查看: 2128|回复: 0
[RTE运行引擎] NI RFmx SpecAn 2.3.1 Runtime Win64ENG RFmx频谱分析仪2.3.1运行版
    发表于 2022-4-6 11:58:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2017/10/16
    包含的版本:
    2.3.1运行版
    Windows 10 (64-bit)
    Windows 8.1 (64-bit)
    Windows 8.0 (64-bit)
    Windows 7(SP1) (64-bit)
    Windows Server 2008 R2 (64-bit)
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 288567296 字节 (275.20 MB)
    修改日期: 2017-10-13 00:25
    MD5: b05368f512f2721fbf2a2021c8b92426
    SHA1: 35fa2418ce35ea62750eeb7e407360b545d136bb
    SHA256: 676820824218be0062b8618ac5b42a874e3b50dadaa5c919e86d3a4cd8c4b6e5
    CRC32: 15342f2f
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn2.3.1RTE64.txt (527 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx SpecAn 2.3.1 Readme
    October 2017
    This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Activation Instructions for NI-RFmx Noise Figure License
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx SpecAn
    NI-RFmx SpecAn 2.3.1 includes the following new feature:
    • Addition of NI-RFmx SpecAn Soft Front Panel (SFP 64-bit) with debug support
    NI-RFmx SpecAn 2.3 includes the following new features:
    • Addition of Phase Noise measurement
    • Addition of Max Timing Error property in DPD and AMPM
    • Support for VBW in Spectrum, Spur, TxP and Zero Span measurements
    • Support for Detectors in Spectrum, Spur and Zero Span measurements
    NI-RFmx SpecAn 2.2 includes the following new features:
    • Addition of noise figure (NF) measurement using Y-Factor and Cold Source methods.
    • Addition of intermodulation (IM) distortion measurements.
    • Support for noise compensation in Spectrum measurement.
    • Support for the linear LUT type in DPD.
    • Support for ENBW on RBW filter bandwidth definition.
    • Addition of Allan Deviation result in frequency counter (FCnt) measurement.
    • Support for LO leakage avoidance when using vector signal transceiver as the analyzer.
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications.
    • Addition of advanced instrument attributes to measurement interactive panel.
    NI-RFmx SpecAn 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution  Before you install NI-RFmx SpecAn 2.3.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    Note  Some of the installed NI-RFmx SpecAn .NET examples require NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries. For these examples to build and run successfully, install NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries before or after installing NI-RFmx SpecAn.
    The Noise Figure measurement requires license activation. To evaluate or activate the Noise Figure license, you must install the Noise Figure license, which is a separate installer from the RFmx SpecAn installer. If you install the Noise Figure license but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx SpecAn 2.3.1 supports the following operating systems:
    Note  NI-RFmx SpecAn 2.3.1 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  For better responsiveness of the NI-RFmx Soft Front Panel on a remote desktop, National Instruments recommends changing the remote desktop connection colors setting to be 16-bit color depth.
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx SpecAn does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 2.3 or later (for DPD examples)
      • (32-bit) windows\system32
    ItemInstalled Location
    Function Panels
    \Shared\CVI\Bin\niRFmxSpecAn.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    \Shared\ExternalCompilerSupport\C\lib32\msvc
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\RFmx\SpecAn\examples
    LabWindows/CVI
    Examples\CVI\samples\RFmx\SpecAn
    Examples\LabVIEW \examples\RFmx\SpecAn
    Select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Measurement Interactive Panel to launch the NI-RFmx SpecAn Measurement Interactive Panel (32-bit / 64-bit).
    Select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx Soft Front Panel to launch the NI-RFmx Soft Front Panel (64-bit).
    Note  NI-RFmx Soft Front Panel does not support the following SpecAn measurements:
    • FCnt Measurements
    • Harmonics Measurements
    • Phase Noise Measurements
    However, these measurements are supported in NI-RFmx SpecAn Measurement Interactive Panel.
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx SpecAn HelpHTML/Windows HelpInformation about NI-RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming functions and VIs
    NI-RFmx SpecAn 2.3.1 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx SpecAn functions are available in LabWindows/CVI from the Library»RFmx SpecAn Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx SpecAn examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx»SpecAn or by directory structure at RFmx»SpecAn.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SpecAn" to locate all NI-RFmx SpecAn examples.
    You can also access all the installed NI-RFmx SpecAn examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Examples.
    Refer to ni.com/examples for these examples and for more information.
    NI-RFmx SpecAn 2.3.1 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx SpecAn drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx SpecAn 2.3.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx SpecAn 2.3.1 to an unsupported OS. Additionally, after installing NI-RFmx SpecAn 2.3.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx SpecAn 2.3.1 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx SpecAn 2.3.1 installation, the following software is installed. To completely remove the NI-RFmx SpecAn 2.3 installation from your system, you must also remove the following packages:
    • NI-RFmx SpecAn Runtime 2.3.1
    • NI-RFmx SpecAn Runtime 2.3.1 (64-bit)
    The following items are the behavior changes in NI-RFmx SpecAn 2.3.1 from NI-RFmx SpecAn 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty sting).
    • The alias 'default@SpecAn' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx version older than 2.2 are no longer supported.
    The following items are the behavior changes in NI-RFmx SpecAn 2.3 from NI-RFmx SpecAn 2.2.
    • The following VIs are no longer accessible from the LabVIEW palette. RFmx SpecAn continues to support VI functionality, but users are encouraged to use replacement VIs.
    • Deprecated VIReplacement VI
      RFmxSpecAn DPD Configure Apply DPD Headroom VIRFmxSpecAn DPD Apply Digital Predistortion VI
      RFmxSpecAn DPD Apply DPD VI
    • The Sync Tuned -4 and Sync Tuned -5 enums of RBW filter types are no longer supported in SpecAn.
    The following item is a behavior change in NI-RFmx SpecAn 2.0 from NI-RFmx SpecAn 1.2.
    • In the ACP measurement spectrum trace, RFmx 1.2 reports relative frequency from the RF center frequency on the x-axis. RFmx 2.0 reports RF absolute frequency on the x-axis.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 2.3.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 2.3.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx SpecAn. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx SpecAn. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx SpecAn 2.3.1 from NI-RFmx SpecAn 2.3.
    647237Fixed an issue with retrieving the properties specific to Spur range measurements when you set the Spur Num Ranges property to n, modify to ‘less than n’ and then set it back to n.
    643208Fixed an issue with CHP trace when RRC filtering is disabled.
    The following items are changes in NI-RFmx SpecAn 2.3 from NI-RFmx SpecAn 2.2.
    631477Fixed an issue with retrieving the results in CHP measurement through property node with a named result.
    623301Fixed an issue with retrieving the calibration data in Noise Figure measurement when using the 26.5 GHz NI PXIe-5668R with 26.5 GHz RF Preamplifier (NI PXIe-5698).
    The following items are changes in NI-RFmx SpecAn 2.2 from NI-RFmx SpecAn 2.1.
    579773Fixed an issue with CHP fetch results when multiple carriers are configured with a signal name.
    572302Fixed an issue with abort measurements when performing spectral acquisition.
    581477Fixed a memory leak with IQ measurement when a signal configuration containing IQ measurement is deleted.
    605884Fixed an issue in .NET where the enum values of the Threshold Type attribute used in CCDF, FCnt, and TxP were not consistent with LabVIEW and C API.
    601654Fixed an issue when switching between RFmx and RF toolkits where RFmx may not apply the acquisition settings correctly in certain scenarios.
    © 2014–2017 National Instruments. All rights reserved.
    374847G-01
    GMT+8, 2026-1-13 09:37
