查看: 1795|回复: 0
[NI驱动程序] NI-FGEN 2.4.5 Driver for LV 8.2 Win32Eng NI-FGEN波形发生器仪器驱动程序2.4.5
    发表于 2022-5-13 20:08:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-FGEN
    NI-FGEN为使用NI波形发生器产品的客户提供支持。
    NI-FGEN是一款NI仪器驱动程序,可实现复杂测量解决方案所需的频率扫描和跳频、波形链接和循环以及频移键控(FSK)调制。 NI-FGEN驱动程序可兼容可互换虚拟仪器(IVI),它具有一系列操作和属性,可以执行波形或信号发生器的功能,并提供交互式软件前面板和示例。
    Win32Eng
    2.4.5
    文件大小: 812102685 字节 (774.48 MB)
    修改日期: 2007-03-28 06:30
    MD5: efdabcce1d0c2eb4f695b76b7315230b
    SHA1: 8bd7b668f21a84ec734ecb11e147c231ee228241
    SHA256: c68296530624f19f51610f636b9343be99d6ee26dc2086f96bc1118e87d31734
    CRC32: 09fa455b
    注册登录视觉论坛账号,购买附件查看下载地址
    FGEN 2.4.5Win.txt (518 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-FGEN™ Instrument Driver Readme
    Version 2.4.5
    February 2007
    Thank you for using NI-FGEN for Windows Vista/XP/2000.
    This file contains important information regarding NI-FGEN and is organized into the following sections:
    • New Features in Version 2.4.5
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • The FGEN Soft Front Panel
    • Uninstalling/Modifying NI-FGEN
    • Obsolete VIs and Functions
    • Changes by Release
    • Support for Windows Vista. For more information about Microsoft Windows Vista and NI products, refer to ni.com/vista.
    New Features in Version 2.4.1
    • Added LabVIEW 8.2 support
    • Support for the NI PXI/PCI-5402 Function Generator
    • Support for the NI PXI/PCI-5406 Function Generator
    • Streaming
    • Direct DMA
    • Script mode
    • Frequency List mode support for the NI 5402/5406/5441
    • New trigger and event routing features: new VIs, functions, trigger types, and event types
    • Data marker events
    • Marker support added to arbitrary waveform mode
    For information on transitioning an application currently using an NI 5401 to one using an NI 5402 or NI 5406, refer to KnowledgeBase document 3V87TOOL at ni.com/kb.
    NI-FGEN is compliant with the IviFgen Class Specification. For more information about this IVI Foundation class specification, visit www.ivifoundation.org.
    The following table shows which hardware products are supported in this release under particular operating systems.
    Hardware ProductSupported Under
    Windows XP/2000
    Supported Under
    Windows Vista1
    NI PXI/PCI-5401 Function Generator
    X
    NI PXI-5404 Frequency Generator
    √2
    NI PXI/PCI-5411 Arbitrary Waveform Generator
    X
    NI PXI/PCI-5412 Arbitrary Waveform Generator
    NI PXI/PCI-5421 Arbitrary Waveform Generator
    NI PXI-5422 Arbitrary Waveform Generator
    NI PXI/PCI-5431 Video Signal Generator
    X
    NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing
    1 Notice that MXI-4 is supported on Windows Vista/XP/2000, but MXI-3 is supported on only Windows XP/2000.
    2 Windows Vista support for the NI 5404 does not include support for external calibration. External calibration for the NI 5404 should be performed on Windows XP or Windows 2000.
    Device-specific information about these signal generators is included in the NI Signal Generators Help file.
