查看: 1817|回复: 0
[NI软件产品] NI RFmx Waveform Creator 19.1 Full Win32/64ENG RFmx波形创造器19.1完整版
    发表于 2022-4-11 15:23:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2019/10/17
    包含的版本:
    19.1完整版
    Windows Server 2008 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 698576896 字节 (666.21 MB)
    修改日期: 2019-10-18 16:11
    MD5: 6889d8eaa49d5684c49e39b2d8756476
    SHA1: cc99b6dab2941773d093521482bdfb93ccf9b9a2
    SHA256: 3938e38d971a48523ab6ec78e12f88e8f9879f10eb1b27cee6794d1750c0e8ac
    CRC32: d125e741
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 19.1.txt (590 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Waveform Creator 19.1 Readme
    October 2019
    This file contains important information about the RFmx Waveform Creator, including system requirements and installation instructions.
    RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Waveform Creator provides a unified interface for creating and generating waveforms for multiple wireless standards. You can create unencrypted, unlocked IQ waveform files for playback on NI PXI RF instrumentation. Supported standards include 5G NR, LTE/LTE-Advanced, W-CDMA/HSPA+, GSM/EDGE+, TD-SCDMA, and more.
    RFmx Waveform Creator 19.1 includes the following new features:
    • Support for V2X (sidelink) in LTE FDD modulation scheme as per 3GPP Release 14 specification
      • Added PSSCH and PSCCH channels
      • Added PSSCH DMRS and PSCCH DMRS signals
      • Support for retransmission
    • 5G new radio (NR) modulation scheme
      • Support for 3GPP NR Release 15 Specification v15.6.0 (June 2019)
      • Support for auto increment cell id for carrier aggregation
      • Support for channel coding in PUSCH, PDSCH, and PDCCH
      • Support for predefined strings for PUSCH RB allocation as per 3GPP TS 38.521-1/2 specification
    • Added option to enable or disable phase continuity in LTE and NR multi-carrier
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    RFmx Waveform Creator 19.0 includes the following new features:
    • Support for PXIe-5830 and PXIe-5831
    • Support for Cat-M2 Uplink (Release 14) and Cat-NB2 Uplink in LTE modulation scheme
      • Added support for Uplink Pi/2 BPSK Spectral Shaping
      • Support for downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Support to resume generated waveforms in Download and Play window
    RFmx Waveform Creator 3.0 includes the following new features:
    • Addition of 5G new radio (NR) modulation scheme
    • Support for launching the WLAN Generation SFP
    • Support for launching the Bluetooth Generation SFP
    • Support for PXIe-5820
    • Addition of crest factor reduction (CFR) in LTE, NR, and Multi-Carrier modulation schemes. Supported CFR types are Clipping and Peak Windowing.
    • Support for custom output sample rate in multi-carrier plugin.
    • GSM relative power per slot
    Vector Signal Generators
    • PXIe-5673
    • PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx Waveform Creator has the following requirements:
    RFmx Waveform Creator 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Waveform Creator dropped support for all 32-bit Windows operating systems. RFmx Waveform Creator will not install or run on an unsupported OS. Refer to RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    NI installs RFmx Waveform Creator using NI Package Manager. If you do not already have NI software installed, RFmx Waveform Creator installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Select Start » All Programs » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator.
    Documentation for RFmx Waveform Creator is located at Start»All Programs»National Instruments»RFmx Waveform Creator»RFmx Waveform Creator Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Waveform Creator HelpHTML/Windows HelpContains primary help content for RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Waveform Creator
    • A complete reference for all RFmx Waveform Creator programming functions and VIs
    RFmx Waveform Creator 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Waveform Creator examples at Start»All Programs»National Instruments»RFmx Waveform Creator»RFmx Waveform Creator Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following items are the behavior changes in RFmx Waveform Creator 19.1 from RFmx Waveform Creator 19.0.
