查看: 1922|回复: 0
[NI软件产品] NI RFmx WLAN 21.3 Full x64Win10 32/64bitENG RFmx无线局域网络21.3完整版
    发表于 2022-4-13 11:32:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    RFmx WLAN为WLAN 802.11a/b/g/j/p/n/ac/ax/be测试应用提供信号生成和分析功能。
    RFmx WLAN(Wireless Local Area Networks)是一个测量API,旨在扩展NI RF仪器生成和分析WLAN 802.11信号的能力。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/ac/ax/be信号进行分析。此外,你可以使用RFmx WLAN生成和分析多达8x8的多输入和多输出(MIMO)单用户和多用户信号,并为每个用户提供灵活的配置、损伤和结果。您可通过交互式软面板快速轻松地执行和调试测量,使用附带的RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2021/10/22
    包含的版本:
    21.3完整版
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 1233856512 字节 (1.15 GB)
    修改日期: 2021-10-22 17:17
    MD5: 8b94e0e32132d9284aec09081fb88b9d
    SHA1: 748f59dfdd1e723f350712fc60f49834cd2672e2
    SHA256: 9aa05e99dc3ab3c5acffcbd9b11268ba14bb67591e3474d63be913ef22c37b25
    CRC32: da7aef9b
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 21.3.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx WLAN 21.3 Readme
    October 2021
    This file contains important information about the RFmx WLAN, including system requirements, and installation instructions.
    • RFmx WLAN Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WLAN Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11be MU PPDU in SISO and MIMO configurations
    • Support for OFDM physical layer of 802.11n, 802.11ac, and 802.11ax in MIMO configuration
    • Support for OFDM physical layer of 802.11ax SU, MU, Extended Range SU, and trigger-based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D8.0.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 21.3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.1
      • Trigger-based PPDU MIMO
      • OFDMA with RU Aggregation
      • Additional phase rotation option for pre-EHT modulated fields of 11be 320 MHz
      • MCS 14 (DCM + DUP) and MCS 15 (DCM)
    • Support for 802.11be data bit decoding
    • Support for 802.11be header decoded bits trace
    • Support for Vector Averaging
    • Support for Auto Level for OFDMModAcc measurement
    • Support for FEC coding type and DCM enabled results
    • Support for group delay trace
    • Support for packet extension duration result
    • Support for min-max statistics for certain results
    • Support for Analysis-Only mode for MIMO waveforms
    • Support to save and load MIMO configurations
    RFmx WLAN 20.7 includes the following new features:
    • Support for MIMO measurements of 802.11n/ac/ax/be standards on PXIe-5830/5831/5832/5840/5841
    • Support for 802.11be Standard IEEE P802.11be/D0.3
      • Bandwidth support up to 320 MHz
      • Modulation scheme support up to 4096 QAM
      • MU PPDU MIMO
        • Non-OFDMA and OFDMA
        • Multi-user MIMO
        • Preamble Puncturing
      • [BETA] Trigger-based PPDU MIMO
    • Reference waveform based EVM computation support in OFDMModAcc measurement
    • Support for sample clock rate factor across all measurements
    RFmx WLAN 20.6 includes the following new features:
    • Support for PXIe-5832
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    • PXIe-5646
    RFmx WLAN has the following requirements:
    RFmx WLAN 21.3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 21.3 to an unsupported OS. Additionally, after installing RFmx WLAN 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1, or 2021
    Required Software
    If you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx WLAN installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx WLAN installs the following licensed products:
      • WLAN: Enables analysis of 802.11a/b/g/j/p/n/ac/ax/11be signals with standard-compliant physical layer measurements such as error vector magnitude (EVM), spectrum emission mask (SEM), transmit power (TXP), and more. RFmx WLAN supports single-user and advanced multi-user signals with flexible configurations, impairments, and measurement results per user.
      • WLAN MIMO: Enables analysis of 802.11n/ac/ax/be MIMO signals with standard-compliant physical layer measurements such as error vector magnitude (EVM), spectrum emission mask (SEM), transmit power (TXP), and more. RFmx WLAN supports single-user and advanced multi-user signals with flexible MIMO configurations, impairments, and measurement results per user/per chain/per segment.
    • Use the serial number that is included with your software to activate RFmx WLAN. For more information on RFmx WLAN activation, refer to National Instruments Software Activation.
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WlanMX.Fx40.dll
    Select Start » National Instruments » RFmx WLAN » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN » RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 21.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 20.7 from RFmx WLAN 20.6.
    • Obsoleted RFmxWLAN OFDMModAcc Results HE-LTF Size property and RFmxWLAN OFDMModAcc Fetch HE-LTF Size API. Use RFmxWLAN OFDMModAcc Results LTF Size property and RFmxWLAN OFDMModAcc Fetch LTF Size API instead.
    • Obsoleted RFmxWLAN OFDM HE-LTF Size property. Use RFmxWLAN OFDM LTF Size property instead.
    • Obsoleted RFmxWLAN OFDM Num HE-LTF Symbols property. Use RFmxWLAN OFDM Num LTF Symbols property instead.
    • Obsoleted public int FetchPpduInformation(string selectorString, double timeout, out RFmxWlanMXDsssModAccDataModulationFormat dataModulationFormat, out int payloadLength, out RFmxWlanMXDsssModAccPreambleType preambleType, out int lockedClocksBit, out int headerCrcStatus, out int psduCrcStatus) method. Use public int FetchPpduInformation(string selectorString, double timeout, out RFmxWlanMXDsssModAccDataModulationFormat dataModulationFormat, out int payloadLength, out RFmxWlanMXDsssModAccPreambleType preambleType, out int lockedClocksBit, out RFmxWlanMXDsssModAccPayloadHeaderCrcStatus headerCrcStatus, out RFmxWlanMXDsssModAccPsduCrcStaus psduCrcStatus) method instead.
    The following is the behavior change in RFmx WLAN 20.6 from RFmx WLAN 20.0.
    • Noise calibration performed by OFDMModAcc EVM on PXIe-5840 and PXIe-5644/5645/5646 using earlier versions of RFmx is no longer valid. Noise calibration should be re-run before performing noise compensation.
    The following is the behavior change in RFmx WLAN 20.0 from RFmx WLAN 19.1.
    • SEM Mask creation now accounts for nearest bin quantization of offset start and stop frequencies
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377888H-01
    GMT+8, 2026-1-13 11:26