    System RequirementsMinimal System
    • Processor—Pentium III 600 MHz or equivalent
    • RAM—128 MB
    • A screen resolution of 800 × 600 with 256 colors
    • Windows Vista (32-bit version), Windows Vista x64 Edition (64-bit version), Windows XP, or Windows 2000, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024 × 768
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    Application Development Software
    • NI LabVIEW 7.1, 8.0, 8.20
    • NI LabVIEW Real-Time Module 7.1, 8.0, 8.20 (NI 5402/5404/5406/5412/5421/5422/5441 only)
    • LabWindows ™ /CVI ™ 7.0, 7.1, 8.0, 8.1
    • Measurement Studio 6.0, 7.0, 7.1, 8.0, 8.1
    • Microsoft Visual C++ (MSVC) 6.0, 7.1, 8.0
    • Microsoft Visual Basic 6.0
    This particular installation of NI-FGEN installs the following files:
    Software
    FilesInstallation Location on Windows XP/2000
    and Windows Vista (32-bit version)
    Windows Vista x64
    VIsProgram Files\National Instruments\
    \instr.lib\niFgen
    Program Files (x86)\ National Instruments\\instr.lib\niFgen
    LabVIEW ExamplesProgram Files\National Instruments\
    \examples\instr\niFgen
    Program Files (x86)\ National Instruments\\examples\instr\niFgen
    C ExamplesProgram Files\IVI\Drivers\niFgen\Examples\cProgram Files (x86)\IVI\Drivers\niFgen\Examples\c
    CVI ExamplesProgram Files\National Instruments\
    \samples\niFgen
    Program Files (x86)\ National Instruments\\samples\niFgen
    NI-FGEN Function Tree for CVIVXIPnP\\niFgenVXIPnP (x86)\\niFgen
    Documentation FilesProgram Files\IVI\Drivers\niFgen\DocumentationProgram Files (x86)\IVI\Drivers\niFgen\Documentation
    FGEN Soft Front Panel (SFP) FilesProgram Files\IVI\Drivers\niFgen\Program Files (x86)\IVI\Drivers\niFgen\
    FPGA Files for
    NI-FGEN and Associated Hardware
    \fpgafiles\
    Program Files (x86)\National Instruments\
    \fpgafiles\
    FGEN SFP Example WaveformsProgram Files\IVI\Drivers\niFgen\Examples\Waveforms\Program Files (x86)\IVI\Drivers\niFgen\Examples\Waveforms\
    Visual Basic ExamplesProgram Files\National Instruments\
    \VB\Samples\niFgen\
    \VB\Samples\niFgen\
    The following files are installed in the system directory of Windows systems:
    • niffofu.dll
    • niFgenDAQ_32.dll
    • niFgenDMF.dll
    • niArbCal.dll
    • nigplu.dll
    • nidcmpu.dll
    • nisrcdu.dll
    • nisrceu.dll
    • nihdf.dll (installed with FGEN SFP)
    • NIHDF_2_LV.dll (installed with FGEN SFP)
    • nifirgenu.dll
    • nifirgenInterfaceu.dll
    • nifirgenanlys.dll
    The following files are installed in the drivers directory of Windows systems:
    • nigplk.dll
    • nigplkl.sys
    • nisrcdk.dll
    • nisrcdkl.sys
    • nisrcdkw.sys
    The following documents are installed with NI-FGEN and are available from Start» Programs»National Instruments»NI-FGEN»Documentation:
    • NI Signal Generators Getting Started Guide
    • NI Signal Generators Help
    • Specifications
    • Calibration Procedures
    Note  To view many of these documents, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Visit ni.com/manuals to find the latest versions of product documentation.
    The FGEN Soft Front Panel (SFP)
    The FGEN Soft Front Panel (SFP) is accessible from Start» Programs»National Instruments»NI-FGEN.
    You can find example waveform and function files in the Program Files\IVI\Drivers\niFgen\Examples\Waveforms\ directory (Program Files (x86)\IVI\Drivers\niFgen\Examples\Waveforms\ directory on the 64-bit version of Windows Vista). Refer to Waveform description.txt within the Waveforms folder for an explanation of the provided waveforms.
    For Windows XP/2000, complete the following steps:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-FGEN 2.4.5 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    As part of the NI-FGEN 2.4.5 installation, the following list of software was installed. To completely remove NI-FGEN 2.4.5 from your system, you must remove all of these packages in addition to NI-FGEN.
