The default interval is 5 minutes. You can specify the interval from 1 minute to 1,440 minutes.
    Upgrade Notes
    NI OPC Servers is upgraded from 2010 to 2011. In Lookout 6.6, if you want to use NI OPC Servers 2011 to run applications built in NI OPC Servers 2010 or earlier, you need to complete the following steps:
    • Launch NI OPC Servers Configuration by selecting Start»All Programs»National Instruments»NI OPC Servers 2011»NI OPC Servers Configuration. Select File»Open from the menu bar to open the NI OPC Servers project file (.opt) built in NI OPC Servers 2010 or earlier.
    • In Lookout 6.6, select File»Open from the menu bar to open the Lookout source code file (.lks) compiled by Lookout 6.5 or earlier.
    • Switch to edit mode and select Object»Object Explorer.
    • In the Object Explorer dialog box that appears, expand your process tree and show your OPC client objects. Right-click the OPC client object you want to use and select Properties from the shortcut menu.
    • In the Revise OPC Client dialog box that appears, switch to National Instruments.NIOPCServers.V5 from the Server Name pull-down menu.
    • Click OK.
    Tip: National Instruments recommends that you save the Lookout process file (.l4p) after completing the previous steps for easier access later. If you do not save this file, you need to complete the previous steps again the next time.
    Refer to the NI OPC Servers Help, available by selecting Start»All Programs»National Instruments»NI OPC Servers 2011»NI OPC Servers Help, for more information about using the NI OPC Servers application.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in Lookout.
    The following table contains the IDs and issues of a subset of fixed bugs in Lookout 6.6. This table is not an exhaustive list of fixed bugs in Lookout 6.6. If you have a CAR ID, you can search this list to validate the bug that has been fixed.
    89017
    Lookout cannot read correct value from FromWhen and ToWhen data members of the CitadelControl object after its property was revised.
    119423
    Symbolic link cannot be deleted once you created a display using symbolic link members.
    281211
    Lookout crashes when you create connection on Logon and/or Logoff in the Edit Connection.
    282153
    Lookout allows you to save a process when your security level is no less than 9, but when your security level is lower than 9, you also can save an unsaved process by reopening or closing the process.
    292698
    You cannot use MAX to create a Citadel 4 database.
    298725
    Lookout needs a help file for the DeleteTrace object.
    302030
    Lookout crashes when the name of the DataTable data member alias is too long.
    Using Microsoft Silverlight
    © 2011 National Instruments Corporation. All rights reserved.
    In regards to components that use Citadel 5, the following copyright applies. Copyright © 1994 Hewlett-Packard Company. Permission to use, copy, modify, distribute and sell this software and its documentation for any purpose is hereby granted without fee, provided that the above copyright notice appears in all copies and that both that copyright notice and this permission notice appear in supporting documentation. Hewlett-Packard Company makes no representations about the suitability of this software for any purpose. It is provided "as is" without express or implied warranty.
    National Instruments, NI, ni.com, the National Instruments corporate logo, the Eagle logo, LabVIEW, Citadel, and Lookout are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-1-13 13:22
