查看: 1666|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 20.6 Full Win32/64ENG RFmx蜂窝测试TD-SCDMA20.6完整版
    发表于 2022-4-11 11:17:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2021/1/20
    包含的版本:
    20.6完整版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 891133952 字节 (849.85 MB)
    修改日期: 2021-01-20 15:18
    MD5: 7dc21268eb1747a8e90e64301a8f59a6
    SHA1: 60e29cbb86116a750542eabc6152c2f79fc91534
    SHA256: 348717fee9bf42f2957769cf3b3b69d97d3049aa6e7975e24c9637a25f1c0812
    CRC32: a17b3673
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA20.6.txt (550 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx TD-SCDMA 20.6 Readme
    January 2021
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    Installed Software
    RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 20.0 includes the following new features:
    RFmx TD-SCDMA 19.1 includes the following new feature:
    RFmx TD-SCDMA 19.0 includes the following new features:
    • Addition of RFmx TD-SCDMA Soft Front Panel (SFP 64-bit) with debug support
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx TD-SCDMA dropped support for all 32-bit Windows operating systems. RFmx TD-SCDMA will not install or run on an unsupported OS. Refer to RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx TD-SCDMA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx TD-SCDMA 20.6 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. To add support for application software installed after installing RFmx TD-SCDMA modify your RFmx TD-SCDMA installation or launch the RFmx TD-SCDMA installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx TD-SCDMA
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx TD-SCDMA using NI Package Manager. If you do not already have NI software installed, RFmx TD-SCDMA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation .
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx TD-SCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » All Programs » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx TD-SCDMA HelpHTML/Windows HelpContains primary help content for RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx TD-SCDMA
    • A complete reference for all RFmx TD-SCDMA programming functions and VIs
    RFmx TD-SCDMA 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx TD-SCDMA examples at Start » All Programs » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    • Obsoleted RFmxTDSCDMA Analyze (IQ) and RFmxTDSCDMA Analyze (Spectrum) APIs. Use RFmxTDSCDMA Analyze (IQ, 1 Wfm) and RFmxTDSCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx TD-SCDMA 19.0 from RFmx TD-SCDMA 3.0:
    • Dropped support for RFmx TD-SCDMA Measurement Interactive Panel
    You can access the RFmx TD-SCDMA known issues online at RFmx TD-SCDMA 20.6 Known Issues.
    You can access the RFmx TD-SCDMA bug fix list online at RFmx TD-SCDMA 20.6 Bug Fixes. This list describes a subset of issues fixed in RFmx TD-SCDMA. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx TD-SCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2021 National Instruments. All rights reserved.
    375525M-01
    GMT+8, 2026-1-13 09:56