    • NI Hierarchical Waveform Storage 1.4.4
    • NI IVI Compliance Package 3.0
    • NI LabVIEW Run-Time Engine 7.1.1
    • NI Measurement & Automation Explorer 4.2
    • Traditional NI-DAQ 7.4.4 (Windows XP/2000 only)
    • NI-DAQmx 8.5
    • NI-VISA 4.1
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • Windows Vista does not support Traditional DAQ (Legacy) devices. Traditional DAQ devices include the NI PXI/PCI-5401, NI PXI/PCI-5411, and NI PXI/PCI-5431. Simulating these devices is also unsupported on Windows Vista, both in NI-FGEN and the FGEN Soft Front Panel. Choosing to simulate a device that is not supported on your operating system will result in indeterminate behavior.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-FGEN operation in progress. In the case of a PXI-5404 operation in progress or open PXI-5404 session, these modes can crash the system. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    The following VIs are obsolete as of NI-FGEN 2.4 and have been moved to niFgenObsolete_2_4.llb.
    • niFgen Configure Ref Clock Frequency VI
    • niFgen Configure Ref Clock Source VI
    • niFgen Configure Trigger VI
    • niFgen Configure Update Clock Source VI
    • niFgen Send Software Trigger VI
    The following functions are obsolete as of NI-FGEN 2.4 and have been moved to niFgenObsolete.h.
    • niFgen_ConfigureReferenceClockFrequency
    • niFgen_ConfigureReferenceClockSource
    • niFgen_ConfigureTriggerSource
    • niFgen_ConfigureUpdateClockSource
    • niFgen_SendSoftwareTrigger
    The niFgen_ComplexF64 type is obsolete and moved to niFgenObsolete.h.
    Changes by Release
    This section describes the changes in NI-FGEN 2.4.5 from NI-FGEN 2.4.1.
    • Added support for Windows Vista
    This section describes the changes in NI-FGEN 2.4.1 from NI-FGEN 2.4.
    This section describes the changes in NI-FGEN 2.4 from NI-FGEN 2.3.
    • Added features described in New Features in Version 2.4
    • Made a number of VIs and functions obsolete as described in Obsolete VIs and Functions
    • Added an NIComplexNumber typedef, which replaces niFgen_ComplexF64
    • Added the following VIs/functions, properties/attributes, and values:
      [tr][/tr]
      AttributesNIFGEN_ATTR_STREAMING_WAVEFORM_HANDLE
      NIFGEN_ATTR_ARB_MARKER_POSITION
      NIFGEN_ATTR_ARB_REPEAT_COUNT
      NIFGEN_ATTR_STREAMING_SPACE_AVAILABLE_IN_WAVEFORM
      NIFGEN_ATTR_SAMPLE_CLOCK_SOURCE
      NIFGEN_ATTR_REFERENCE_CLOCK_SOURCE
      NIFGEN_ATTR_FLATNESS_CORRECTION_ENABLED
      NIFGEN_ATTR_SCRIPT_TO_GENERATE
      NIFGEN_ATTR_MARKER_EVENTS_COUNT
      NIFGEN_ATTR_SCRIPT_TRIGGERS_COUNT
      NIFGEN_ATTR_DATA_MARKER_EVENTS_COUNT
      NIFGEN_ATTR_STREAMING_WAVEFORM_NAME
