查看: 1886|回复: 0
[NI软件产品] NI RFmx SpecAn 2.1 Full Win32/64ENG RFmx频谱分析仪2.1完整版
    发表于 2022-4-6 11:30:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2016/2/3
    包含的版本:
    2.1完整版
    Windows 10 (32-bit and 64-bit)
    Windows 8.1 (32-bit and 64-bit)
    Windows 8.0 (32-bit and 64-bit)
    Windows 7 (32-bit and 64-bit)
    Windows Server 2008 R2 (64-bit)
    语言:
    英文
    应用程序位数:
    32/64位
    修改日期: 2016-02-03 01:09
    MD5: 51d98e3223621bdb321f09bc45b9c9ee
    SHA1: 202d4013a8695450ca4dfb9a62884c0ba81d8a32
    SHA256: f6cb4a40503a11205394eec1fd8cc29dbdb7a36f364181b5478630356c556340
    CRC32: c61f2f48
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn2.1.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx SpecAn 2.1 Readme
    February 2016
    Thank you for using NI-RFmx SpecAn. This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx SpecAn
    NI-RFmx SpecAn 2.1 includes support for the Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q or Spectrum waveform.
    NI-RFmx SpecAn 2.0 includes the following new features:
    • Addition of I/Q measurement
    • Support for multicarrier CHP measurements
    • Support for offset frequency definition in ACP and SEM measurements
    • Support for 3 dB, 6 dB, and bin width RBW definitions for spectral measurements
    • Support for detection of spurs with peak excursion as criteria in spur measurements and when using peak search with markers
    • Support for Magnitude Only and Phase Only correction for memory polynomial DPD models
    • Support for average, linear, and peak gain targets in DPD
    • Improved memory and speed performance of DPD measurements and composite measurements
    • Support for LabVIEW 2015 (32-bit and 64-bit)
    NI-RFmx SpecAn 1.2 includes the following new features:
    • Support for NI 5668R
    • Addition of AMPM and DPD measurements
    NI-RFmx SpecAn 1.1 includes support for C, LabWindows™/CVI™, and .NET.
    Caution  Before you install NI-RFmx SpecAn 2.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    Note  Some of the installed NI-RFmx SpecAn .NET examples require NI-RFSG .NET Class Libraries. For these examples to build and run successfully, install NI-RFSG .NET Class Libraries before or after installing NI-RFmx SpecAn.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx SpecAn 2.1 supports the following operating systems:
    • Windows 10 (32-bit and 64-bit)
    • Windows 8.1 (32-bit and 64-bit)
    • Windows 7 Service Pack 1 (32-bit and 64-bit)
    Note  NI-RFmx SpecAn 2.1 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx SpecAn does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG .NET Class Library 14.5 or later*
    • NI-RFSA .NET Class Library 14.5*
    *NI-RFSA .NET Class Library and NI-RFSG .NET Class Library are only required for .NET support.
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\National Instruments\MeasurementStudioVS2010
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments\MeasurementStudioVS2010
      • Windows 10/8.1/7: Users\Public\Documents\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/7
    Function Panels
    \Shared\CVI\Bin\niRFmxSpecAn.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files
    Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit):\Shared\ExternalCompilerSupport\C\include
    C, .NET, NI TestStand
    Examples\RFmx\SpecAn\Examples
    LabWindows/CVI
    Examples\CVI\samples\RFmx\SpecAn
    Examples\LabVIEW \examples\RFmx\SpecAn
    Select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Measurement Interactive Panel to launch the NI-RFmx SpecAn Measurement Interactive Panel.
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx SpecAn HelpHTML/Windows HelpInformation about NI-RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming functions
    NI-RFmx SpecAn 2.1 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx SpecAn functions are available in LabWindows/CVI from the Library»RFmx SpecAn Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx SpecAn examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx»SpecAn or by directory structure at RFmx»SpecAn.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SpecAn" to locate all NI-RFmx SpecAn examples.
    You can also access all the installed NI-RFmx SpecAn examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Examples.
    • Select NI-RFmx SpecAn 2.1 from the dialog box that appears.
    • Click the Uninstall button.
    As part of the NI-RFmx SpecAn 2.1 installation, the following software is installed. To completely remove the NI-RFmx SpecAn 2.1 installation from your system, you must also remove the following packages:
    • NI-RFmx SpecAn Runtime 2.1 for LabVIEW
    • NI-RFmx SpecAn Runtime 2.1 for C/.NET
    • NI-RFmx SpecAn Runtime 2.1 (64-bit) for C/.NET
    The following item is a behavior change in NI-RFmx SpecAn 2.0 from NI-RFmx SpecAn 1.2.
    • In the ACP measurement spectrum trace, RFmx 1.2 reports relative frequency from the RF center frequency on the x-axis. RFmx 2.0 reports RF absolute frequency on the x-axis.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 2.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 2.1.
    The following items are changes in NI-RFmx SpecAn 2.1 from NI-RFmx SpecAn 2.0.
    560637Fixed an issue with fetching all spurs list when traces are disabled.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    The following items are changes in NI-RFmx SpecAn 2.0 from NI-RFmx SpecAn 1.2.
    531357Fixed an issue with AMPM and DPD when using waveforms with high auto correlation.
    538026Fixed an issue with acquiring a signal using composite measurements and a trigger is enabled.
    541755Fixed an issue where the default RBW definition was set to 3 dB bandwidth of the FFT window instead of using FFT bin spacing when using an FFT based RBW filter type in spectral measurements.
    515825Fixed an issue with CHP measurement not integrating the power in the RRC filter roll off when the RRC filter is enabled and the span is not configured or it is configured to be less than integration bandwidth.
    The following items are changes in NI-RFmx SpecAn 1.2 from NI-RFmx SpecAn 1.1.
    457564Fixed composite measurement on a multicarrier signal with at least one measurement measuring a single carrier.
    506637Fixed an issue in which peaks were detected twice in some cases of Spur measurement.
    510432Fixed an issue in which incorrect peaks were detected when the limit line had a nonzero slope in Spur measurement.
    The following items are changes in NI-RFmx SpecAn 1.1 from NI-RFmx SpecAn 1.0.
    484980Fixed an issue in which the RFmxSpecAn Auto Level VI was not able to handle RF front end attributes.
    488782Fixed an issue in which an error was not returned when the start frequency was equal to the stop frequency for Spur and SEM measurements.
    484136Fixed an issue in which the waveform duration and delay in zero span were incorrect when RBW was set to a value less than 2 MHz.
    487678Fixed an issue in which incorrect power was reported when the span was less than the integration bandwidth for CHP measurement.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view click the down arrow on the bottom left of the screen.
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2014–2016 National Instruments. All rights reserved.
    374847C-01
    GMT+8, 2026-1-13 09:36
