查看: 1878|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 2.2 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.2运行版-64位
    发表于 2022-4-12 11:08:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:
    2016/12/8
    包含的版本:
    2.2运行版
    Windows 10
    Windows 8.1
    Windows 7
    Windows Server 2008 R2 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 284844048 字节 (271.65 MB)
    修改日期: 2016-12-09 00:12
    MD5: eab9c0f299b22a5317a74f510b221dbe
    SHA1: 9f1e5f4a288ae8abb364d333e2d9867bb2adfc3f
    SHA256: 55a9d8e416397714ec9687afc103707d466557ca116772ac23c8670794d97439
    CRC32: a97cf537
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 2.2RTE64.txt (518 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx WCDMA 2.2 Readme
    December 2016
    Thank you for using NI-RFmx WCDMA. This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    NI-RFmx WCDMA 2.2 includes the following new features:
    • Support for I/Q gain imbalance in ModAcc measurement
    • Support for quadrature skew in ModAcc measurement
    • Addition of QEVM measurement
    • Addition of SlotPhase measurement
    • Addition of 21 additional standard defined UL test models in ModAcc measurement
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance on VST devices
    • Support for reading the measurement configuration internally used by NI-RFmx in spectral measurements
    NI-RFmx WCDMA 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    NI-RFmx WCDMA 2.1 includes the following new features:
    • Support for C and .NET
    • Support for the Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q waveform
    Caution  Before you install NI-RFmx WCDMA 2.2, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx WCDMA 2.2 supports the following operating systems:
    Note  NI-RFmx WCDMA 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx WCDMA. To add support for ADEs installed after installing NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or launch the NI-RFmx WCDMA installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    Note  NI-RFmx WCDMA will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming functions and VIs
    NI-RFmx WCDMA 2.2 Beta 1 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Examples.
    NI-RFmx WCDMA 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx WCDMA drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx WCDMA 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx WCDMA 2.2 to an unsupported OS. Additionally, after installing NI-RFmx WCDMA 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx WCDMA 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx WCDMA 2.2 installation, the following software is installed. To completely remove the NI-RFmx WCDMA 2.2 installation from your system, you must also remove the following package:
    • NI-RFmx WCDMA Runtime 2.2
    • NI-RFmx WCDMA Runtime 2.2 (64-bit)
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.2.
    The following items are changes in NI-RFmx WCDMA 2.2 from NI-RFmx WCDMA 2.1.
    581372, 542850, 541109Fixed issues with channel detection for complex test models and high input powers.
    526865Fixed an issue with I/Q origin offset for highly impaired signals.
    The following items are changes in NI-RFmx WCDMA 2.1 from NI-RFmx WCDMA 2.0.
    562957Fixed an issue with fetching ModAcc results from the property node when traces are disabled in the NI-RFmx WCDMA ModAcc measurement.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    © 2015–2016 National Instruments. All rights reserved.
    375559C-01
    GMT+8, 2026-1-13 11:27