      NIFGEN_ATTR_SCRIPT_TRIGGER_TYPE
      NIFGEN_ATTR_DIGITAL_EDGE_SCRIPT_TRIGGER_SOURCE
      NIFGEN_ATTR_DIGITAL_EDGE_SCRIPT_TRIGGER_EDGE
      NIFGEN_ATTR_DIGITAL_LEVEL_SCRIPT_TRIGGER_SOURCE
      NIFGEN_ATTR_DIGITAL_LEVEL_SCRIPT_TRIGGER_ACTIVE_LEVEL
      NIFGEN_ATTR_EXPORTED_SCRIPT_TRIGGER_OUTPUT_TERMINAL
      NIFGEN_ATTR_START_TRIGGER_TYPE
      NIFGEN_ATTR_DIGITAL_EDGE_START_TRIGGER_SOURCE
      NIFGEN_ATTR_DIGITAL_EDGE_TRIGGER_EDGE
      NIFGEN_ATTR_EXPORTED_START_TRIGGER_OUTPUT_TERMINAL
      NIFGEN_ATTR_READY_FOR_START_EVENT_OUTPUT_TERMINAL
      NIFGEN_ATTR_READY_FOR_START_EVENT_LEVEL_ACTIVE_LEVEL
      NIFGEN_ATTR_MARKER_EVENT_OUTPUT_TERMINAL
      NIFGEN_ATTR_MARKER_EVENT_PULSE_POLARITY
      NIFGEN_ATTR_MARKER_EVENT_PULSE_WIDTH
      NIFGEN_ATTR_MARKER_EVENT_PULSE_WIDTH_UNITS
      NIFGEN_ATTR_MARKER_EVENT_OUTPUT_BEHAVIOR
      NIFGEN_ATTR_MARKER_EVENT_TOGGLE_INITIAL_STATE
      NIFGEN_ATTR_STARTED_EVENT_OUTPUT_TERMINAL
      NIFGEN_ATTR_STARTED_EVENT_LEVEL_ACTIVE_LEVEL
      NIFGEN_ATTR_STARTED_EVENT_PULSE_POLARITY
      NIFGEN_ATTR_STARTED_EVENT_OUTPUT_BEHAVIOR
      NIFGEN_ATTR_STARTED_EVENT_PULSE_WIDTH_UNITS
      NIFGEN_ATTR_DONE_EVENT_OUTPUT_TERMINAL
      NIFGEN_ATTR_DONE_EVENT_LEVEL_ACTIVE_LEVEL
      NIFGEN_ATTR_DONE_EVENT_PULSE_POLARITY
      NIFGEN_ATTR_DONE_EVENT_OUTPUT_BEHAVIOR
      NIFGEN_ATTR_DONE_EVENT_PULSE_WIDTH_UNITS
      NIFGEN_ATTR_DATA_MARKER_EVENT_DATA_BIT_NUMBER
      NIFGEN_ATTR_DATA_MARKER_EVENT_LEVEL_POLARITY
      NIFGEN_ATTR_DATA_MARKER_EVENT_OUTPUT_TERMINAL
      NIFGEN_ATTR_ALL_MARKER_EVENTS_LIVE_STATUS
      NIFGEN_ATTR_MARKER_EVENT_LIVE_STATUS
      NIFGEN_ATTR_READY_FOR_START_EVENT_LIVE_STATUS
      NIFGEN_ATTR_ALL_MARKER_EVENTS_LATCHED_STATUS
      NIFGEN_ATTR_MARKER_EVENT_LATCHED_STATUS
      NIFGEN_ATTR_DONE_EVENT_LATCHED_STATUS
      NIFGEN_ATTR_STARTED_EVENT_LATCHED_STATUS
      NIFGEN_ATTR_EXPORTED_SAMPLE_CLOCK_OUTPUT_TERMINAL
      NIFGEN_ATTR_EXPORTED_REFERENCE_CLOCK_OUTPUT_TERMINAL
      NIFGEN_ATTR_EXPORTED_ONBOARD_REFERENCE_CLOCK_OUTPUT_TERMINAL
      NIFGEN_ATTR_EXPORTED_SAMPLE_CLOCK_TIMEBASE_OUTPUT_TERMINAL
      NIFGEN_ATTR_SYNC_OUT_OUTPUT_TERMINAL
      NIFGEN_ATTR_DIRECT_DMA_ENABLE
      NIFGEN_ATTR_DIRECT_DMA_WINDOW_SIZE
      NIFGEN_ATTR_DIRECT_DMA_WINDOW_ADDRESS
      FunctionsViStatus _VI_FUNC niFgen_AllocateNamedWaveform(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples);
      ViStatus _VI_FUNC niFgen_SetNamedWaveformNextWritePosition(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 relativeTo, ViInt32 offset);
      ViStatus _VI_FUNC niFgen_WriteNamedWaveformF64(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, ViReal64 wfmData[]);
      ViStatus _VI_FUNC niFgen_WriteNamedWaveformI16(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, ViInt16 wfmData[]);
