查看: 1814|回复: 0
[NI软件产品] NI RFmx SpecAn 19.0 Full Win32/64ENG RFmx频谱分析仪19.0完整版
    发表于 2022-4-6 15:22:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2019/6/27
    包含的版本:
    19.0完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 1041430528 字节 (993.19 MB)
    修改日期: 2019-07-18 18:12
    MD5: 1ddd95b5a7534d9d2534362d99f05765
    SHA1: e4e2e22c4bad2e042ff5d85032a6b0b1f913a398
    SHA256: 3069f9df87afeee58fcbe5c13516629239edb89666d2302ebe23b7e368a7bbda
    CRC32: 1c94841a
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn19.0.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx SpecAn 19.0 Readme
    June 2019
    This file contains important information about the RFmx SpecAn, including installation instructions, new features, bugs fixes, and known issues.
    Installed Software
    RFmx SpecAn Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx SpecAn offers simple access to the most advanced optimization techniques such as multi-measurement parallelism, multi-DUT measurements, and high dynamic range noise correction. The result is extremely fast and high-quality measurements with the minimal software development effort.
    RFmx SpecAn 19.0 includes the following new features:
    • Addition of alias protected synchronization method in AMPM and DPD measurements for reliable synchronization with non-contiguous multi-carrier waveforms
    • Support for PXIe-5830 (EAP) and PXIe-5831 (EAP)
    RFmx SpecAn 3.0 includes the following new features:
    • Support for PXIe-5820
    • Addition of a new API to validate calibration data for Noise Figure measurement
    • Addition of input and output XdB compression point result for various compression levels in AMPM
    • Addition of the Origin Offset Correction Enabled property in AMPM and DPD measurements
    RFmx SpecAn 2.5 includes the following new features:
    • Addition of Phase vs Time trace in AMPM measurement
    • Addition of Reference Power Type attribute in AMPM measurement
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for monitoring an RFmx application in RFmx Soft Front Panel
    • Support for querying configuration attributes without calling RFmxSpecAn Commit API
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830 (EAP)
    • PXIe-5831 (EAP)
    System RequirementsRFmx SpecAn has the following requirements:
    • 4 GB RAM*
    RFmx SpecAn 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2019, RFmx SpecAn dropped support for all 32-bit Windows operating systems. RFmx SpecAn will not install or run on an unsupported OS. Refer to RFmx SpecAn Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. To add support for application software installed after installing RFmx SpecAn modify your RFmx SpecAn installation or launch the RFmx SpecAn installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx SpecAn
    LabWindows™/CVI™2013 SP2 or laterRequired Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 19.0 (for DPD examples)
    NI installs RFmx SpecAn using NI Package Manager. If you do not already have NI software installed, RFmx SpecAn installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\SpecAn\Examples
    Examples\LabVIEW \examples\RFmx\SpecAn
    Select Start»All Programs»National Instruments»RFmx SpecAn»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFmx»SpecAn. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed RFmx SpecAn examples at Start»All Programs»National Instruments»RFmx SpecAn»RFmx SpecAn Examples.
    Documentation for RFmx SpecAn is located at Start»All Programs»National Instruments»RFmx SpecAn»RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx SpecAn HelpHTML/Windows HelpContains primary help content for RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx SpecAn
    • A complete reference for all RFmx SpecAn programming functions and VIs
    RFmx SpecAn 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Accessing VIs
    RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx»SpecAn palette.
    The following items are behavior changes in RFmx SpecAn 19.0 from RFmx SpecAn 3.0.
    The following items are the behavior changes in RFmx SpecAn 2.5 from RFmx SpecAn 2.4.
    • Dropped support for RFmx SpecAn Measurement Interactive Panel (64-bit)
    The following items are the IDs and titles of a subset of issues fixed in RFmx SpecAn. This is not an exhaustive list of issues fixed in the current version of the RFmx SpecAn. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx SpecAn 19.0 from RFmx SpecAn 3.0
    728966Fixed an issue with ACP dynamic range measurement for the signal re-configuration use case.
    739646Fixed an issue in compensating the external pre-amp gain for Noise Figure measurement.
    The following items are changes in RFmx SpecAn 3.0 from RFmx SpecAn 2.5
    719203Fixed an issue where a timeout error was returned when the digital trigger was configured when 'Using breakpoints in C/C++/.NET application' was selected in the PXIe-5840.
    711341Fixed an issue where Apply DPD resulted in negative PAPR after adjusting power offset under high compression.
    714332Fixed an issue with the computation of compression point in AMPM.
    The following items are changes in RFmx SpecAn 2.5 from RFmx SpecAn 2.4
    693345Fixed an issue with the behavior of Auto Sweep Time in Zero Span Mode. The Zero Spam Mode of spectrum measurement now uses Auto RBW and Auto Sweep Time as 10 MHz and 1 ms respectively.
    695688Fixed an issue with IQ data measurement, where querying IQ Bandwidth property always returned 1 MHz when auto-bandwidth was enabled.
    RFmx SpecAn will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2014–2019 National Instruments. All rights reserved.
    374847L-01
    GMT+8, 2026-1-13 09:38
