查看: 1850|回复: 0
[NI软件产品] NI RFmx Waveform Creator 19.0 Full Win32/64ENG RFmx波形创造器19.0完整版
    发表于 2022-4-11 15:21:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2019/6/27
    包含的版本:
    19.0完整版
    Windows Server 2008 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 681158656 字节 (649.60 MB)
    修改日期: 2019-08-07 15:40
    MD5: 1941e653965d09c7495a1478153ba3ed
    SHA1: 56847b08d583962d9e73719353d7e626a2667379
    SHA256: df4954fcbf170dd0f9524dad8df7edd2cedd39e1334957d1482b69626fd42a4b
    CRC32: efbd4475
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 19.0.txt (580 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Waveform Creator 19.0 Readme
    June 2019
    This file contains important information about RFmx Waveform Creator, including installation instructions, new features, bugs fixes, and known issues.
    Installed Software
    RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Waveform Creator provides a unified interface for creating and generating waveforms for multiple wireless standards. You can create unencrypted, unlocked IQ waveform files for playback on NI PXI RF instrumentation.Supported standards include LTE/LTE-Advanced, W-CDMA/HSPA+, GSM/EDGE+, TD-SCDMA, and more.
    RFmx Waveform Creator 19.0 includes the following new features:
    • Support for PXIe-5830 (EAP) and PXIe-5831 (EAP)
    • Support for Cat-M2 Uplink (Release 14) and Cat-NB2 Uplink in LTE modulation scheme
    • 5G new radio (NR) modulation scheme
      • Added support for Uplink Pi/2 BPSK Spectral Shaping
      • Support for downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Support for Resume Waveform Playback in Download and Play window
    RFmx Waveform Creator 3.0 includes the following new features:
    • Addition of 5G new radio (NR) modulation scheme
    • Support for launching the WLAN Generation SFP
    • Support for launching the Bluetooth Generation SFP
    • Support for PXIe-5820
    • Addition of crest factor reduction (CFR) in LTE, NR, and Multi-Carrier modulation schemes. Supported CFR types are Clipping and Peak Windowing.
    • Support for custom output sample rate in multi-carrier plugin.
    • GSM relative power per slot
    RFmx Waveform Creator 2.5 includes the following new features:
    • Support for waveform generation in eMTC uplink features such as,
      • Frequency Hopping
      • Guard symbols
    • Support for waveform generation in NB-IoT uplink features such as,
      • Single/multi tones
      • 15kHz/3.75kHz subcarrier spacing
      • NPUSCH Format 1/2
    • Support for LTE-LAA Resource Allocation Type 3
    • Support for 64-bit
    • Addition of the Waveform Summary window
    • Support for multi-carrier generation utility
    • Support for generating tones up to 1.25G
    • Support for updating the window duration based on LTE bandwidth
    • Improvements in the performance of waveform generation
    Supported HardwareVector Signal Generators
    • PXIe-5673
    • PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5831 (EAP)
    RFmx Waveform Creator has the following requirements:
    • 4 GB RAM*
    RFmx Waveform Creator 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx Waveform Creator dropped support for all 32-bit Windows operating systems. RFmx Waveform Creator will not install or run on an unsupported OS. Refer to RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Other Required Software
    • NI-RFSG 14.5 or later
    NI installs RFmx Waveform Creator using NI Package Manager. If you do not already have NI software installed, RFmx Waveform Creator installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Examples\examples
    Select Start»All Programs»National Instruments»RFmx Waveform Creator»RFmx Waveform Creator Examples to launch the RFmx Waveform Creator.
    You can access all the installed RFmx Waveform Creator examples at Start»All Programs»National Instruments»RFmx Waveform Creator»RFmx Waveform Creator Examples.
    Documentation for RFmx Waveform Creator is located at Start»All Programs»National Instruments»RFmx Waveform Creator»RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Waveform Creator HelpHTML/Windows HelpInformation about the RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Waveform Creator
    • How to get started with the application
    • A complete reference of all the different modulation schemes supported
    RFmx Waveform Creator 19.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    The following items are the behavior changes in RFmx Waveform Creator 19.0 from RFmx Waveform Creator 3.0.
      • Deprecated support for Slot Offset control
      • Default value of downlink Channel Configuration Mode control has changed to Test Model from User defined.
      • Default value of BWP Number of RBs control has changed to -1 from maximum number of resource blocks.
      • Added SSB Active Blocks control and deprecated SSB Transmitted Pattern control under SS/PBCH Block configurations window.
    • Saving of waveforms in evaluation mode is not allowed in WLAN and Bluetooth
    The following items are the behavior changes in RFmx Waveform Creator 3.0 from RFmx Waveform Creator 2.5.
    • Fractional resampling is performed in LTE and NR carrier aggregation so that the final sample rate is a multiple of 3.84 MHz.
    • CCDF graph calculates PAPR based on generated waveform excluding OFF power period.
    • UI controls on the Download & Play window are reset based on selected device.
    The following items are the behavior changes in RFmx Waveform Creator 2.5 from RFmx Waveform Creator 2.4.
    • Updated the PAPR calculation for bursty signals in the presence of noise.
    • Removed restriction on configuring resource allocation type 0 and resource allocation type 1 settings in LTE.
    The following item is a known issue in RFmx Waveform Creator 19.0.
    IDKnown Issue
    711673PAPR displayed on CCDF graph does not match with PAPR stored in the tdms file in User plugin.
    736118When Waveform Creator aggregates multiple carriers, it may adjust the carrier offsets to ensure resultant signal is phase continuous. To avoid coercions of the carrier offsets, set offsets to be an integer multiple of (1/signal duration). In case you are setting NR spacing type to Nominal, set Reference CC Index to a valid CC Index, instead of -1.
    The following items are the IDs and titles of a subset of issues fixed in RFmx Waveform Creator. This is not an exhaustive list of issues fixed in the current version of the RFmx Waveform Creator. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx Waveform Creator 19.0 from RFmx Waveform Creator 3.0
    734588Fixed an issue where the error message was getting cleared in Download and Play window when switching between windows
    732228Fixed an issue where the speed degradation in CFR operations for waveform size was less than 20M samples.
    724892Fixed an issue where the Graphics tab IQ FFT view was not scaling correctly in corner case when the bandwidth was increased.
    695883Fixed the issue of WFC precision being low, 14 bits.
    The following items are changes in RFmx Waveform Creator 3.0 from RFmx Waveform Creator 2.5
    704721Fixed the phase discontinuity issue on configuring GSM on first slot and EDGE on last slot.
    698120Fixed the issue where CCDF graph was reporting negative results for some configurations.
    701478Fixed the issue of not reporting burst start and stop locations for NB-IoT and eMTC FDD.
    705738 and 701490Fixed the issue of reporting incorrect burst PAPR for impaired bursty signal in Multi-Carrier and User plugins.
    712524Fixed the issue where IQ impairments per carrier set were incorrect, when multiple carrier sets are configured.
    The following items are changes in RFmx Waveform Creator 2.5 from RFmx Waveform Creator 2.4
    685187Fixed issue where an overflow error was reported on generating LTE.
    700390Fixed issue where the PAPR calculation for bursty signals with user plugin was incorrect.
    RFmx Waveform Creator will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2017–2019 National Instruments. All rights reserved.
    377066F-01
    GMT+8, 2026-1-13 11:27