      ViStatus _VI_FUNC niFgen_WriteNamedWaveformComplexF64(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, NIComplexNumber wfmData[]);
      ViStatus _VI_FUNC niFgen_WriteNamedWaveformComplexI16(ViSession vi, ViConstString channelName, ViConstString wfmName, ViInt32 numberOfSamples, NIComplexI16 wfmData[]);
      ViStatus _VI_FUNC niFgen_DeleteNamedWaveform(ViSession vi, ViConstString channelName, ViConstString wfmName);
      VViStatus _VI_FUNC niFgen_WriteScript(ViSession vi, ViConstString channelName, ViConstString script);
      ViStatus _VI_FUNC niFgen_DeleteScript(ViSession vi, ViConstString channelName, ViConstString scriptName);
      ViStatus _VI_FUNC niFgen_ExportSignal(ViSession vi, ViInt32 signal, ViConstString signalIdentifier, ViConstString outputTerminal);
      ViStatus _VI_FUNC niFgen_SendSoftwareEdgeTrigger(ViSession vi, ViInt32 triggerName, ViConstString triggerIdentifier);
      ViStatus _VI_FUNC niFgen_ConfigureDigitalEdgeStartTrigger(ViSession vi, ViConstString source, ViInt32 edge);
      ViStatus _VI_FUNC niFgen_ConfigureSoftwareEdgeStartTrigger(ViSession vi);
      ViStatus _VI_FUNC niFgen_DisableStartTrigger(ViSession vi);
      ViStatus _VI_FUNC niFgen_ConfigureDigitalEdgeScriptTrigger(ViSession vi, ViConstString triggerID, ViConstString source, ViInt32 edge);
      ViStatus _VI_FUNC niFgen_ConfigureDigitalLevelScriptTrigger(ViSession vi, ViConstString triggerID, ViConstString source, ViInt32 level);
      ViStatus _VI_FUNC niFgen_ConfigureSoftwareEdgeScriptTrigger(ViSession vi, ViConstString triggerID);
      ViStatus _VI_FUNC niFgen_DisableScriptTrigger(ViSession vi, ViConstString triggerID);
      ViStatus _VI_FUNC niFgen_WriteComplexBinary16Waveform(ViSession vi, ViConstString channelName, ViInt32 waveformHandle, ViInt32 numberOfSamples, NIComplexI16 wfmData[]);
      ViStatus _VI_FUNC niFgen_InitializeFlatnessCalibration(ViSession vi);
      ViStatus _VI_FUNC niFgen_CalAdjustFlatness(ViSession vi, ViConstString channelName, ViInt32 configuration, ViReal64 requestedAmplitude, ViReal64* frequencies, ViReal64* measuredAmplitudes, ViInt32 numberOfMeasurements);
      ViStatus _VI_FUNC niFgen_ConfigureSampleClockSource(ViSession vi, ViConstString sampleClockSource);
      ValuesOutput Mode:
      NIFGEN_VAL_OUTPUT_SCRIPT
      New attributes and functions:
      See niFgen.h file for values supported by new attributes and functions
      This section describes the changes in NI-FGEN 2.3 from NI-FGEN 2.2.
      • Added driver support for the NI PXI/PCI-5412 Arbitrary Waveform Generator.
      • Added driver support for the NI PXI-5441 Arbitrary Waveform Generator with Onboard Signal Processing.
