查看: 2928|回复: 0
[NI软件产品] NI VeriStand 2021R2 and Drivers Win64Eng PC版完整版及运行版NIVS2021R2 21.2.0含驱动版9.57GB
    6 小时前
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2022-4-26 18:21:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand 2021 R2和驱动程序
    发布日期
    2022/4/17
    包含的版本
    2021 R2
    受支持的操作系统
    语言
    English
    校验和
    文件大小: 10276280320 字节 (9.57 GB)
    修改日期: 2022-04-18 10:18
    MD5: e7e5977e3a503c905eeaadbce2735a0d
    SHA1: 5f3d12fb6aa33a8c1ae07748866d7e43010b2e2b
    SHA256: 2cd06e7d20dd1b1582395492481a84b260826ecc8a72c7c441103d0c3e485fd7
    CRC32: 6a836fe9
    NIVS2021R2 and Drv.txt (588 Bytes, 下载次数: 16, 售价: 20 圆)
    VeriStand 2021 R2 Readme
    May 2022
    This file contains installation instructions and compatibility information for VeriStand 2021 R2.
    • VeriStand Manual: New features, behavior changes, and other documentation
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools. Use VeriStand's run-time editable user interface to implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand 2021 R2 installs with the following:
    • NI-DAQmx 21.8
    • NI-VISA 21.5
    • NI-SLSC 21.3
    • NI-XNET 21.8
    • NI R Series Multifunction RIO 21.5
    Simulation Models
    Note  You do not need the full VeriStand environment to generate a compatible model. Instead, you can install VeriStand Model Framework or VeriStand Model Generation Support Toolbox for Simulink.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2021 R2 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 10 64-bit version 21H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2021 R2, select Linux RT System Image 21.8 and enable support for the LabVIEW 2021 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2021 R2.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2021 R2. To access the documents, refer to the VeriStand Release Notes.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2021 SP1 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Migrating Files from VeriStand 2010 to 2018 SP1
    VeriStand 2021 R2 can open projects from VeriStand 2010 to 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    Beginning with VeriStand 2021, the VeriStand suite installer will include custom devices for both offline and online installation. The following custom devices can be included during installation.
    • Data Sharing Framework
    • Embedded Data Logger
    • Engine Simulation Toolkit
    • FPGA Addon
    • Instrument Addon
    • Routing and Faulting (NI-SWITCH and SLSC Switch)
    • Scan Engine and EtherCAT
    • SLSC 12201
    • SLSC EDS
    • Synchronization
    • Telemetry
    To install Custom Devices separately, see the release page for each Custom Device on the VeriStand Add-ons support page.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2021 R2 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2021 R2 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.Access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  Select VeriStand Model Framework when you run the VeriStand installer.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Note  On the Windows OS, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2020\examples\NI Veristand directory.
    VeriStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit NI Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    375380Y-01
    GMT+8, 2026-2-2 16:39
