查看: 9583|回复: 29
[MVTEC] MVTEC Deep Learning Tool 22.03 Full Version x64 windows 深度学习工具dlt-22.03完整版
    昨天 11:29
  • 签到天数: 3774 天
    连续签到: 25 天
    发表于 2022-4-15 13:30:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: dlt-22.03.zip
    文件大小: 2099668170 字节 (1.96 GB)
    修改日期: 2022-04-11 09:48
    MD5: 8764f7b12a28d1a0bd66467e09e669b8
    SHA1: c792cc5e0093b95a1cb5746727e3bdd281f3f4ae
    SHA256: 6d7d7a3042e0d6100ed03c29663e4bee03e243ae49458649213fc5217a61bdb3
    CRC32: 7a6cec21
    MVTEC官方地址:
    需要注册,然后免费下载。www.mvtec.com
    链接:
    提取码:yj79
    --来自百度网盘超级会员V5的分享
    RELEASE NOTES DEEP LEARNING TOOL
    This document provides the release notes for MVTec Deep Learning Tool 22.03, as released on 2022-03-24.
    The license of version 22.03 is valid until 2023-12-31.
    VERSION 22.03NEW FEATURES
    • The DLT now ships with example projects for all supported deep learning methods.
    • The appearance of the About dialog has been adapted to other dialogs.
    • The currently used HALCON version is now shown in the About dialog.
    • It is now possible to adjust the shown contrast and brightness of the images to ease the labeling and assessment of difficult images.
    • The DLT has been extended with an undo and redo function allowing you to revert any operation that modifies the project.
    • In segmentation projects, it is now possible to scale or rotate label regions or components.
    • It is now possible to set a project-wide (absolute or relative) image base path for the current project. If set, for all images on the same drive, a path relative to the image base path is stored. This makes it much easier to pass a project with images or to handle different image locations. The dialog for setting the image base path also allows relocating the images.
      When a project is created from a DL dataset (HDICT file), the image base path stored in the dataset file is now set as the project's image base path.
    • The Statistics dialog has been improved for object detection and segmentation projects.
    • The speed of the dictionary export has been improved significantly for large datasets with many images and labels.
    • The DLT is now based on HALCON 20.11.2 Steady.
    • It is now possible to convert bounding boxes imported from a HALCON Dictionary into polygon or mask regions.
    • The Deep Learning Tool now supports DirectX11 on Windows more reliably. To force software rendering in case of problems with the display, set the environment variable QSG_RHI_PREFER_SOFTWARE_RENDERER=1.
    • The help pages now offer the possibility to switch between the available languages (English, Chinese, Japanese).
    • The SOM package of the DLT has been split into four packages. Downloading and insta-lling NVIDIA GPU support and example projects now are optional.
    RESOLVED ISSUES AND IMPROVEMENTS
    • When a label was dragged onto itself, it was duplicated. This problem has been fixed.
    • Creating a new project using the path of an existing project showed inconsistent behavior: Although the Create button was disabled, the project could be created by pressing the Enter key. In addition, trainings of the overwritten project were inherited by the new project. These problems have been fixed.
    • Entering floating point numbers with multiple digits in input fields did not work correctly. This problem has been fixed.
    • The response time when drawing masks and polygons is low if the screen refresh rate is below 55 Hz. If this is the case, now a dialog is shown advising users to change the refresh rate of their screen.
    • Adding a single point to an existing line between two polygon points was not stored in the project. This problem has been fixed.
    • In the Create New Project dialog, it was possible to enter invalid file names or paths that resulted in errors when saving. This problem has been fixed.
    • It was possible to close the current project via the shortcut Ctrl+W while a modal dialog, like the Import Image Folder dialog, was open. This could lead to a crash when the dialog was closed afterwards. This problem has been fixed.
    • For very large images, the Review page could respond slowly. This problem has been fixed.
    • When using the "Home" link on Chinese or Japanese documentation pages, the English version was shown in Chromium-based browsers. This problem has been fixed.
    • On some systems, the DLT displayed a license expiration error after the turn of the year. This problem has been fixed.
    • The "No Label" class on the Review page showed a useless delete button upon hovering. This problem has been fixed by removing the button.
    • When pressing and releasing the Ctrl key in drawing mode, it could happen that the image was moved in an unexpected way. This problem has been fixed.
    • In some cases, the class menu was too close to polygon grip points of the region so that the points could not be selected. This behavior has been improved by moving the class menu farther away from the region.
    • The highlighting when hovering or selecting labels has been improved.
    • When drawing a new mask and activating the eraser tool by pressing the Alt key, clicking into another window outside the DLT application, and then moving back to the image view of the DLT, it was possible that the eraser tool was permanently activated even though the Alt key was not pressed anymore. This problem has been fixed.
    • The selection of overlapping regions and components has been improved. When clicking at a position with several overlapping regions, components, and/or holes, now the selection depends only on the position and the current selection. If the region to which the current selection belongs is below the mouse cursor, the next component of that region or the next region on the stack is selected. Otherwise, the topmost region on the stack is selected. The region or component about to be selected with the next click is always indicated by the hover indicator (a white border line). Clicking a hole will never selec-t the whole region but only the hole itself and the underlying components.
    • The documentation has been extended to include a note that repeatedly converting regions between mask and polygon can degenerate the region.
    • The documentation now mentions that converting masks to polygons or vice versa may change their position and size slightly.
    • During the installation using the MVTec Software Manager (SOM), the EULA is now displayed before the download of the DLT starts.
    发表于 2023-10-30 13:48:52 | 显示全部楼层 来自:江西省宜春市 移动
    超低价工业相机、机器视觉光源、工业镜头、机器视觉教程,就到机器视觉商城
    发表于 2023-10-10 14:00:20 | 显示全部楼层 来自:山东省 移动
    发表于 2023-8-30 16:21:42 | 显示全部楼层 来自:广东省深圳市 电信
    我今天最想说:「机器视觉光源,环形光条形光面光同轴光,就去机器视觉商城
  • 签到天数: 2 天
    发表于 2022-7-17 11:23:15 | 显示全部楼层 来自:广东省深圳市 天威有线宽带(关内)
  • 签到天数: 11 天
    发表于 2022-8-11 01:47:05 | 显示全部楼层 来自:重庆市 电信
  • 签到天数: 68 天
    [LV.6]600FPS
    发表于 2022-10-22 23:32:35 | 显示全部楼层 来自:江苏省 移动数据上网公共出口
  • 签到天数: 6 天
    发表于 2022-11-4 22:56:42 | 显示全部楼层 来自:辽宁省大连市 电信
  • 签到天数: 30 天
    发表于 2023-3-8 14:12:28 | 显示全部楼层 来自:香港 奥飞数据科技数据中心
    GMT+8, 2026-1-17 05:01
