查看: 1943|回复: 0
[RTE运行引擎] NI RFmx SpecAn 2.5 Runtime Win64ENG RFmx频谱分析仪2.5运行版
    发表于 2022-4-6 15:11:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2018/7/3
    包含的版本:
    2.5运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 319741976 字节 (304.93 MB)
    修改日期: 2018-07-03 17:49
    MD5: 5531897472b410005b4fda06c2376861
    SHA1: 366522564d069862fd66f4bd0aa5e9346ae579a8
    SHA256: b06e3cf31404894aa5c52251c15a8e3dc175837ebdf9e8a400d1ee12ceaea55c
    CRC32: fea3a734
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn2.5RTE64.txt (523 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx SpecAn 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Activation Instructions for NI-RFmx Noise Figure License
    Accessing VIs and Functions
    NI-RFmx SpecAn 2.5 includes the following new features:
    • Addition of Phase vs Time trace in AMPM measurement
    • Addition of Reference Power Type attribute in AMPM measurement
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for monitoring a RFmx application in NI-RFmx Soft Front Panel
    • Support for querying configuration attributes without calling RFmxSpecAn Commit API
    NI-RFmx SpecAn 2.4 includes the following new features:
    • Support for crest factor reduction for pre-DPD and post-DPD signal processing when operating under high compression
    • Improvement in performance and stability in Iterative Memory DPD
    • Addition of the NMSE result property to DPD measurement
    • Speed performance improvements with Noise Figure measurement
    NI-RFmx SpecAn 2.3.1 includes the following new feature:
    • Addition of NI-RFmx SpecAn Soft Front Panel (SFP 64-bit) with debug support
    NI-RFmx SpecAn 2.3 includes the following new features:
    • Addition of Phase Noise measurement
    • Addition of Max Timing Error property in DPD and AMPM
    • Support for VBW in Spectrum, Spur, TxP and Zero Span measurements
    • Support for Detectors in Spectrum, Spur and Zero Span measurements
    Caution  Before you install NI-RFmx SpecAn 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    Note  Some of the installed NI-RFmx SpecAn .NET examples require NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries. For these examples to build and run successfully, install NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries before or after installing NI-RFmx SpecAn.
    The Noise Figure measurement requires license activation. To evaluate or activate the Noise Figure license, you must install the Noise Figure license, which is a separate installer from the RFmx SpecAn installer. If you install the Noise Figure license but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx SpecAn 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx SpecAn dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx SpecAn 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx SpecAn 2.5 to an unsupported OS. Additionally, after installing NI-RFmx SpecAn 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFmx SpecAn 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx SpecAn does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 2.5 or later (for DPD examples)
      • (32-bit) windows\system32
    Item
    Installed Location
    Function Panels
    \Shared\CVI\Bin\niRFmxSpecAn.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    \Shared\ExternalCompilerSupport\C\lib32\msvc
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\NI-RFmx\SpecAn\examples
    LabWindows/CVI
    Examples\CVI\samples\RFmx\SpecAn
    Examples\LabVIEW\examples\RFmx\SpecAn
    For 32-bit OS, select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Measurement Interactive Panel to launch the NI-RFmx SpecAn Measurement Interactive Panel (32-bit).
    Select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Note  NI-RFmx Soft Front Panel does not support the FCnt Measurement. However, this measurement is supported in the NI-RFmx SpecAn Measurement Interactive Panel.
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFmx SpecAn HelpHTML/Windows HelpInformation about NI-RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming functions and VIs
    NI-RFmx SpecAn 2.5 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx SpecAn functions are available in LabWindows/CVI from the Library»RFmx SpecAn Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx SpecAn examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx»SpecAn or by directory structure at RFmx»SpecAn.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SpecAn" to locate all NI-RFmx SpecAn examples.
    You can also access all the installed NI-RFmx SpecAn examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Examples.
    Refer to ni.com/examples for these examples and for more information.
    The following items are the behavior changes in NI-RFmx SpecAn 2.5 from NI-RFmx SpecAn 2.4.
    • Dropped support for NI-RFmx SpecAn Measurement Interactive Panel (64-bit).
    The following items are the behavior changes in NI-RFmx SpecAn 2.3.1 from NI-RFmx SpecAn 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@SpecAn' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are no longer supported.
    The following items are the behavior changes in NI-RFmx SpecAn 2.3 from NI-RFmx SpecAn 2.2.
    • The following VIs are no longer accessible from the LabVIEW palette. RFmx SpecAn continues to support VI functionality, but users are encouraged to use replacement VIs.
    • Deprecated VI
      Replacement VI
      RFmxSpecAn DPD Configure Apply DPD Headroom VIRFmxSpecAn DPD Apply Digital Predistortion VI
      RFmxSpecAn DPD Apply DPD VI
    • The Sync Tuned -4 and Sync Tuned -5 enums of RBW filter types are no longer supported in SpecAn.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx SpecAn. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx SpecAn. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx SpecAn 2.5 from NI-RFmx SpecAn 2.4
    ID
    Fixed Issue
    693345Fixed an issue with the behavior of Auto Sweep Time in Zero Span Mode. The Zero Spam Mode of spectrum measurement now uses Auto RBW and Auto Sweep Time as 10 MHz and 1 ms respectively.
    695688Fixed an issue with IQ data measurement, where querying IQ Bandwidth property always returned 1 MHz when auto-bandwidth was enabled.
    The following items are changes in NI-RFmx SpecAn 2.4 from NI-RFmx SpecAn 2.3.1
    ID
    Fixed Issue
    628854Fixed an issue where burst detection failed for some RU locations in 802.11ax MU PPDU.
    645675Fixed an issue where the user mode of Apply DPD required configuration of reference waveform and commit as a workaround.
    675609Fixed an issue with double array properties in Phase Noise and Noise Figure measurements when used with LV 64-bit.
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod, resulted in higher EVM on 5668R.
    671078Fixed an issue where the .NET methods, RFmxSpecAnMXIQResults.FetchData() and RFmxSpecAnMXDpdApplyDpd.ApplyDigitalPredistortion(), threw exception when used with a named result.
    The following items are changes in NI-RFmx SpecAn 2.3.1 from NI-RFmx SpecAn 2.3.
    ID
    Fixed Issue
    647237Fixed an issue with retrieving the properties specific to Spur range measurements when you set the Spur Num Ranges property to n, modify to 'less than n' and then set it back to n.
    643208Fixed an issue with CHP trace when RRC filtering is disabled.
    The following items are changes in NI-RFmx SpecAn 2.3 from NI-RFmx SpecAn 2.2.
    ID
    Fixed Issue
    631477Fixed an issue with retrieving the results in CHP measurement through property node with a named result.
    623301Fixed an issue with retrieving the calibration data in Noise Figure measurement when using the 26.5 GHz NI PXIe-5668R with 26.5 GHz RF Preamplifier (NI PXIe-5698).
    © 2014–2018 National Instruments. All rights reserved.
    374847J-01
    GMT+8, 2026-1-13 09:40
