查看: 1954|回复: 0
[RTE运行引擎] NI RFmx Phase Noise 19.0 Runtime Win32/64ENG RFmx相位噪声19.0运行版
    发表于 2022-4-8 10:11:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Phase Noise相位噪声
    RFmx Phase Noise为相位噪声分析提供交互式自动化测量。
    RFmx Phase Noise是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Phase Noise一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件扩展了NI射频仪器的相位噪声分析能力,帮助您通过智能自动范围设置或手动配置来测量对数图、点和集成相位噪声。使用迹线平滑、消除杂散和消除仪器相位噪声等先进技术有助于提升测量性能。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2019/6/27
    包含的版本:
    19.0运行版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 375969792 字节 (358.55 MB)
    修改日期: 2019-08-07 15:45
    MD5: f9f365b3cc5e722ec249fbd017efc55c
    SHA1: 33cef827a5780d045cec3912d7f2448b9ab93eff
    SHA256: 4af843d3a46e48d70344491c98470fbf770a22131bd47bc41c31e774e0f039dd
    CRC32: 99106f9a
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Phase Noise19.0RTE.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Phase Noise 19.0 Readme
    June 2019
    This file contains important information about RFmx Phase Noise 19.0 and is organized into the following sections:
    RFmx Phase Noise Drops Support for Windows 7 (64-bit) and Windows Server 2008 R2 in 2021
    RFmx Phase Noise installer contains the license files only. The Phase Noise measurement software is included in RFmx SpecAn. Install RFmx SpecAn 19.0 or later before installing the RFmx Phase Noise. Please refer to the RFmx SpecAn documentation for more information.
    RFmx Phase Noise has the following requirements:
    • 4 GB RAM*
    RFmx Phase Noise 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    Note  In 2019, RFmx Phase Noise dropped support for all 32-bit Windows operating systems. RFmx Phase Noise will not install or run on an unsupported OS. Refer to RFmx Phase Noise Drops Support for Windows 7 (64-bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    NI automates RFmx Phase Noise installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx Phase Noise is available for download from NI Software Product Downloads.
    The RFmx Phase Noise measurement requires license activation. If you install the Phase Noise license but do not activate it, you will have 30 days to activate the measurement from the day you use it.
    RFmx Phase Noise will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2016–2019 National Instruments. All rights reserved.
    378027A-01
    GMT+8, 2026-1-13 09:36
