查看: 1576|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 19.0 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试19.0运行版-32位
    发表于 2022-4-12 11:47:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:
    2019/6/27
    包含的版本:
    19.0运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32位
    文件大小: 573102080 字节 (546.55 MB)
    修改日期: 2019-07-17 14:31
    MD5: bcd584d9d5fe0db570bec83f535f16e3
    SHA1: 535b0a4601d33d67952b71bac2b6c14c2a6cedc7
    SHA256: cdab6e9e1fbf6fe6d58a5c47c8b637f7b791213bd456472fc9f6a6b8e94aec47
    CRC32: c7518554
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 19.0RTE32.txt (560 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 19.0 Readme
    June 2019
    This file contains important information about RFmx WCDMA, including installation instructions, new features, bugs fixes, and known issues.
    Installed Software
    RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 19.0 includes the following new features:
    • Addition of RFmx WCDMA Soft Front Panel (SFP 64-bit) with debug support
    RFmx WCDMA 3.0 includes the following new features:
    • Support for PXIe-5820
    RFmx WCDMA 2.5 includes the following new features:
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for querying configuration attributes without calling RFmxWCDMA Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    System RequirementsRFmx WCDMA has the following requirements:
    • RAM—4 GB*
    RFmx WCDMA 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx WCDMA dropped support for all 32-bit Windows operating systems. RFmx WCDMA will not install or run on an unsupported OS. Refer to RFmx WCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx WCDMA. To add support for application software installed after installing RFmx WCDMA modify your RFmx WCDMA installation or launch the RFmx WCDMA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx WCDMA
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI automates RFmx WCDMA installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx WCDMA is available for download from NI Software Product Downloads.
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Select Start»All Programs»National Instruments»RFmx WCDMA»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    You can access all the installed RFmx WCDMA examples at Start»All Programs»National Instruments»RFmx WCDMA»RFmx WCDMA Examples.
    Documentation for RFmx WCDMA is located at Start»All Programs»National Instruments»RFmx WCDMA»RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WCDMA HelpHTML/Windows HelpContains primary help content for RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WCDMA
    • A complete reference for all RFmx WCDMA programming functions and VIs
    RFmx WCDMA 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    The following items are behavior changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    • Dropped support for RFmx WCDMA Measurement Interactive Panel.
    The following items are the behavior changes in RFmx WCDMA 2.3.1 from RFmx WCDMA 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@WCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    The following items are the IDs and titles of a subset of issues fixed in RFmx WCDMA. This is not an exhaustive list of issues fixed in the current version of the RFmx WCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    732660Fixed an issue where the user-configured values for ModAcc IQ Gain Imbalance Removal Enabled and ModAcc IQ Quadrature Error Removal Enabled properties were not being considered in a few scenarios.
    The following items are changes in RFmx WCDMA 3.0 from RFmx WCDMA 2.5
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following item is the change in RFmx WCDMA 2.4 from RFmx WCDMA 2.3.1
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in RFmx WCDMA 2.3.1 from RFmx WCDMA 2.3.
    The following items are changes in RFmx WCDMA 2.3 from RFmx WCDMA 2.2.
    641152Fixed an issue with configuring User Defined Channel properties in ModAcc and SlotPhase measurements with a named signal.
    RFmx WCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    375559J-01
    GMT+8, 2026-1-13 11:27