        AttributesNIFGEN_ATTR_DIGITAL_GAIN
        NIFGEN_ATTR_OSP_ENABLED
        NIFGEN_ATTR_OSP_DATA_PROCESSING_MODE
        NIFGEN_ATTR_OSP_IQ_RATE
        NIFGEN_ATTR_OSP_CARRIER_ENABLED
        NIFGEN_ATTR_OSP_CARRIER_FREQUENCY
        NIFGEN_ATTR_OSP_CARRIER_PHASE_I
        NIFGEN_ATTR_OSP_CARRIER_PHASE_Q
        NIFGEN_ATTR_OSP_FIR_FILTER_TYPE
        NIFGEN_ATTR_OSP_FIR_FILTER_ENABLED
        NIFGEN_ATTR_OSP_FIR_FILTER_INTERPOLATION
        NIFGEN_ATTR_OSP_CIC_FILTER_ENABLED
        NIFGEN_ATTR_OSP_CIC_FILTER_INTERPOLATION
        NIFGEN_ATTR_OSP_FIR_FILTER_ROOT_RAISED_COSINE_ALPHA
        NIFGEN_ATTR_OSP_FIR_FILTER_RAISED_COSINE_ALPHA
        NIFGEN_ATTR_OSP_FIR_FILTER_FLAT_PASSBAND
        NIFGEN_ATTR_OSP_FIR_FILTER_GAUSSIAN_BT
        NIFGEN_ATTR_OSP_CIC_FILTER_GAIN
        NIFGEN_ATTR_OSP_PRE_FILTER_GAIN_I
        NIFGEN_ATTR_OSP_PRE_FILTER_GAIN_Q
        NIFGEN_ATTR_OSP_PRE_FILTER_OFFSET_I
        NIFGEN_ATTR_OSP_PRE_FILTER_OFFSET_Q
        NIFGEN_ATTR_OSP_OVERFLOW_ERROR_REPORTING
        NIFGEN_ATTR_OSP_OVERFLOW_STATUS
        FunctionsViStatus niFgen_ConfigureCustomFIRFilterCoefficients (ViSession vi, ViConstString channelName, ViInt32 numberOfCoefficients, ViReal64* coefficients)
        ViStatus niFgen_GetFIRFilterCoefficients (ViSession vi, ViConstString channelName, ViInt32 arraySize, ViReal64* coefficients, ViInt32* numberOfCoefficientsRead)
        ViStatus niFgen_CreateWaveformComplexF64 (ViSession vi, ViConstString channelName, ViInt32 numberOfSamples, niFgen_ComplexF64 wfmData[], ViInt32 *wfmHandle)
        ViStatus niFgen_WriteWaveformComplexF6 (ViSession vi, ViConstString channelName, ViInt32 numberOfSamples, niFgen_ComplexF64 data[], ViInt32 wfmHandle)
        ValuesOSP Data Processing Mode:
        NIFGEN_VAL_OSP_REAL
        NIFGEN_VAL_OSP_COMPLEX
        OSP FIR Filter Type:
        NIFGEN_VAL_OSP_FLAT
        NIFGEN_VAL_OSP_RAISED_COSINE
        NIFGEN_VAL_OSP_ROOT_RAISED_COSINE
        NIFGEN_VAL_OSP_GAUSSIAN
        NIFGEN_VAL_OSP_CUSTOM
        OSP Overflow Error Reporting:
        NIFGEN_VAL_ERROR_REPORTING_ERROR
        NIFGEN_VAL_ERROR_REPORTING_DISABLED
        OSP Overflow Status:
        NIFGEN_VAL_OSP_OVERFLOW_NONE
        NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_GAIN_I
        NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_GAIN_Q
        NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_OFFSET_I
        NIFGEN_VAL_OSP_OVERFLOW_PRE_FILTER_OFFSET_Q
        NIFGEN_VAL_OSP_OVERFLOW_FIR_FILTER_I
        NIFGEN_VAL_OSP_OVERFLOW_FIR_FILTER_Q
        NIFGEN_VAL_OSP_OVERFLOW_CIC_FILTER_I
        NIFGEN_VAL_OSP_OVERFLOW_CIC_FILTER_Q
        NIFGEN_VAL_OSP_OVERFLOW_COMPLEX_DATA
        © 2007 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2026-1-13 13:21
