查看: 1949|回复: 0
[NI软件产品] NI Switch Executive 2021 Full Win32/64Eng 美国国家仪器开关管理软件NISE21.5.0离线安装完整版下载
    发表于 2022-5-6 11:35:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Switch Executive是一款开关管理与路由应用软件,能够加速开发过程、简化对复杂开关系统的维护。
    Switch Executive提供交互式配置和自动路由功能,使开关系统的设计变得更加容易。您可以为开关模块、外部连接和信号路由分配别名,从而简化系统的文档,以便未来进行修改。使用Switch Executive开发的测试代码可以复用于LabVIEW、LabWindows/CVI、Measurement Studio和TestStand环境。
    发布日期
    2022/1/27
    包含的版本
    21.5.0
    受支持的操作系统
    语言
    English
    文件大小: 859863040 字节 (820.03 MB)
    修改日期: 2022-01-28 07:01
    MD5: 1c6ea74622066d1bab075c183103a19a
    SHA1: f0005c30db8d4deabac00ab72acd923d2b35887a
    SHA256: cce64b1234f46bd4e4ea59520baa94546eb3eb5ad59beb8691f8aff776ca55a8
    CRC32: 2ba09b68
    百度网盘下载地址和NI官方下载地址:
    请注册登录视觉论坛会员,购买附件查看
    NISE21.5.txt (589 Bytes, 下载次数: 0, 售价: 10 圆)
    Switch Executive 2021 Readme
    January 2022
    This file contains installation instructions and compatibility information for Switch Executive.
    You can find more information on ni.com
    • Switch Executive Release Notes: New features, behavior changes, and other documentation
    • Switch Executive Manuals: New features, behavior changes, and other documentation
    Switch Executive is a switch management and routing application that accelerates development and simplifies maintenance of complex switch systems.
    Switch Executive 2021 has the following requirements:
    • Processor—1 GHz or faster 64-bit (x64) processor
    • 2 GB RAM (64-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    Switch Executive 2021 supports the following operating systems:
    Switch Executive 2021 supports the following application software versions, including service packs.
    Versions Supported by Switch Executive
    LabVIEW2018, 2019, 2020, 2021
    LabVIEW NXG5.1
    LabWindows™/CVI™2013 and later
    Download the Switch Executive installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    Switch Executive no longer installs IVI Compliance Package (ICP). Switch Executive supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    • Switch Executive 2021 adds support for LabVIEW 2021.
    Switch Executive supports all IVI switches, which includes all NI switches and some third-party switches.
    Refer to the NI Switch Executive Help, accessible from Start»All Programs»National Instruments»Switch Executive»Switch Executive Documentation, for information about Switch Executive.
    You can access all the installed Switch Executive examples at Start»All Programs»National Instruments»Switch Executive»Switch Executive Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Switch Executive are located in the LabVIEW XXXX\examples\SwitchExecutive directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Toolkits and Modules»NI Switch Executive.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Switch Executive" to locate all Switch Executive examples.
    The following sections detail considerations for using LabVIEW NXG with Switch Executive.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    Switch Executive no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2002–2022 National Instruments Corporation. All rights reserved.
    375352H-01
    GMT+8, 2026-1-13 13:20
