查看: 1978|回复: 0
[NI软件产品] NI RFmx WLAN 19.0 Full Win64ENG RFmx无线局域网络19.0完整版
    发表于 2022-4-13 10:50:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    RFmx WLAN为WLAN 802.11a/b/g/j/p/n/ac/ax/be测试应用提供信号生成和分析功能。
    RFmx WLAN(Wireless Local Area Networks)是一个测量API,旨在扩展NI RF仪器生成和分析WLAN 802.11信号的能力。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/ac/ax/be信号进行分析。此外,你可以使用RFmx WLAN生成和分析多达8x8的多输入和多输出(MIMO)单用户和多用户信号,并为每个用户提供灵活的配置、损伤和结果。您可通过交互式软面板快速轻松地执行和调试测量,使用附带的RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2019/6/27
    包含的版本:
    19.0完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 929173504 字节 (886.13 MB)
    修改日期: 2019-07-18 18:13
    MD5: 87f4676b696312508cd9014716a35bde
    SHA1: 500e323a89b90df0a813b70f0019a52c142f018d
    SHA256: 97e52be72238305529cb925700610e9acbf013f70c8cf4abb7fe1569b30ae23e
    CRC32: b28320dc
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 19.0.txt (525 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx WLAN 19.0 Readme
    June 2019
    This file contains important information about RFmx WLAN, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    Installed Software
    RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11ax Single-User (SU), Multi-User (MU), Extended Range SU, and Trigger-Based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D4.2.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, and 160 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 19.0 includes the following new features:
    • Support for PXIe-5830 (EAP)
    RFmx WLAN 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for Auto Level in RFmx Soft Front Panel
    • NS_04 additional SEM requirements according to Table 6.6.2.2.3.2-3 of the 3GPP TS 36.521-1 specification (Release 12 and later)
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5840
    System RequirementsRFmx WLAN has the following requirements:
    • Processor—1 GH 64-bit (x64) processor
    • RAM—4 GB*
    RFmx WLAN 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx WLAN dropped support for all 32-bit Windows operating systems. RFmx WLAN will not install or run on an unsupported OS. Refer to RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx WLAN. To add support for application software installed after installing RFmx WLAN modify your RFmx WLAN installation or launch the RFmx WLAN installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI automates RFmx WLAN installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx WLAN is available for download from NI Software Product Downloads.
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WLAN\Examples
    Examples\LabVIEW \examples\RFmx\WLAN
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WlanMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx WLAN»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx WLAN examples at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Examples.
    Documentation for RFmx WLAN is located at Start»All Programs»National Instruments»RFmx WLAN»RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx WLAN palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WLAN palette.
    The following items are behavior changes in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    The following items are the IDs and titles of a subset of issues fixed in RFmx WLAN. This is not an exhaustive list of issues fixed in the current version of the RFmx WLAN. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    738282Fixed an issue where two DSSS ModAcc measurements returned different results for the same waveform when run in parallel.
    RFmx WLAN will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377888B-01
    GMT+8, 2026-1-13 11:27
