查看: 1663|回复: 0
[RTE运行引擎] NI RFmx Niose Figure 2.5 Runtime Win32/64ENG RFmx噪声系数2.5运行版
    发表于 2022-4-7 11:42:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2018/7/3
    包含的版本:
    2.5运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 182243344 字节 (173.80 MB)
    修改日期: 2018-07-03 17:48
    MD5: 60ee40f7033433de1fa5cc34f62c6aba
    SHA1: 0237c50cda450aeb0b8b37471566c9fc7b22113d
    SHA256: 6adbb4f48b6f4887b393fac912bc8ef888f92f35ebc713e596d701f83370ef61
    CRC32: 8c68f4d1
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure2.5RTE.txt (522 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx Noise Figure 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx Noise Figure 2.5 and is organized into the following sections:
    Activation Instructions
    NI-RFmx Noise Figure 2.5 installs the license files only. The Noise Figure measurement software is included in NI-RFmx SpecAn 2.5.
    Install NI-RFmx SpecAn 2.5 or later before installing the NI-RFmx Noise Figure.
    The Noise Figure measurement requires license activation. If you install the NI-RFmx Noise Figure 2.5 but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    NI-RFmx Noise Figure 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx Noise Figure dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Noise Figure 2.5 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Noise Figure 2.5 to an unsupported OS. Additionally, after installing NI-RFmx Noise Figure 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFmx Noise Figure 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    © 2016-2018 National Instruments. All rights reserved.
    376695E-01
    GMT+8, 2026-1-13 09:37
