查看: 2085|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2.1 Full Win32/64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.1完整版
    发表于 2022-4-12 11:03:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:
    2016/2/3
    包含的版本:
    2.1完整版
    Windows 10
    Windows 8.1
    Windows 7
    Windows Server 2008 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 780530240 字节 (744.37 MB)
    修改日期: 2016-02-03 01:08
    MD5: 3d063695639a765c31e023eb6b3af58c
    SHA1: 84e34d42e6f4df5feff62a9dc803ce9d8cdf6b7f
    SHA256: 02e2dc5b5e2cc202fa4d7470a3ab162970a7a3bcb632f69072b578b735c6a124
    CRC32: cdb5bccd
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 2.1.txt (501 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx WCDMA 2.1 Readme
    February 2016
    Thank you for using NI-RFmx WCDMA. This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    How to Use NI Software with Microsoft Windows 10
    How to Use NI Software with Microsoft Windows 8.1
    NI-RFmx WCDMA 2.1 includes the following new features:
    • Support for C and .NET
    • Support for Hardware Agnostic Mode, where you can perform measurements on a user-specified I/Q or spectrum waveform
    Installation InstructionsCaution  Before you install NI-RFmx WCDMA 2.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx WCDMA 2.1 supports the following operating systems:
    • Windows 10 (32-bit and 64-bit)
    • Windows 8.1 (32-bit and 64-bit)
    Note  NI-RFmx WCDMA 2.1 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install NI LabVIEW ADE before installing NI-RFmx WCDMA. To add support for ADEs installed after installing NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or launch the NI-RFmx WCDMA installer again.
    • LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    Note  NI-RFmx WCDMA will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\National Instruments\MeasurementStudioVS2010
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments\MeasurementStudioVS2010
      • Windows 10/8.1/7: Users\Public\Documents\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/7
    Import Library files
    Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit):\Shared\ExternalCompilerSupport\C\include
    C, .NET
    Examples\RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming VIs
    NI-RFmx WCDMA 2.1 ReadmeHTML (this document)Information about supported hardware, supported operating systems, and legal notices.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Examples.
    • Select NI-RFmx WCDMA 2.1 from the dialog box that appears.
    • Click the Uninstall button.
    As part of the NI-RFmx WCDMA 2.1 installation, the following software is installed. To completely remove the NI-RFmx WCDMA 2.1 installation from your system, you must also remove the following package:
    • NI-RFmx WCDMA Runtime 2.1 for LabVIEW
    • NI-RFmx WCDMA Runtime 2.1 for C/.NET
    • NI-RFmx WCDMA Runtime 2.1 (64-bit) for C/.NET
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.1.
    The following items are changes in NI-RFmx WCDMA 2.1 from NI-RFmx WCDMA 2.0.
    562957Fixed an issue with fetching ModAcc results from the property node when traces are disabled in the NI-RFmx WCDMA ModAcc measurement.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view click the down arrow on the bottom left of the screen (Windows 8.1).
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2015–2016 National Instruments. All rights reserved.
    375559B-01
    GMT+8, 2026-1-13 11:27
