查看: 2018|回复: 0
[RTE运行引擎] NI RFmx TD-SCDMA 2.2 Runtime Win64ENG RFmx蜂窝测试TD-SCDMA2.2运行版-64位
    发表于 2022-4-11 09:53:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2016/12/9
    包含的版本:
    2.2运行版
    Windows 10
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows 7
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 285720608 字节 (272.48 MB)
    修改日期: 2016-12-09 00:11
    MD5: 6d66cea631a3e6c6950b10c267d88ce8
    SHA1: 85ec52740c21f7e59e5208f60c2e36d63a5ad903
    SHA256: 2357b7ecbd1853b2b49c7cea85eba9000964ad375a0a56fa3fdce1bb9045587d
    CRC32: 8936c66a
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA2.2RTE64.txt (521 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx TD-SCDMA 2.2 Readme
    December 2016
    Thank you for using NI-RFmx TD-SCDMA. This file contains important information about NI-RFmx TD-SCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx TD-SCDMA
    NI-RFmx TD-SCDMA 2.2 includes the following new features:
    • Added code domain analysis (CDA) measurement
    • Added power versus time (PVT) measurement
    • Support for the auto detection of midamble shift for ModAcc, CDA and PVT measurements
    • Support for averaging for ModAcc measurements
    • Support for Code Domain Error trace
    • Support for I/Q gain imbalance for ModAcc measurements
    • Support for I/Q quadrature error for ModAcc measurements
    • Improved robustness of synchronization/channel auto detection for ModAcc, CDA and PVT measurements
    • Support for reading measurement configuration internally used by RFmx for spectral measurements
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance vector signal transciever as the analyzer
    NI-RFmx TD-SCDMA 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    NI-RFmx TD-SCDMA 2.1 includes the following new features:
    • Support for C and .NET
    • Support for Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q or Spectrum waveform
    Caution  Before you install NI-RFmx TD-SCDMA 2.2, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx TD-SCDMA 2.2 supports the following operating systems:
    Note  NI-RFmx TD-SCDMA 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    • A screen resolution of 1,300 x 700 with 256 colors
    Recommended System
    • RAM—4 GB*
    • A screen resolution of 1300 x 700
    Note  You should install NI LabVIEW ADE before installing NI-RFmx TD-SCDMA. To add support for ADEs installed after installing NI-RFmx TD-SCDMA, modify your NI-RFmx TD-SCDMA installation or launch the NI-RFmx TD-SCDMA installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    Note  NI-RFmx TD-SCDMA does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\RFmx\TDSCDMA\Examples
    Examples\LabVIEW \examples\RFmx\TDSCDMA
    Select Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Measurement Interactive Panel to launch the NI-RFmx TD-SCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx TD-SCDMA is located at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx TD-SCDMA HelpHTML/Windows HelpInformation about NI-RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx TD-SCDMA
    • A complete reference for all NI-RFmx TD-SCDMA programming functions and VIs
    NI-RFmx TD-SCDMA 2.2 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx TD-SCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»TD-SCDMA palette.
    You can access all the installed NI-RFmx TD-SCDMA examples at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Examples.
    NI-RFmx TD-SCDMA 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx TD-SCDMA drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx TD-SCDMA 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx TD-SCDMA 2.2 to an unsupported OS. Additionally, after installing NI-RFmx TD-SCDMA 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx TD-SCDMA 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx TD-SCDMA 2.2 installation, the following software is installed. To completely remove the NI-RFmx TD-SCDMA 2.2 installation from your system, you must also remove the following package:
    • NI-RFmx TD-SCDMA Runtime 2.2
    • NI-RFmx TD-SCDMA Runtime 2.2 (64-bit)
    The following are the behavior changes in NI-RFmx TD-SCDMA 2.2 from NI-RFmx TD-SCDMA 2.1:
    • Auto detection of midamble shift is activated by default in ModAcc, CDA, and PVT measurements
    • Configuration of midamble code is no longer supported; basic midamble code is now derived from the configured scrambling code using the relationship defined between the two in 3GPP TS 25.223
    • RFmxTDSCDMA Configure Midamble.vi has been replaced by RFmxTDSCDMA Configure Midamble Shift.vi
    The following are the behavior changes in NI-RFmx TD-SCDMA 2.1 from NI-RFmx TD-SCDMA 2.0:
    • Configuration for midamble auto detection has to be set globally with RFmxTDSCDMA Configure Midamble.vi
    You can access the software and documentation known issues list online. Refer to the NI-RFmx TD-SCDMA 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx TD-SCDMA 2.2.
    The following items are changes in NI-RFmx TD-SCDMA 2.2 from NI-RFmx TD-SCDMA 2.1.
    538047Fixed an issue where synchronization unable to detect signals with power level that were below -40 dBm.
    570432Fixed an issue where the midamble shift parameter was applied in the wrong direction, which caused in a wrong relation of midamble shift and midamble sequence.
    570431Fixed an issue where the range restriction for the configuration of midamble shift which was limited to 0-16 chips.
    The following items are changes in NI-RFmx TD-SCDMA 2.1 from NI-RFmx TD-SCDMA 2.0.
    563071Fixed an issue where you could not fetch scalar results from the property node when traces are disabled in NI-RFmx TD-SCDMA ModAcc measurement.
    555713Fixed an issue where the absolute mask limits in the SEM offset segment definition were corrected according to Table 5.5.2.1.2.2 in 3GPP TS 34.122
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information about LabVIEW memory usage, refer to KB 2HDEH9DT, How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G, Using the Large Address Aware Flag With TestStand Applications.
    © 2015–2016 National Instruments. All rights reserved.
    375525C-01
    GMT+8, 2026-1-13 09:53
