查看: 1778|回复: 0
[NI软件产品] NI RFmx Niose Figure 2.2 Full Win32/64ENG RFmx噪声系数2.2完整版
    发表于 2022-4-7 11:23:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2016/12/8
    包含的版本:
    2.2完整版
    Windows 10
    Windows Server 2008 R2 64-bit
    Windows 8.1
    Windows 7
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 219906064 字节 (209.72 MB)
    修改日期: 2016-12-09 00:20
    MD5: a5a297ad3128c80025fd0bb73b6711fd
    SHA1: 1cea7bdffdb0fb57d97221454c75f02779cffa63
    SHA256: 66aa953a3510cbfe9d201057e220cb7677a9b0e80f7daeb38b41e9b3e7ed2af2
    CRC32: 892ebd4d
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure2.2.txt (517 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Noise Figure License 2.2 Readme
    December 2016
    This file contains important information about NI-RFmx Noise Figure License 2.2 and is organized into the following sections:
    Activation Instructions
    Uninstalling/Modifying NI-RFmx Noise Figure License 2.2
    NI-RFmx Noise Figure License 2.2 installs the license files only. The Noise Figure measurement software is included in NI-RFmx SpecAn 2.2.
    Install NI-RFmx SpecAn 2.2 or later before installing the NI-RFmx Noise Figure License.
    The Noise Figure measurement requires license activation. If you install the Noise Figure license but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    NI-RFmx Noise Figure License 2.2 supports the following operating systems:
    Note  NI-RFmx Noise Figure License 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Refer to ni.com/examples for these examples and for more information.
    NI-RFmx Noise Figure License 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx Noise Figure License 2.2 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Noise Figure License 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Noise Figure License 2.2 to an unsupported OS. Additionally, after installing NI-RFmx Noise Figure License 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx Noise Figure License 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx Noise Figure License 2.2 installation, the following software is installed. To completely remove the NI-RFmx Noise Figure License 2.2 installation from your system, you must also remove the following packages:
    • NI-RFmx Noise Figure Runtime License 2.2
    © 2016 National Instruments. All rights reserved.
    376695A-01
    GMT+8, 2026-1-13 09:39