    • Following configurations require recreation of waveforms in 5G new radio (NR) modulation scheme
      • Carrier aggregation due to 3GPP NR specification updates to nominal spacing
      • Downlink test models due to 3GPP NR specification updates to definitions of downlink test models
      • ACP optimized filter bandwidth is updated to avoid corrupting edge sub-carriers
    The following items are the behavior changes in RFmx Waveform Creator 19.0 from RFmx Waveform Creator 3.0.
      • Deprecated support for slot Offset control
      • Default value of downlink Channel Configuration Mode control has changed to Test Model from User defined .
      • Default value of BWP Number of RBs control has changed to -1 from maximum number of resource blocks.
      • Added SSB Active Blocks control and deprecated SSB Transmitted Pattern control under SS/PBCH Block configurations window.
    • Saving of waveforms in evaluation mode is not allowed in WLAN and Bluetooth
    The following items are the behavior changes in RFmx Waveform Creator 3.0 from RFmx Waveform Creator 2.5.
    • Fractional resampling is performed in LTE and NR carrier aggregation so that the final sample rate is a multiple of 3.84 MHz.
    • CCDF graph calculates PAPR based on generated waveform excluding OFF power period.
    • UI controls on the Download & Play window are reset based on selected device.
    You can access the software and documentation known issues list online. Refer to the RFmx Waveform Creator Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in RFmx Waveform Creator . This is not an exhaustive list of issues fixed in the current version of the RFmx Waveform Creator . If you have a bug ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx Waveform Creator 19.1 from RFmx Waveform Creator 19.0
    237107Fixed a crash issue in graphics panel when Zoom In option was chosen before generating plot.
    237143Fixed a crash issue while saving idle waveform in GSM modulation scheme.
    237073Fixed an issue with file name containing German characters in Multi-Carrier plugin.
    244064Fixed an issue to enable Payload Length and Payload Length Mode fields when you set the Carrier Mode to Continuous in Bluetooth modulation scheme.
    244072Fixed an issue in Bluetooth waveform generation of LE-TP Ext and LE Enhanced packets where
    • CTE time field was set to 0 bits when you set Direction Finding Mode parameter to value other than Disabled .
    • CTE type field was incorrect when you set the Direction Finding Mode parameter to Angle of Departure and CTE slot duration to 2 us.
    244074Fixed an issue where filter delay was not accounted for the continuous mode of Bluetooth EDR packet generation.
    217088Fixed an issue where the waveform length was incorrectly computed for continuous mode of Bluetooth LE packet generation when direction finding mode was set to value other than Disabled .
    237195Fixed an issue of periodic spurs at specific frequencies in tones generation.
    216576 and 218907Fixed an issue with CFR bandwidth calculation in NR plugin and Multi-Carrier plugin.
    The following items are changes in RFmx Waveform Creator 19.0 from RFmx Waveform Creator 3.0
    236984Fixed an issue where the error message was getting cleared in Download and Play window when switching between windows
    236966Performance enhancements in CFR operations for waveforms of size lesser than 20M samples.
    236903Fixed an issue where the Graphics tab IQ FFT view was not scaling correctly when the bandwidth was increased.
    236913Fixed an issue with waveform precision from 14 bits to 16 bits.
    The following items are changes in RFmx Waveform Creator 3.0 from RFmx Waveform Creator 2.5
    236754Fixed the phase discontinuity issue on configuring GSM on first slot and EDGE on last slot.
    236716Fixed the issue where CCDF graph was reporting negative results for some configurations.
    236718Fixed the issue of not reporting burst start and stop locations for NB-IoT and eMTC FDD.
    236732 and 236751Fixed the issue of reporting incorrect burst PAPR for impaired bursty signal in Multi-Carrier and User plugins.
    236710Fixed the issue where IQ impairments per carrier set were incorrect, when multiple carrier sets are configured.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx Waveform Creator will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2017–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    377066G-01
    GMT+8, 2026-1-13 11:27
